      01-14-2017, 02:01 PM   #1
alveoli0
Drives: 08 135 coupe loaded
2014 X5 M rims on 2014 X5 Msport (35i)
I did search and find a number of threads but needed clarification.
I have the opportunity to purchase a relatively new set of X5M (he states 2014?) set of 20" rims and winter runflats (scorporian I&S) for a decent price. Problem is that I've been getting conflicting information about bore size.
The dealer stated that the rims would not fit as X5 M have a adaptive rear dif which results in the bore size for rear wheels being 72 mm. The F15 has a bore size of 74.1 which means the rim needs to be modified. The offset is slightly different between the two models but likely won't make a difference (+/- 5 mm)
Can someone confirm that the 20" X5M OEM rims will fit the same year X5 Msport without modification.
He is running 275/40/20 in the front and 315/35/20 in the rear.
Thanks!!!
