06-15-2018, 11:53 AM | #2 |
Rep 1,799
06-15-2018, 04:32 PM | #4 | |
Rep 176
Drives: 17' X5M/91' 325i
Garage List 2017 X5M [0.00]
2014 X5 50i MSport [0.00] 2011 X5 35i SA [0.00] 2007 X3 3.0si [0.00] 2007 335i [0.00] 2003 330Ci [0.00] 1991 325ic [0.00] |
On availability, winters usually come back on the market in Sept/October. I will say, DO NOT WAIT until it is too late. Had a Scorpion that needed to be replaced in Jan and it took 2+ weeks to find one. On another note, a few people seemed to like the Yoko BluEarth 21" winters if you want to swap tires between seasons. I just found it easier to swap wheels between winter and summer, in addition to changing the staggered to 285's all around, which is why I bought the 20" OEM winter set.
17' X5M LBB
91' 325ic - Bril Red, Full Dinan Spec (past) 14' X5 50i MSport - Min White (past) 11' X5 35i SA - Black Saph (past) 07' X3 3.0si MSport |
06-15-2018, 05:17 PM | #5 |
Self-Deprecating Narcissist
7263
Rep 6,561
Michelin production for the new season begins in January and is based on previous years demand. The 21" tires are then ready by mid to late February and begin to get sorted to the usual vendors and then start shipping out sometime around May (iirc). At that point folks like TR and company then take them into inventory and get them ready for the coming season while putting leftover (if any) tires on clearance. There is no other time when they are produced so whatever is sent out is the only available amount and once gone there is no more until January rolls around again.
06-15-2018, 10:33 PM | #6 |
Rep 169
Thanks all for the inputs. Spoke to Tirerack today they have Yokos Bluearth Winter V905 available but only rears as of now 325/30/21. They told me fronts 285/35/21 are in production now and will be released in the fall. Pirelli also will do the same with their Scorpion Ice/Snow run flat
iconoclast7262.50 |
06-16-2018, 06:57 AM | #7 |
Rep 636
Related, if you do a 20" winter and run a 21" summer setup, do you have to get the alignment redone each time you swap.
I had an argument with the dealer recently about this as they were adamant that a 21" alignment was different than a 20" one. I don't believe them, but haven't been able to verify...
06-16-2018, 09:17 AM | #8 | |
Rep 80
My Yoko 21" winter tires are amazing. I just swap out my summer and winter tires. I wouldn't do 20" tires. Just my opinion. I almost settled for 20" tires after I couldn't find 21"...then one day I got lucky and called Tire Rack and a pair just became available in Dallas (a dealer returned them). SO HAPPY I got 21"...and didn't settle for 20.
I live in DC and I have my winter tires on from about Halloween till Easter. That's 5/6 months. Mostly for cold weather, some snow. They worked out perfect and grip is amazing. But driving the car for that long with 20" tires on my x6m??? NO WAY!! lol Be patient, call Tire Rack and you will find a pair. Not even on sale yet. I love how my Yoko 21" winter tires look! Quote:
musa421.50 |
06-16-2018, 11:25 AM | #9 |
Rep 4,213
06-16-2018, 03:24 PM | #10 |
Rep 253
definitely not going to find them now .. have to wait till production begins later in the year. however I have been running the pirelli scorpion snow and ice 21" staggered and they work flawlessly. anyone telling you the wider tire won't work has obviously not tried it.
06-18-2018, 01:28 PM | #11 | |
Rep 2,245
Drives: '16 991.1 911 GTS, '16 F85 X5M
Same with my F10, from 19" to 20" and vice versa.
2016 991.1 911 Carrera GTS
2016 F85 X5M - Carbon Black/Mugello Red |
06-18-2018, 05:35 PM | #12 |
7263
Rep 6,561
In BMW's system there are different settings for the 20" and 21" wheels. You put in the year, model and equipment. If you choose 20 or 21 there are different settings on the machine. I can show you a photo later when I get in showing the different alignment specs. Some may argue the numbers are negligible but if some Engineer sat around tooling and dialing the numbers for either set I am going to go with it. Alignment is cheaper than replacing tires that have worn inner shoulders but new meat everywhere else.
06-18-2018, 06:52 PM | #13 | |
Rep 900
06-19-2018, 08:21 AM | #15 |
Rep 80
Hmmmm...my Yoko winter tires fit the rims exactly the same as the stock tires it came with. No exposure at all.
06-19-2018, 09:48 AM | #16 | |
Rep 58
06-19-2018, 05:49 PM | #17 | |
Rep 636
06-20-2018, 11:19 AM | #18 |
Rep 13
All-season 21" tires
Does anyone have any experience with any all-season tire replacements for the 21" set-up? I found some from Accelera, but I do not know much about them.
Thank you, Brian |
06-20-2018, 11:50 AM | #19 |
7263
Rep 6,561
all-season means they do not well in any season. go for a dedicated set otherwise you may regret it.
