02-07-2024, 08:38 AM | #2 |
Rep 7,489
I'm lost...I'm not seeing any missing "plugs". Are you talking about the oval air duct identified by the arrows in your amended pic below?
If you are, again, those are air ducts that are designed into the trim piece (see #13 in diagram below). They are not "plugs" that should be filled with anything...if you closed them off...you restrict air to the engine bay.
02-08-2024, 01:26 AM | #5 |
Rep 137
You should have an air duct hooked up there. Pictures of your full engine?
https://www.realoem.com/bmw/enUS/sho...diagId=13_1261 |
_ObiJon200.00 |
02-08-2024, 10:57 AM | #6 | |
Rep 7,489
That part (#7 in the diagram) is only used on the N55 engine based on the part database site.
02-09-2024, 05:25 AM | #7 |
873
Rep 345
I found them, no worries. Btw I don’t have stock air duct/intake as It won’t feed a stage 3 turbo…. I built a custom 4” intake … so I don’t use those holes. Found two plugs on eBay… ofcourse I couldn’t find the one I took out from stock.
