      06-12-2018, 03:51 PM   #1
LoganTheDriver
LoganTheDriver's Avatar
11
Drives: Pink X6M
Washer fluid low light - but it's full???
So I emptied and filled the washer fluid reservoir with distilled water. It gave me the washer fluid low light, which I learned is because it has not only a fill sensor but also some kind of chemical analysis sensor and will throw a low light if the right fluid isn't in there. So I bought some BMW washer concentrate and added it. I started with 2 ounces. Still had the light so I increased to 4 ounces. But the light remains!
Anyone have any ideas? The reservoir is completely full. I have distilled water in there mixed with 4 ounces of BMW's washer concentrate.
I'm stumped at this point because 4 ounces is already more than the bottle says you need to put in.
      06-13-2018, 07:44 AM   #2
VGM6
Drives: F86 X6M & E63 M6
I have the exact same problem with my washer fluid and it drives me insane.
      06-13-2018, 06:04 PM   #3
LoganTheDriver
11
Drives: Pink X6M
Got to be a solution to this! Anyone? What's the deal with the low washer fluid light? If it's full, why is it still going off??
      06-13-2018, 07:08 PM   #4
pachieh
Drives: '17 X5M
Bad sensor? That's about the only thing I can think of...
Eisenmann Pro, Dinan Intake, BM3 Stage 1, XHP Stage 3
21" Vossen VFS-1 on Michelin PSS
      06-14-2018, 07:41 AM   #5
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7266
Faulty or failed sensor. Typically occurs if someone used rain-x or similar style washer fluid.
      06-14-2018, 02:18 PM   #6
LoganTheDriver
11
Drives: Pink X6M
Only thing I put in there was distilled water and BMW's washer concentrate.
      06-14-2018, 02:29 PM   #7
iconoclast
iconoclast's Avatar
7266
Not sure if you are the original owner or not but if you are then the obvious question is did you fill it all the way up? If so then I would wager the sensor failed.
      06-16-2018, 10:17 PM   #8
LoganTheDriver
11
Drives: Pink X6M
Original owner. Car only has about 1,000 miles on it. When it ran out of fluid the first time, the low washer fluid light came on for the first time. And then it never went away, even after refilling the reservoir.
It does seem based on that that something went wrong and the sensor failed. It basically had a one trigger life in it because the first time the low washer fluid light went off in the car's history, it never turned back off.
      06-16-2018, 10:58 PM   #9
Apple Corps
Drives: 2018 X5 M
Am I missing something here? If the car only has 1000 miles on it why have you not taken it in to the dealer under warranty? Problem solved.
      06-17-2018, 01:42 AM   #10
LoganTheDriver
11
Drives: Pink X6M
Because the dealers are, in general, retarded and know far less about the cars than the members on this board do. Going to the dealer is the last resort in my head, not the first.
      06-17-2018, 05:33 AM   #11
pachieh
Drives: '17 X5M
Maybe... But they have diagnostic tools we don't. Plus, it is free. If you don't like the one you go to, go to another if there is one nearby.
You have a bad sensor. It should be easy for them to diagnose and replace.
Keep in mind that while the community here knows a fair amount, the vast majority probably don't do a ton of digging into and fixing problems since most of us are under warranty. There's not a lot of engine pulls, crazy internal upgrades, or deep mechanical repairs going on.
      06-17-2018, 09:53 AM   #12
Apple Corps
Drives: 2018 X5 M
My experience has been quite the opposite. So you are going to avoid the dealer, purchase a new sensor somewhere, replace it yourself - all on a new X6 M?
      06-19-2018, 07:58 PM   #13
LoganTheDriver
11
Drives: Pink X6M
Ask here first, go to dealer second. That's my policy. Going to the dealer first would be like walking into a dealer to buy a car with no idea what the going rate for that car is elsewhere. Be equipped with more info, get a better result. Half the time car dealers say something is impossible when it isn't and then I have to bring them the print out from the message boards for them to realize they can actually do it.
      06-21-2018, 09:08 AM   #14
Cabby
Drives: 2019 X740i
2020 BMW M340xi  [0.00]
2019 BMW X7  [0.00]
You used all your windshield wiper fluid in the 1st 1000 miles?!
      06-21-2018, 11:26 AM   #15
VGM6
So I just took my car into the dealer for normal maintenance and had them check the washer fluid and why this might be happening. Since I would fill it up and literally a day or 2 later it would ask for more they decided to check the nozzles both on the hood for the windshield and the bumper nozzles for the headlights. They found that the headlight nozzles were leaking fluid and had them replaced. So i'm hoping that everything is fine now and if the issue continues ill post back.
2015 Alpine White X6M (Akrapovic, ER Downpipes)
2008 Alpine White M6-6MT (Fully Modded S85 w/ Dinan, RDSport, KW, Akrapovic, and Brembo)
      06-22-2018, 08:30 PM   #16
pachieh
Drives: '17 X5M
Ahhhhh... Interesting, didn't think about a nozzle leak.
      07-13-2018, 10:18 AM   #17
iconoclast
iconoclast's Avatar
7266
What was the root cause and solution?
      07-14-2018, 08:49 PM   #18
VGM6
Well my light came back on....... I’m noticing water dripping by the rear of the front passenger wheel. Getting really annoyed.
      07-20-2018, 08:07 PM   #19
CaboM4
BMW Aficionado
1359
Drives: 23 i7,23 iX,24 Silverado
+1 ... wife fucked up the sensor on her F34 using rainx
iconoclast7265.50
      07-20-2018, 08:08 PM   #20
CaboM4
BMW Aficionado
1359
maybe its just because you show up in a pink F86
iconoclast7265.50
      10-31-2019, 09:50 AM   #21
~ViO~
~ViO~'s Avatar
53
Drives: 2013 X6M, 2015 X6 50i
*This fixed my issue 100% and within 5 minutes.... I did not need a new sensor or a tank replacement.. I got this fix straight from a BMW service tech.. You have nothing to loose if your light is already stuck on when the washer tank is full.. Worth a try.
https://f15.bimmerpost.com/forums/sh....php?t=1663527
