04-30-2019, 09:58 AM | #1 |
Rep 22
Hey y'all. '18 50i. Every time I go through the car wash, the dryer blowers open the fuel door. Sometimes aggressively and it slams shut. Other times I need to close it myself. I've tried locking from the inside door and from the key fob (with me inside). The fuel door does lock with the normal park and lock routine. Suggestions? Thanks
04-30-2019, 10:41 AM | #2 |
<3 Flat Four
217
Rep 754
mine does the same thing, gets blown open from drive through car washes. i believe it only locks when the vehicle is off.
2011 335is Le Mans Blue
05-02-2019, 10:30 AM | #3 |
Rep 7,489
Interesting...all the BMWs I've owned, the fuel door was under some type of tension from a spring/clip designed into the fuel door flap hinge. Is your flap "loose" or does it still have tension when trying to open it?
My f06 is the 1st of my BMWs where the fuel flap operates slightly different...it requires pressing down on the left side, and it pops the flap open. All the previous models you'd press on the right side of the flap to open it. {e53 X5 - press on the right side} {e38/e39 - press on the right side} {f06 6GC - press on the left side} The central locking system only locks the fuel filler flap when you use the remote fob or the driver's exterior door lock cylinder. Using the central locking button inside the car doesn't lock the fuel filler door. This is to allow a fuel attendant (in states or countries that still have them) to access and refuel your vehicle while you and your occupants can remain safe & secure inside the vehicle.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 05-02-2019 at 10:51 AM.. |
05-05-2019, 02:58 AM | #4 | |
Rep 272
It's odd the there is no actual latch holding it closed when the car is unlocked with ours. |
05-05-2019, 07:37 PM | #5 | ||
Rep 22
