      03-18-2018, 09:35 AM   #4049
RajX5
Drives: X5
Hi Shawn,
Can I get link for latest coding software?
      03-18-2018, 09:44 AM   #4050
shawnsheridan
shawnsheridan's Avatar
Originally Posted by RajX5 View Post
Hi Shawn,
PM sent.
      03-18-2018, 09:55 AM   #4051
RajX5
Drives: X5
Originally Posted by shawnsheridan View Post
PM sent.
Thank you Shawn
      03-18-2018, 10:02 AM   #4052
Juane
Drives: X5 40d
From Argentina
Hi, I m Juan from Argentina. I buyed a 2018 X5 40d.
I would like to change any codes (bimmercode app) and my first doubt is: My x5 has iDrive 5 with touchscreen without Apple Car so I would like to change Idrive 5 to 6.
What do you recommended? First change iDrive 5 to 6 and then download apple car? or do on the contrary?
Apple Car is not available in Arg, so i trying to do with a UK address.
Sorry for my English!
Thanks! Juan.
      03-18-2018, 10:09 AM   #4053
shawnsheridan
Thanks! Juan.
Download CarPlay? If you do not have CarPlay from factory, you must purchase it via ConnectedDrive portal, and if not possible in portal, then you must get a 143 FSC Code solution and coding.
      03-20-2018, 08:07 AM   #4054
btm76
Drives: X5 F15
hi. i have X5 F15 2014 year,America.I want to change xenon (S522)+AHL(S524) on LED Adaptiv Europa,
bought and set the lights,
extended the wires according to the scheme "newtis",has changed SZL with function 5AC.
Of FA removed S522,S524,S8S4
added S552,S5AC
i have :ENET+ E-SYS+ISTA-D
please tell me which blocks and how to encode if possible in detail
      03-20-2018, 10:45 AM   #4055
kariem
Egypt
4
Drives: 2018 X5 x50i M Kit
Exclamation Dealer Problem
Hi guys,
Just got from the dealer today with a problem, I purchased the M performance brake kit part #34112348054, after installation they said they couldn't code the kit to the car, i had previously added TPMS, do I just remove the VO coding and that should fix the problem ?
They said I need to return the car to it's original setting, or I have to VO code all modules !!!
This was done on 2018 X5 50i
Just found the coding steps, apparently they found a conflict between factory FO and current FO so they just panicked and refused to code it !
They actually refitted the original brakes back on and said they won't release the car with the M brake kit !! I have to reset the FO, take the car back to them, remove the original brakes again and refit the M brakes again !
One more thing, hoe come E-sys I'm using only shows numbers under the vehicle profile folder list, I'm using launcher premium v2.8 ??
      03-20-2018, 08:48 PM   #4056
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
Any idea how to code the rear turn signal behave like the Audi. Instead of the entire lamp blinking it would start with the LED closest to the license plate then move towards the outside then starts again, you know what I mean right.
      03-21-2018, 12:20 AM   #4057
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
added S552,S5AC
Read ECU and see if any of light modules are missing CAFD. If they are, injet one. If that fails, you must flash program.
VO code BDC Body, FLA or KAFAS, and Both LHM/TMS or FLE.
Then, use ISTA+ to initialize.
      03-21-2018, 08:20 AM   #4058
yura79
Belarus
Drives: BMW F15 35dx '2015
This is my brother's car.
My actions:
1. Stretched to every 1 power wire to the headlamp from the front (to the left of Faro) and back (right headlamp) Toko-distributor
2. Changed under the Steering switch to European auto-far
3. Changed configuration: via VO Coding removed from FA 522, 524, 5a1, 8s4 Added 552, 5ac
lamp not earned
Сoding:
4. TMS units appeared and LHM, for which use the ' Detect CAF for SWE ' added for:
(41) TMS_L cafd_00001082_032_001_000 (f025-15-11-505)
(42) TMS_R cafd_00001083_032_001_000 (f025-15-11-505)
(43) LHM_L cafd_000010ba_001_008_051 (f025-17-11-520)
(44) LHM_R cafd_000016bf_001_008_051 (f025-17-11-520)
VO code: BDC_Body, KAFAS2, (41) TMS, (42) TMS, (43) LHM, (44) LHM
Earned middle, ring and turn signals do not work-
- LHM_L and LHM_R blocks the error disappeared, but the STML and STMR stayed
- Initialization using Ista+ does not pass, writes-coding error
Not initialize when performing service function error-programming interrupted with error.
When bought headlights, new seller said.
??? I can break both modules if I connected LAE headlights instead of xenon without changing the wiring and changing the FA ???
I came across such a description on one of the forums:
When you completed the manual work remember to NOT INSTALL THE LED HEADLIGHT BEFORE HAVE CODED FA (Veichle Order) AND FRM ECU.
This step is FUNDAMENTAL, because FRM send different signals to headlights depending of the configuration, if you install LED but the car and FRM is coded for xenon simply you risk to burn your thousand € or $ headlight!!!!)
http://f10.5post.com/forums/showthread.php?t=1355907
please somebody, if possible for more details where and what to fix?
      03-21-2018, 09:28 PM   #4059
Almaretto
Almaretto's Avatar
2374
If you do not install hardware, I am not sure what you would be VO coding. Other than that, I am not sure how to help.
Hopefully someone else can chime in.
      03-22-2018, 06:41 AM   #4060
Crasherr
Drives: 2018 F15, 2024 G80
Shawn, is v.63.3_PSdZData_Lite still the latest version?
      03-22-2018, 07:04 AM   #4061
shawnsheridan
No. v.4.10.21 is.
      03-22-2018, 08:27 AM   #4062
yura79
Belarus
Maybe I need to encode (Fdl coding) some values ​​in ecu (41/42)TMS or BDC?
(tms_type, tms_variant, tms_id.....)???
      03-22-2018, 02:07 PM   #4063
Crasherr
Shawn, can I get the latest link? My X5 is being built right now.
      03-22-2018, 03:00 PM   #4064
shawnsheridan
PM sent.
      03-23-2018, 07:33 AM   #4065
Audiocracy
Drives: X5
Hey Shawn,
Can I get the link to the coding software? Thanks!
      03-24-2018, 02:49 AM   #4066
javaperson
Drives: 2021 G05 X5
Hi Shawn,
Can I get a link to the latest software and psdz-data files? Thanks!
      03-24-2018, 06:04 AM   #4067
Almaretto
Almaretto's Avatar
2374
Originally Posted by Audiocracy View Post
Hey Shawn,
Originally Posted by javaperson View Post
Hi Shawn,
Check here.
      03-24-2018, 09:48 AM   #4068
shawnsheridan
Hey Shawn,
Hi Shawn,
PM's sent.
      03-24-2018, 03:47 PM   #4069
MachineYOO
Drives: BMW X5 F15 35i Xdrive
Hello. Can you please tell me if it's possible to coding a digital instrument cluster (6WB) , so that at night it is in day mode? That is, to keep it white, not red. The red is just awful, like a 2000 car and I work as a taxi driver.
Screen white:
Screen red:
I'm sure this can be done by coding, as it changes depending on the lighting on the street. That is, the light sensor somewhere makes 6WB change color.
      03-24-2018, 07:52 PM   #4070
fromkrypton
Drives: 2015 X5 35d
2015 BMW X5 35d  [0.00]
Possible to get the latest coding software?
Thanks in advance!
