      01-13-2017, 04:51 PM   #3059
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by HZX540e View Post
When was this released?
Which one?
      01-13-2017, 04:53 PM   #3060
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
Which one?
I have mn-003.009.004 and tn-003-009-004
      01-14-2017, 12:54 AM   #3061
Almaretto
Almaretto's Avatar
2374
That means you have I-Step F025-16-07-506 & NBT_M15392A.
MN/TN-003.013.002 (F025-16-11-501) came out in November. There have been three releases since, but only two integration changes for the F015.
      01-14-2017, 10:06 AM   #3062
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
And where can I get that update?
Never mind I found the instructions it's quite a bit of work.
      01-15-2017, 02:44 PM   #3063
Almaretto
Almaretto's Avatar
2374
Yes, additional hardware (ie PSU) is required and poses greater risk than coding.
There is no reason to update BT unless you are having issues. BMW rolls out software to fix problems rather than bring new features. The ladder comes with LCI's and new chassis codes (eg, F015 vs G005).
      01-17-2017, 08:19 AM   #3064
C4sF80M3
23
Drives: 17 F80 M3 ZCP
Vehicle is a 2017 X5 with all options minus the Carplay.
Originally Posted by FourDoor View Post
Added Carplay functionality usually requires hardware upgrades to the entertainment system (from what I've seen with other vehicles). Has anyone been able to confirm that Carplay can be added to previous model years (with or without hardware upgrades?)
      01-17-2017, 08:30 PM   #3065
Almaretto
Almaretto's Avatar
2374
Then you are short an FSC code.
      01-18-2017, 08:56 PM   #3066
leo95se
Drives: '09 e92 M3, '15 F15 X5d
is there a way to check or verify the usb port is working correctly? i can plug a usb cable in and play my phone, but i have tried 3 usb/flash cards to install map/software updates, and none seem to be read. two of them give errors of incompatible software, and one is operation is not available at this time.
i am trying to install update 5074, and latest maps (2017-1). wondering if all cards are getting bad formatting from my mac, but i formatted one via windows, and one is my gopro card. im stumped and am wondering if this can be checked through software.
thanks..
      01-18-2017, 09:05 PM   #3067
Neuera09
Drives: 2016 X5 Xline with MPPK
thanks..
USB must be formatted as FAT32. Once u have formatted it, put an MP3 music file and try playing that music via your idrive. Good luck.
      01-18-2017, 09:38 PM   #3068
leo95se
All are formatted as fat32. Good idea on the music test! It worked for m4a and MP3. Still won't read maps or software. Ugh. So remedial and I'm stumped.
      01-18-2017, 10:34 PM   #3069
Neuera09
okay. you are using a 32gb thumb drive right? Also, take a picture of your flash drive directories or folders.
      01-19-2017, 01:09 AM   #3070
Almaretto
Almaretto's Avatar
2374
You can get an incompatible error if you try to load earlier BT Media and Communication than vehicle's current software.
UPD5074 = MN-002.255.071/TN-002.255.070. If I tried to load on my vehicle (MN/TN-003.013.001), I would get an error.
Make sure files are in the root directory.
      01-19-2017, 06:22 PM   #3071
bms5
Drives: 2010 335d, 2018 540d
C027 Runtime Error
Hi all!
About a month ago, I successfully coded out the iDrive legal disclaimer and coded Close trunk via Keyfob and inside button with no issues.
Today, I was starting the coding in preparation to retrofit 2VB (TPMS) and successfully added 2VB to the FA. I am getting the sensors installed tomorrow.
However, when I went in to DSC, BDC and HU_NBT to code them, I am getting a Runtime Error C027 when clicking on EDIT FDL after reading the CAFD folder.
The same thing happens in all 3 modules.
Any thoughts on what is wrong?
Thanks!
      01-19-2017, 07:27 PM   #3072
Neuera09
Originally Posted by bms5 View Post
Hi all!
