11-12-2017, 04:42 PM | #2 |
Rep 18,716
Use OEM. It is special blend made for BMW.
11-12-2017, 06:02 PM | #3 |
Rep 2,388
I assume you are under warranty still? Then just let BMW dealer replace it. I would highly recommend doing a oil change in between BMW dealer visits. That way you can cut down interval by half. I would never do this for any other engine, but 50i will benefit from it (and valve stem seals will thank you too). Our engines (n63tu) are a known oil killers and oil change interval is critical. Ideally 5k interval is best. I know people who change oil every 4k even - but they are in NYC in stop-n-Go traffic constantly including cold winter starts with car parked outside etc. For normal usage 5-6k interval should be fine.
I would go with LL-01 oil (there are several out there) that has either ester base or even better alkylated naphthalene: 1. Red Line 0w-40 (this is the best there is IMHO) 2. Castrol 0w-40 (good old tried and true) This is all just my subjective opinion (but based on countless research regarding our n63tu engine issues) |
Stev_chu108.00 Teufelshund152.50 |
11-12-2017, 06:07 PM | #4 | |
Rep 177
11-12-2017, 08:58 PM | #5 | |
Rep 2,388
50i is a high-performance engine by BMW classification (that is what number "3" stands for in engine code) and is twin-turbo and direct injection - all this makes it sensitive to oil and fuel - there's nothing else that cleans and lubricates internals - only oil and fuel Additives in oil and in general ability of oil to properly lubricate engine deteriorates with heat and time. 50i is a high temperature loaded engine - it can destroy oil faster than other engines and bad things will follow. Previous engines like n62 and partially n63 had rod bearings issue - expensive to fix. Valve stem seals issue is another example of expensive repair. Majority of this issues were due to not adequate oil supply and/or oil that was not lubricating internals as it was intended. Frequent oil changes guarantee fresh oil and additives to rejuvenate seals and lubricate everything properly. It's a lot cheaper than dealing with issues down the road - this is the only reason I do my oil changes twice as frequently as BMW maintenance schedule requires. It's worth mentioning here that n63tu engine design has a 2 huge cats positioned right behind the turbos at the back of engine. Distance from cats to valves is like couple inches! Heat from those cats is around 750F at idle and 1300F at spirited driving I'm not an expert and once again this is just my opinion. You can read about n63tu engine and make your own conclusions To sum up - it's not necessarily performance that we are looking in oil, but a longer life of engine imho (to answer your question - in terms of performance you won't notice difference between a good and so-so oil) With that been said LL-01 oil like a Castrol 0w-40 is a good starting point This is the oil filter wrench you'll need: https://www.amazon.com/gp/product/B0...ilpage_o04_s00 This is oil filter Mann (IMHO the best filter): https://www.bavauto.com/catalog/prod...ive50i-4516130 This is the Castrol 0w-40 oil that I use (you'll need 2 jags of it since 50i takes 9.5L of oil with filter change): https://www.amazon.com/Castrol-03101...=castrol+0w-40 As you can see it comes to total: around $80 + tool you'll buy one time. It's fairly simple to change oil on 50i: both filter and oil drain plug are under the engine easily accessible if you are up to a DIY. IMHO it's a small price to pay for longevity of your engine (price for used complete n63tu engine alone without swap labor is north of $14k and new one from BMW is just ridiculous price) Last edited by DuSh; 11-12-2017 at 09:25 PM.. |
4
11-13-2017, 08:17 AM | #6 |
Rep 7,160
any thoughts on Mobil 0w-40? I used that religously on my AMG and never had a single issue through 130k miles. it is what AMG recommended at the start but then moved to cheaper standard 5w-20 blends (but pretty sure that was more a dealership thing than anything from AMG) I also did every one of my oil changes myself at 7k mile intervals.
11-13-2017, 11:36 AM | #7 | |
Rep 2,388
11-13-2017, 12:21 PM | #8 | ||
Rep 177
11-13-2017, 02:50 PM | #11 | ||
Rep 177
DuSh2113.50 |
11-28-2017, 05:27 PM | #12 |
Rep 299
Drives: 2022 X3MC BSM/SO
11-28-2017, 06:02 PM | #13 |
1636
Rep 2,995
i doubt mobil changed its formulation. bmw probably changed their LL-01 specs. or it probably has to do with bmw switching from castrol to shell/penzoil for their oil supplier.
11-28-2017, 06:43 PM | #14 |
Self-Deprecating Narcissist
7266
Rep 6,561
OEM BMW TT 0w30 as stated on the vehicle in the engine bay.
11-28-2017, 11:33 PM | #15 |
Rep 2,388
That's an excellent oil too. It's a Shell oil based on GTL oils and their Infinium line. Oil analysis (on oilclub forums) yielded very good results (which is not always the case with OEM)
The only downside is that it's more expensive (for what it is - a re-branded Shell oil with a BMW luxury tax), but for someone on free maintenance plan - it's excellent! Just my opinion |
Stev_chu108.00 |
11-29-2017, 07:19 AM | #16 |
7266
Rep 6,561
I purchase a few just to have on hand if I ever need one but I also use Shell Helix 10w60 for the E46 M3 and Rotella for other applications. I used to purchase Castrol Edge (EF) which is not available in the US and worth every penny to me. Maintenance plan alone is not the reason I go with it since I purchase Shell for my other vehicles.
DuSh2113.50 |
11-27-2018, 10:23 PM | #17 | |
Rep 177
11-28-2018, 12:31 AM | #18 |
1636
Rep 2,995
walmart sells castrol 0w-40 european oil. meets bmw spec.
$25 for 5qt jug. but $8 if you buy single quarts... https://www.walmart.com/ip/Castrol-E...-5-QT/35931146 |
11-28-2018, 01:59 AM | #19 | |
Rep 177
11-28-2018, 04:26 AM | #20 | |
Rep 535
the winter numbers 0w vs. 5w matter really much below freezing.
Present: 2014 X5 50i
11-28-2018, 01:03 PM | #22 |
1150
Rep 2,426
BMW seems to have changed the oil requirements a bit from 5W30 to 0W30.
I would buy the BMW 0W30 from the dealer if you have a good relationship with the parts department (AKA they can give a good price), otherwise Pennzoil Platinum Euro 5W30 is available on Amazon. https://www.amazon.com/dp/B00ZEK6Z64/ (Current BMW oil is rebranded from Shell Helix Ultra which is sold in the US under the Pennzoil Platinum Euro brand) Just FYI, BMW sells oil in Liters whereas the Pennzoil is sold in Quarts. You need 9 L or 9.5 Qt for one change. Here's the filter if you are looking also: https://www.amazon.com/dp/B00AFVT5OQ/
2015 BMW X5 xDrive50i
BMW CCA 509766 Last edited by alphaod; 11-28-2018 at 01:28 PM.. Reason: Fixed from 5W40 to 0W30 and fixed URL |
DuSh2113.50 |
