      10-09-2023, 05:54 PM   #331
tlow98
Drives: 2009 E91, 2014 F15 x35i
Originally Posted by Eurogreek View Post
Where do you buy createc? Do you just add it into the oil? I tired of the dealer telling me it’s normal noise.
Thanks
Amazon. Pour bottle into oil inlet.
That’s it.
      10-09-2023, 08:52 PM   #332
Eurogreek
Drives: BMW X5 3.5
Thank you……. Do you just put the whole bottle in?
      10-09-2023, 09:04 PM   #333
BeachsideF30
Drives: E90--> E92-->F30
My local advanced autoparts had a couple bottles on the shelf. I added the whole bottle in a day or two after a fresh oil change at the dealer. I’ve always been hesitant of any additives, but to be frank I was just so over the embarrassment of the noise. I did a ton of research on it and found guys putting it in brand new cars. BMW’s/porsche etc. with good results. decided to give, it’s also popular in the 5.0 mustang community too.
Do I know what it’s making more quiet? Not at all. All I know is I didn’t hear the tick under load this weekend fully warmed up with the windows down.
      10-10-2023, 12:43 AM   #334
tlow98
Technically you should use 391ml of ceratec to achieve the 6% recommendation advised by liqui moly. This would be ~ 1 1/3 bottles. I only did one. I’ll prolly buy another to have on hand anyway and drop another ~100ml in.
      10-13-2023, 09:54 AM   #335
toneatles
Drives: 2011 328xi
Should ceratec be added only after a fresh oil change? I got a oil change back in August so less than 2 months ago.
      10-13-2023, 02:52 PM   #336
BeachsideF30
That I don’t know I just saw everyone doing it after a new oil change, some did it in conjunction with the engine flush for best results. Maybe email liqui moly and ask
      10-14-2023, 04:15 PM   #337
tonyec7
Drives: 228i M Sport
I listed to the user above recommending the additive to get rid of the noise and it worked! It was so embarrassing driving around with the noise. Only put one bottle in and that was enough to make the noise go away.
      10-15-2023, 08:22 PM   #338
Eurogreek
Drives: BMW X5 3.5
I just added a can of Ceratec. Not sure if it’s in my mind but the ticking noise is not there. I drove it for about 10 miles. Not even sure if it would make a difference that fast. We’ll see tomorrow as I will be driving more. I will keep everyone updated. If it does work, what would this stuff do to correct the ticking noise. What is it masking?
      10-15-2023, 09:33 PM   #339
tlow98
If we knew, we wouldn’t be shooting from the hip with additives.
      10-15-2023, 09:53 PM   #340
Eurogreek
Drives: BMW X5 3.5
lol… true
      10-16-2023, 07:41 AM   #341
Monkeypoop
39
Drives: 2017 Bmw X5 sDrive
Here is a recent (year ago) video explaining exactly what I have been doing before I even knew it was an concern for the BMW or owned one. Used to do this on my 09 Infiniti G37 to help. I had severe lifter tapping... I do make sure to flush every other oil change as apart of routine. Probably been posted before, but just figured it may help:
https://youtu.be/j7T0FJ2LM7g?si=i6W0QdSf_zepjTlq
      10-16-2023, 02:43 PM   #342
BeachsideF30
Its not in your head my noise is gone too, wish I knew what it was masking but then again maybe not since its internal lol
      10-16-2023, 03:28 PM   #343
tlow98
So, mine came back, but to a lesser degree.
Further reading on Ceratec says you can use 1 bottle of ceratec per 3-5liters of oil. Which means for 6.5 liters of oil in our cars you can use anywhere from 1.33 - 2.1 ish bottles of ceratec.
I added another 2/3rds of a bottle. Noise went away again.
I’ll update here if it stays away.
      10-21-2023, 10:42 AM   #344
Ascotgrun
Drives: X5
http://https://youtube.com/shorts/3O9rbPOSPR0?si=oPBc9yMXIz-Dd-Lb
Is this sound similar to what some of you are experiencing?. I get this noise from the top of the engine. Obviously it's more pronounced with the hood open and the engine cover removed but it is still audible with everything in place and standing at the passenger side front which is where the turbo wastegate would be loudest.
      10-21-2023, 06:10 PM   #345
BeachsideF30
Originally Posted by Ascotgrun View Post
http://https://youtube.com/shorts/3O9rbPOSP...Bc9yMXIz-Dd-Lb
No, this is a distinct rattle under load and low rpm. What you hear is normal valve and lifter tick that the n55 has. It’s not the best sounding motor at idle with the hood up and the covers off
      10-22-2023, 09:41 PM   #346
Ascotgrun
Drives: X5
Ok, thanks. I may still try Ceratec out of curiosity.
      01-04-2024, 08:17 AM   #347
irzayev
Drives: BMW X5 F15
Hi everyone,
Ceratec fixed the sound, but today I changed my OIL after 5000km without ceratec.
Sound came back =(
Any ideas what is the root cause of sound?
      01-19-2024, 11:50 AM   #348
Bomzara
BMW Fan
Ukraine
6
Drives: F15 35iX
Just pour another bottle in
Nope We've been trying to spot the issue for 3 years here with no luck so far. Some harmonic resonance somewhere in the engine...
      03-01-2024, 11:26 PM   #349
jamal.is.in@gmail.com
Drives: F15 BMW X5 Sdrive35i, M Sport
I found the waste gate flap to ewg connector is loose and it is rattling. Marked with red in picture.
Is it normal ? I suspect this could be the reason.
Also, does the flap connector moves in/out while you push and pull ? Marked with blue in the picture.
      03-17-2024, 08:35 PM   #350
EnzoCali
Drives: X5 F15, 535 F10
Originally Posted by acarr6 View Post
Yep, so dumb. Ended up selling it anyways, bought a G05. The B58 is awesome
that's probably the best way to get rid of it. sell the shit.
      03-17-2024, 08:53 PM   #351
EnzoCali
you can check my post on wastegate rattle fix. i kinda does help but i'm not sure that's the ultimate solution.
      03-30-2024, 09:39 AM   #352
irzayev
Drives: BMW X5 F15
Ceratec fixes the issue so its not waste gate ticking noise =)
