Go Back   BMW X5 and X6 Forum (F15/F16) > BMW X5 (F15) and BMW X6 (F16) Forum > Vendors Classifieds
      03-06-2018, 12:26 PM   #1
Mike@N54Tuning.com
Joint Chiefs of Staff
Drives: 2007 335i, 2015 M3
BOOTMOD3 N55 / N20 / N26 OBD Unlock + 1 Free OTS MAP @ www.n54tuning.com
NOW Available
ORDER LINK
https://www.n54tuning.com/bootmod3-n...-x4-x5-m2.html
ProTUNING Freaks
BOOTMOD3 N55 N20 N26 BETA - BMW F2X F3X 228I 328I 428I 235I 335I 435I 535I 640I X3 X4 X5 M2
OBD based flash at home!! No need to PULL ECU!!
World's first custom mobile flash tuning platform for the BMW F series. Developed and tested in-house from the ground up over the course of almost 2 years with more features being added regularly makes the bootmod3 platform a custom BMW factory DME tuning solution like no other on the market today.
Build the ultimate tune for your N55 /N20 / N26 powered vehicle and go from stock to full race calibration, and everywhere in between, with a map switch in the provided mobile app. bootmod3 calibrates the factory vehicle modules over the OBD port in a matter of minutes in the convenience of your driveway or anywhere internet access is available.
bootmod3 app and cloud services offer many unique features not found in any other flash tune including and currently available:
Mobile app (iOS and Android) and Web (http://www.bootmod3.net)
One OTS map/tune included with the purchase
Datalogging over 200 diagnostic channels, up to 40 channels concurrently
Datalog sharing and charting without a need to upload to 3rd party websites or apps using the mobile app or web browser
DCT TCU (transmission) flash for maximized clutch clamping force extending life on stock and upgraded DCT clutch packs
Cloud based storage for map data and datalogs
Reverting back to stock performance map
Live Dash - realtime vehicle parameter monitoring via in-app guages
GTS TCU Flash for DCT vehicles
Diagnostics
Read and clear trouble codes in all vehicle modules
Reset learned adaptations (octane, knock, Valvetronic, etc)
ECU power reset
(Optional) Off the shelf (OTS) tunes for 91/93/Race gas/E85 octane at $100 per map (SEE HERE)
(Optional) Custom tuning for non-standard vehicle hardware and alternative fuels such as E85 and race gas
Customization of an existing OTS map $300 per map
Prior OTS map purchase required
Some of the map features provided:
- Top speed (VMAX) limiter removal
- Higher rev limiter
- GTS Startup Roar
- Cold start cat heat cycle removed (for off-road use)
- Cat efficiency check removed (for off-road use)
- Exhaust valve control and overrun (burble)
- Maps for upgraded Stage 1 and Stage 2 turbos
- E85/blend, race gas and meth injection tuning
- Custom Throttle mapping
- Backend Flash maps for use with piggybacks such as the JB4
Overview of what’s been covered:
OBD Unlock:
- New convenience option to unlock your DME and tune the car with BM3. The previous bench type unlock is still fully supported.
- Unlock DME without pulling it out of the car or sending out for unlock
- NO SPECIAL CABLES or hardware required. Uses the same ENET cable still that you can get on Amazon for around $16-20. No waiting time for special cables to be shipped or waiting on us to ship them as they're available through Amazon
- Instant activation and OTS map download! No waiting after purchase
- OBD unlock for new cars/install time around 260 seconds start to finish instead of 10-50minutes with other F series tuning solutions.
- Revert back to Stock and locked. No chance of tamper code showing once flashed back.
- No flash counter limitations - our dev cars have been flashed well over 1000 times. This has always been a BM3 feature.
- Flash date freeze - unique BM3-first feature, no other tool supports today. Flash date never changes when flashing with BM3.
- Flash counter freezes after OBD unlock
We also offer the BOOTMOD3 OBD AGENT DEVICE
https://www.n54tuning.com/bootmod3-o...-vehicles.html
and you can get the BMW ENET Interface Cable (OBD To Ethernet) For BOOTMOD3
https://www.n54tuning.com/mw-enet-in...-bootmod3.html
