      01-31-2017, 09:04 AM   #23
ixlr8
Drives: 2016 X5 35i
Originally Posted by stewy604 View Post
Update on mine, its happened a few times now, the two center vents (dash) blow cold air, regardless of the temp setting - even at max. The blend control makes no difference in this. A cycle of the ignition seems to solve the problem. Any one else experience this?
I have tried all suggestions in this post, I still get cold air blowing out first thing in the morning. Which was not pleasant this morning when it was in the single digits temp wise. The only way I have found to stop it is to turn off the HVAC system and wait for the engine to warm up some before turning it back on. I will try cycling the ignition and see if that helps.
      01-31-2017, 09:04 AM   #24
IvanLZ
IvanLZ's Avatar
Drives: 2015 X5 35i
My solution as of now: turn it off until engines warm up
