02-05-2015, 10:59 AM | #1 |
Rep 75
You can find additional coding here.
Hi everybody!
I'm new in this community. I just finished my first coding following F 15 X5 Cheat Sheet from: https://docs.google.com/spreadsheets...9s4/edit#gid=0 Then I found more in (see attached PDF) Hope it will help to beginners like me. |
02-05-2015, 12:13 PM | #2 | |
Rep 1,768
Hi, welcome to the site. Check this thread: http://f15.bimmerpost.com/forums/sho....php?t=1033991 Your PDF has a few extra codes, maybe they should be added to cheat sheet after testing them. opasha maintains our copy and updates it.
2024 X3 m40i
02-05-2015, 05:05 PM | #4 |
Rep 3,990
Maxipes, welcome and thank you for sharing, buddy . I've looked at all of those codes before and provided some of the extra/untested codes in the coding thread and in threads where people asked for them. There are some codes that are sort of pointless like the dimmer wheel to control the the ambient lighting also (no one wants their ambient lights to be dimmed with their cluster dimmer since it can be controlled separately via our iDrive - this code was designed for those that don't have our feature in order to separate them) and there are a few codes from that pdf that don't exist in the F25/F15/F16 infrastructure.
Ben (r33) recently added the rear view and top view camera at all speeds so that's the latest code that we discussed recently. I just need my car back first to test the different codes before I start posting irrelevant codes that don't work or may screw up people's cars. @nameisjae1 and I tested all the different camera views in order to restore that "default" surround view as the default reverse gear camera (first); there are about 5 or so in the HU_NBT/Camera folder that turned his screen completely blank until he picked the default one set for his surround view. I've already tested a few with others who were kind enough to let me change those codes on their cars during my coding sessions for them - most if not all were non-existent or did nothing. It would be great if someone could sneak into BMW engineering and get their coding manual description that tells us what does what, lol. Till then, it's searching and trial/error .
02-06-2015, 03:38 PM | #5 |
Rep 75
Guys, I tested yesterday all codes from that list and find that in BDC_BODY
Module codes above DON'T WORK! Start Car by pushing button (hold brake not needed) 3020 TCM_STARTLOCK_BRAKE set to: nicht_aktiv 3020 TCM_STARTLOCK_DRIVINGREADINESS set to: nicht_aktiv You will experience of ignition on and off, engine will not start! |
02-06-2015, 04:24 PM | #6 | |
Rep 3,990
02-06-2015, 07:01 PM | #7 |
Rep 18,763
@opasha, that rearview camera. It only work on top view and rearview camera.
While the front camera, it still turned off on drive and can't be pressed on drive. But then on the top view and rear view, it will go off after a few seconds of driving. Will need to mess around with the coding again.
02-06-2015, 07:31 PM | #8 | |
Rep 3,990
