01-13-2017, 09:48 AM | #1 |
Rep 19
Those with Exhaust mod
I have a strong desire to get either AC Schnitzer or Hamann exhaust. I'd like to hear from those with this mod to see if you had any experience or concerns about dealer voiding warranty due to aftermarket part. Mine is 2016 X5 50i with ~18,000 miles. My service department said aftermarket exhaust would void warranty!
I reached out to few experts (thanks friends!) in this forum, even though risk is low due Magnuson-Moss warranty Act would you do it/should I do it? |
01-13-2017, 10:00 AM | #2 |
Rep 208
I have AC Schnitzer on my 16' 50i since 1500 miles
I am very happy with it and can't imagine having warranty issues. I've had my car in twice over 13k miles for maintenance and no problems from service dept. |
01-13-2017, 10:49 AM | #5 | |
Self-Deprecating Narcissist
7266
Rep 6,561
The warranty on the exhaust system along with catalytic converters, o2 etc will be void because you modified the functionality of that system. The warranty on the rest of the vehicle should remain intact because nothing has changed. There is no reason to believe or think that installing a cat-back exhaust would void warranty on a suspension component or window switch or anything that is completely unrelated to the item that was replaced. Secondly, MMWA is only in regards to aftermarket parts that are identical to the factory part it replaced. For example. If you go and buy a Zimmerman rotor to replace a BMW rotor it will not void the warranty on the brake system because it is spec to the factory rotor. This was created to avoid MFG having a monopoly on parts and repair services strong-arming customers into them only using dealerships for service/repairs. That being said the warranty on the rotor is now from Zimmerman and not BMW. BMW will not do a warranty claim on an aftermarket part. Data stored in the vehicle will show it was operating out of the factory specs even if you remove the tune.
01-13-2017, 11:13 AM | #6 |
Rep 5,066
My last service I forgot to remove the Racechip tune and I had no issues from the service department. I plan to keep it on my X5 for the next service...
OP, you live once... enjoy it and don't worry about the warranty.
01-13-2017, 01:19 PM | #7 |
7266
Rep 6,561
Unrelated but somewhat similar. Audi does something a bit more sneaky Kzang, not sure if BMW does as well however when you come in with a tune. It is noticed it is flagged in the system under "TD1" (there are other codes but TD1 is the top dawg) and associated with your VIN you are not aware of it (unless you request the printout from ELSA-Web or AccessAudi showing your vehicle history and status) down the road when you come in say ABC or XYZ occurred then they say "sorry, you're not covered because you have performance software installed on your vehicle". Almost every Audi I have owned has a TD1 flag on it before the temp registration was off the windshield, I never had an issue in-house at the dealership and AOA never denied anything however the remarks and flag was placed on the vehicle and it's history.
TallTrees148.00 |
01-13-2017, 01:59 PM | #8 |
Rep 5,066
I was not aware of that, Thank you for pointing that out!
iconoclast7265.50 |
01-13-2017, 02:37 PM | #9 |
7266
Rep 6,561
Again, not sure if BMW does it the same way but I would guess so.
01-13-2017, 09:13 PM | #10 |
Rep 19
Thanks icon for the info! At least thus far one visit to the dealer no issues
iconoclast7265.50 |
01-14-2017, 10:05 AM | #11 |
Rep 18,739
I am not sure if any of you guys read my writing on the Piggy Back tune, especially the passive piggy back (passive meant, it doesn't read any data off the CAN BUS), but here is the nutshell.
Unless you are full throttling all the time, BMW will not detect the piggy back tunes. The only time the boost number will be recorded over the chart is when you are doing a max boost of default setting, plus "x" psi added by the piggy back tune. So, if you are just punching it on red light to red light, most likely you will record max boost + "x" psi at a millisecond. Also, the last time I heard, the log is only up to certain amount of hours of engine running time. Again, not saying that your warranty will not be voided, but by law, they need proof that the mods is indeed the cause of the trouble. Some dealer just trigger happy just so they can rob you some more. And Audi is specially one. Expensive car with VW quality and Porsche's service / repair rates. That's why a lot of mods company stop trying to partner up with Audi. Some tried and stop since the head office decided to void all of the warranty for the equipped car with the name partnered mods.
iconoclast7265.50 |
01-14-2017, 01:04 PM | #12 | |
7266
Rep 6,561
if a tune is found and or present they have the ability by law to void a warranty because you took a product of theirs and put unauthorized software on it. the liability is now shifted onto the tuner/tune provider unless stated before purchasing that it will void warranty or customer signs a waiver that they are responsible for all and any warranty violations by installing the product. this is why i believe that if you're going to "mod" go big or go home.
01-14-2017, 09:14 PM | #13 |
Rep 18,739
@iconoclast , agree with your statement.
Especially the last sentence.
iconoclast7265.50 |
01-15-2017, 03:05 PM | #14 | ||
Rep 2,353
01-15-2017, 10:17 PM | #15 | ||
Rep 2,353
01-17-2017, 10:40 AM | #16 | ||
Rep 2,353
01-17-2017, 12:08 PM | #17 |
Rep 749
Rest of your vehicle warranty will remain intact unless BMW can prove that there was a mechanical failure due to new exhaust system.
Let's say something goes wrong with your turbos...BMW would have to prove that your exhausts caused the turbos to go down - highly unlikely. I think exhausts is the safest performance mod you can make without having to worry about warranty. |
