05-01-2023, 05:23 PM | #1 |
Rep 496
ZF8 transmission initial fluid fill amount?
Soooo while doing the front driveshaft I decided to also change my transmission and diff fluids.
For the initial fill of the transmission I could only get in about 2.7l before fluid started coming out. Is that normal? I put a level on the transmission pan front to back and side to side and it’s level af 😉 |
05-01-2023, 07:56 PM | #5 |
Rep 496
Thanks, I’ve found things that varied from 4L to 6.5L if you loosened the solenoid.
I think about 4L total came out when I drained it. With the front diff fluid I had a total of around 4.5L or thereabout |
08-01-2023, 09:29 PM | #6 |
Rep 1
Trans temp fluid
How were you able to measure the temperature of the transmission fluid ? per the FCP video the temp is supposed to be between 40-50 C then topping it off your fluid once it was in this operating range
08-01-2023, 10:21 PM | #7 |
Rep 1,036
You will need a wifi/enet cable. There is no native in iDrive/Cluster way of doing it.
If you are trying to stick to a budged, get yourself a ENET cable and a free copy of ISTA. ISTA will give you the reading. Do a quick search, you should be able to find instructions on how to use ISTA and see that value. Alternatively you can use android apps (+wifi dongle/enet) to see the temp via something like Bimmerlink/Torque. or you can use like a dedicated scanner like a NT530. Personally the 530 is a waist of money, get yourself a ENET/wifi dongle and you will get more use out of it. |
08-01-2023, 10:21 PM | #8 |
154
Rep 355
08-02-2023, 12:45 AM | #9 | |
Rep 5,015
CMYACHTIE3.00 |
08-02-2023, 01:10 AM | #10 | |
Rep 1,036
Granted I do have it rolling around in the trunk, in case of emergency. |
08-02-2023, 03:04 PM | #11 | |
Rep 449
Just start it up and top off and put the plug in. Worst case, the trans is overfilled by a couple ounces. No big deal. |
08-02-2023, 03:49 PM | #12 |
Rep 496
08-02-2023, 03:57 PM | #13 |
Rep 5,015
08-02-2023, 04:14 PM | #14 | |
154
Rep 355
Was this meant as tongue-in-cheek? |
08-02-2023, 04:55 PM | #15 |
Rep 449
08-02-2023, 06:18 PM | #16 |
154
Rep 355
Transmission fluid has a massive volume expansion as temperature rises. That advice amounts to telling somebody they don’t need to pay attention to the manufacturer of a very expensive transmission.
08-02-2023, 10:37 PM | #17 | ||
Rep 449
Here's a sample quote I found on internet. Quote:
The extra oil in the pan acts as a reserve. So the fluid level going up or down a bit has zero effect on function. |
08-02-2023, 11:32 PM | #18 |
154
Rep 355
08-03-2023, 12:20 AM | #19 |
Rep 449
I'm not trolling. I'm just someone who's rebuilt transmissions before, and knows how they work, and I'm asking you why the fluid level is so critical?
08-03-2023, 12:27 AM | #20 |
154
Rep 355
Alright, friend. We obviously have different opinions on what constitutes helpful advice.
This is the advice from the manufacturer... https://aftermarket.zf.com/en/afterm...assenger-cars/ Last edited by Tomcat_F15_STL; 08-03-2023 at 12:38 AM.. |
08-10-2023, 06:37 AM | #21 |
Rep 42
Drives: 545i,2017XC90,2018F15 X5 35iM
How on BimmerLink do you see transmission oil temps?
I have BimmerLink and B code but haven’t been able to see the fluid temps anywhere?
2004 545i and then 2017 XC90 and now 2018 F15 X35i Msport
08-10-2023, 06:46 AM | #22 |
Rep 496
One of the things in BimmerLink is “sensor values”. You can choose various ones to monitor
