02-05-2017, 11:22 AM | #199 | |
Rep 100
https://www.dropbox.com/s/cs1bpsd4ig...rror.jpeg?dl=0 Thoughts? |
02-05-2017, 12:17 PM | #200 |
Rep 100
Ok, shawnsheridan solved it for me. Of course it was operator error (i.e., me). I was connecting as F010 instead of F025. Re VO coded both BDC_Body and KAFAS.
I didn't re VO code and FDL code both FLE modules since those seemed to work fine yesterday even connected as F010. I also coded a couple of other modules (removed legal disclaimers, etc.) while connected as F010 yesterday and verified that those worked. So.....fingers crossed that GFHB works when I test tonight and I won't have to go through the torture of changing all those werte values back again. |
02-05-2017, 06:18 PM | #201 | |
Rep 8,364
If you use Launcher Cheat codes I took the time to type, then you do not have to torture yourself; just select and apply. |
02-05-2017, 11:14 PM | #202 |
Rep 100
02-05-2017, 11:18 PM | #203 | |
Rep 8,364
cheats |
02-06-2017, 11:11 AM | #204 | |
Rep 100
Is there any way to lower the speed at which it activates? Looks to be around 45 mph and 30-35 would be way more useful. I recall reading about this somewhere but can't find it again. |
02-06-2017, 06:38 PM | #205 | |
Rep 8,364
You can lower it, but system is not necessarily designed to operate at those speeds. |
02-07-2017, 02:27 AM | #206 |
Rep 1,181
^^^ This!!! I think people like the novelty of having them activate at lower speeds and in the city when they are really designed for highway and non-light-polluted stretches.
02-07-2017, 12:06 PM | #207 | |
Rep 108
Here is the code (value in kph in hexadecimal): Below speeds are in HEX VALUE: 00—> 0, 08—> 8, 1F—> 31, 32—> 50, 64—> 100, FF—> 255 BDC_Body / C_HBA_ENA_V_HI / default value = 46 (43 mph) - this is the speed when the HBA enables BDC_Body / C_HBA_ENA_V_LO / default value = 3C (37 mph)- this is the speed when HBA disables http://f15.bimmerpost.com/forums/sho...33&postcount=4 |
02-07-2017, 01:09 PM | #208 | |
Rep 100
03-07-2017, 12:35 AM | #209 |
Rep 1
I got chance to create a video using my GoPro to demonstrate this.
[YT]4ENjIYu_5Ps[/YT] Here's the link: https://www.youtube.com/watch?v=4ENjIYu_5Ps |
03-18-2017, 11:06 PM | #210 |
Rep 192
A little help needed
Hi all,
Picked up my wife's new '17 X5 yesterday and am working hard to get everything coded including GFHB. I downloaded the PDF and made it somewhat through step 1 of Appendix 2 --- 5AP & 8S4 have been successfully removed and I have VO coded BDC_BODY and both FLE. However, the directions state that I also need to VO code either FLA or KAFAS -- I don't have either of those - only FLA3 -- when I attempted to VO code FLA3, I got the below error: FLA3 [5f]Any thoughts? Will this error cause any issues with either my GFHB efforts, or elsewhere (e.g. since the VO code was not completed successfully?) I'm going to proceed to step 2 and change the many values for each FLE... but any suggestions/input would be most appreciated! Thanks! |
03-19-2017, 01:32 PM | #211 |
Rep 192
A quick update - I updated the wert values for FLE, but have yet to apply the changes to my car. Also, wanted to clarify that while I do have the lighting package, I do not have DA+. My '14 F10 is configured in the same manner and I have been able to use GFHB successfully for the past 3 years....
Can somebody please clarify that I do not need to have DA+ to code GFHB on the F15? Also hoping somebody can provide some insight on FLA3 and why I was not able to FO Code it successfully based on the error message I posted earlier --- I do not have a plain FLA listed to code -- did I need to add a module at the time that I deleted 5AP & 8S4? Any help would be greatly appreciated --- the only reason I ordered ZLP on the F15 was to get GFHB... Thanks again |
03-19-2017, 04:42 PM | #212 | |
Rep 8,364
For the FLE changes, you should be using Cheat Codes. |
03-19-2017, 07:06 PM | #213 |
Rep 1,181
Confirmed... you do not need DA+. I don't have it and GFHB works like a charm.
03-19-2017, 08:01 PM | #215 |
Rep 192
03-22-2017, 05:33 AM | #216 |
'06 525xi, '14 435xi, '17 X5 50i, '16 428xi GC
36
Rep 152
I FA coded to remove the 5AP and 8S4 from the FA file. I then right clicked ECU and read code. Then after I right clicked ECU again and coded.
Then I used the cheat to code no dazzle step 2 to both sides. I even went back after coding to double check if the parameters remained in CAFD and FA files. Took a drive and didn't notice anything. The blue high beam indicator would blink on and off. It also remained on when vehicles were around. When I pass the vehicle in front I noticed one of my lights were shining right up to their window. As for the VLD, it should work after removing 5AP and 8S4 from FA, shouldn't it? I didn't notice anything either going from a stand still to 140km/h. At least I got the disclaimers to shut off. Where did I mess up? Should I set it back to factory? How is this done if I had to? 😖 Any insight is appreciated. Maybe I still don't understand what VO coding and I have done so much reading even months before actually trying to code. Last edited by PeanutButterJellyTime; 03-22-2017 at 05:56 AM.. |
03-22-2017, 01:37 PM | #217 | |
Rep 8,364
Modifying FA alone does nothing. VO coding is the actual process of selecting "Code." |
03-22-2017, 06:00 PM | #218 | |
36
Rep 152
I did check the ECU to see if if the step 2 parameters were still applied and it was. I will work on it later and see what else could have happened (not like I would know. Still a noob). I am still able to VO code the modules again without having dire consequences right? To confirm, there is only a step 2 no glare option in cheat code right? No step 3? Last edited by PeanutButterJellyTime; 03-22-2017 at 06:06 PM.. |
03-23-2017, 01:30 AM | #219 | |
Rep 8,364
KAFAS: GLAREFREE_HIGHBEAM_ENABLED: 01 No risk in VO coding multiple times. "F15 (After July 1 2015) - NGHB. Apply to Both FLEs. Step 2 of PDF" |
03-23-2017, 03:30 PM | #220 |
36
Rep 152
Thanks for the info. I will take a look to see if it all matches later. I checked out the high beams again last night and noticed it to be working. I just can't determine if my lowest variable lights are functioning. After seeing how the high beam assistant works I wish the LEDs were separate individual ones like the mercedes one. Good enough I guess.