Thanks!
http://f30.bimmerpost.com/forums/sho...highlight=C027
Almaretto2374.00
      01-19-2017, 07:39 PM   #3073
bms5
Thanks, I had just found that thread a few minutes ago. I don't fully understand the procedure to use FDL editor, though. I have located the ncd. file numbers from each of the modules and copied them into the editor but I don't see any available cheat codes for turning on RDC.
      01-19-2017, 07:58 PM   #3074
SAshraf7
Drives: X5 2017
Hello everyone.
This has been a great website and has been very helpful.
I have just purchased 2017 X5 with M Sport package.
I have coded a few things without any problems.
I am trying to code video in motion and have followed all of the settings in the cheat sheet. However it does not seem to have made a difference when the car it's driving over 2 miles an hour. The closest I have found some way of getting this done is h**p://naviks.com/i-24075600-2017-bmw-x5-x5m-f15-f85-idrive-5-0-video-in-motion-bypasstv-free-dvd.html (I don't know if this is real and if it works)
Are there any new coding options for the 2017 models in regards to video in motion?
Also, I coded the surround view to be enabled at any driving speed based on the cheat sheet. It works fine but it does go away after a few seconds at higher speeds. Is there another setting that can be used to enable it for a longer period of time?
While doing research, it seems that a lot of people caution to not to code any guess work (which I agree). However I have also seen people recommending "try it, if it doesn't work then change it back"
Can the car get damaged (where you have to flash it back) by trying settings? Can you always easily revert it back? (I did make backup of the original CAFD files)
Last question, is there a service manual available for the vehicle?
      01-19-2017, 08:53 PM   #3075
Almaretto
Almaretto's Avatar
2374
When you Right Click Orange CAFD & Select Edit, it is just redirecting you to FDL-Editor. There are not Cheat Codes, especially for options that can be VO coded, for every module. But, make sure to check "Auto Fetch Codes," and clear any filters.
For IDrive5, video in motion can be coded for up to 63 kph. If you need at all speeds, you can purchase script activation or emulator that fools GPS.
It would depend on what you are coding whether you can do real damage. To revert back to factory, VO code.
For Service Manual, use ISTA+.
      01-19-2017, 09:39 PM   #3076
bms5
[QUOTE=Almaretto;21145622]When you Right Click Orange CAFD & Select Edit, it is just redirecting you to FDL-Editor. There are not Cheat Codes, especially for options that can be VO coded, for every module. But, make sure to check "Auto Fetch Codes," and clear any filters.
When I added 2VB to the FA, it asked me whether I wanted to transfer the change to Coding (or worded something like that). I was unsure so I said no.
If I do that, does it automatically code the necessary modules without going in and editing them?
      01-20-2017, 12:00 AM   #3077
Almaretto
Almaretto's Avatar
2374
I have never seen any wording to that affect. Modifying FA, alone, does not automatically code anything. You most load said FA, activate, and VO code necessary ECU's.
      01-20-2017, 04:09 PM   #3078
bms5
Attached is a screen shot of the message I am getting.
I have added 2VB to my VO, applied the change, calculated FP, clicked on Save, and when I click the Green 'back' arrow, I then get the message window shown.
      01-20-2017, 04:34 PM   #3079
Almaretto
Almaretto's Avatar
2374
If you have same FA loaded in multiple locations (eg, Expert Mode > Coding, VCM, or Coding-Verification plus Viewers & Editors > FA-Editor), changes in FA-Editor or manually using text editor (ie Notepad++) may result in popups asking if you want to automatically reload FA with associated changes.
That does not have any affect on coding or VCM until changes are pushed through VO coding or VCM section, respectively.
EDIT: One option is to leave your FA factory by loading modified FA (Expert Mode > Coding> Vehicle Order) rather than writing changes to VCM.
      01-20-2017, 04:55 PM   #3080
bms5
I am so new to this and wish I understood more of the acronyms!
So if I understand you correctly, saying yes to this pop up is OK?
I am trying to follow this video so any variance makes me nervous!
http://www.bmwesys.com/guides/Beginn...e%20Coding.pdf
Is there an all-inclusive resource for learning this that you can suggest?
Thanks for your all your help and especially your patience, Almaretto!
