11-03-2015, 11:26 PM | #1850 |
Rep 265
The minute you do some spirited driving on a windy back road your headlights will flash and you will get errors on the dash. Turn it off.
11-04-2015, 05:39 AM | #1851 |
Rep 7
Because my girlfriend has been bored by the Orange Ambient Light, and Blue was allready reserved by my Key
I've coded a new Ambient Light Color: BDC_BODY -> GROUP_0_FARBE_ENSEMBLE_1 -> Default Value=orange -> New Value=weiss BDC_BODY -> AMBIENTE_FARBE_ENSEMBLE_1_LAYER_1 -> Default Value=orange -> New Value=violett BDC_BODY -> AMBIENTE_FARBE_ENSEMBLE_1_LAYER_2 -> Default Value=orange -> New Value=violett Works fine! There are other colors available... |
11-04-2015, 07:57 AM | #1852 |
Rep 136
@skalberti, shawnsheridan told me engine running is completely fine as long as you're not doing any DME changes. Also, he said all of the coding that is in r33's cheat sheet does not require much power so it's ok to code those with AC on only. Based on this, I have never had any issues coding with engine on or AC on.[/QUOTE]
Guys I have searched but cannot find a clear answer is it ok to have the engine running or not when coding? |
11-04-2015, 08:00 AM | #1853 | |
Rep 8,815
What other colors are available?
11-04-2015, 08:59 AM | #1855 |
Rep 7
Just out of my head I only remember "pink" & "green"
Also "iceblue", but this could be "normal" blue which is selectable thru menu as well. There is also a code "AMBIENTE_RGB_LAUFLICHT_BEI_TUEROEFFNEN" (Ambiente lights in sequence when door is open) - but I didn't see any effect. |
11-04-2015, 05:50 PM | #1856 |
Rep 16
I try to start coding the first time today on my F15. I got to Coding step 8 to right click on BDC_BODY CAFD and select "Read coding data", but the following error shows. What did I do wrong? I'm using E-Sys version 3.26.1
Transaktions-Report: Aktion: Codierdaten lesen BDC_BODY [40] [0P09368] readCPS o.k. CAFD_000017BE_005_031_151 Fehler: File for "cafd_000017be-005_031_151" not found! [C012] |
11-04-2015, 05:57 PM | #1857 |
Rep 226
Hi All,
Is there any codes to have the headlights and foglights turn on when the car is unlocked? I can't find my previous sheets for my X3 that had this coding. I'm curious to see if this would work on the F15. Can I also have all the latest psd files and essays files. |
11-04-2015, 06:10 PM | #1858 | |
Rep 968
11-04-2015, 08:38 PM | #1859 | |
Rep 40,789
PM sent.
11-05-2015, 04:27 AM | #1860 |
Rep 299
Drives: F15 2015 X5 40D M Sport
Could i please get a copy of the latest software please
Current 2015 F15 X5 40D M sport
Gone X5 E70 4.0D M Sport Gone 335D E92 M Sport |
11-05-2015, 05:07 AM | #1861 |
Rep 40,789
11-05-2015, 05:23 PM | #1862 |
Rep 812
In the MY2014 F15 X5, Navigation is not in the standard configuration and part of the Premium Package instead. However the 10" LCD display is part of the standard configuration. Does this mean that retrofitting Navigation in is just a matter of coding? Thanks!
Ground Control Camber Plates, Ferrodo D2500 w/ E86 MZ4 2 piece rotors, Dunlop Direzza ZII on Apex EC-7s
11-05-2015, 05:27 PM | #1863 | |
Rep 40,789
11-05-2015, 11:09 PM | #1864 |
Rep 137
Front camera on?
Hi all,
Ordered my 2015 50i M-sport, should be here next week, but was lurking on the forums for about a month or so. Have a coding question: I see a lot of you are coding front camera to be on while driving - what is the use of that? I mean I can understand if we could record what it shows, but just to watch what's going on on a screen while driving dont bash newb |
11-06-2015, 07:00 AM | #1865 |
Rep 136
Guys can someone try to help me please, I cant get a network connection between my 2014 F15 (UK based) and laptop, little yellow triangle appears on available networks. Tried a couple of laptops same problem, so could it be the vehicle?. Its seeing the network but is throwing up a "Ethernet does not have a valid IP configuration". Thanks in advance for any help its driving me nuts. Have loaded Eysys etc. so all ready to code but cant get a network connection.
11-06-2015, 11:57 AM | #1866 | |
Rep 136
11-06-2015, 12:00 PM | #1867 | |
Rep 40,789
11-06-2015, 04:40 PM | #1868 | |
Rep 136
11-06-2015, 06:01 PM | #1869 |
Rep 40,789
What is the exact E-Sys Data path set for under E-Sys Options?
11-07-2015, 06:25 AM | #1870 | |
Rep 37
