11-01-2018, 11:53 AM | #1 |
Rep 178
Chassis Function Restricted Error Code
So I got this message pop up today - Chassis Function Restricted. I am unable to switch through the drive modes.
From what I read it typically has to do with some type of sensor with the front springs. I did have my springs changed out about 3 weeks ago to the ACS kit. I haven't had any issues for over a 1000 miles and now it just popped up. However, I checked my BimmerLink App and it is throwing code FF1800, but there is no description for the code other than it is under an engine issue. Anyone experience this? Did you have to go to the dealer to have it cleared? Anyone get this after a suspension drop? Thanks, Joe |
11-01-2018, 12:02 PM | #2 |
Rep 18,717
If you have EDC/DDC/VDC, check the connectors and wires.
Maybe the connectors came loose or wires got cut.
11-01-2018, 02:13 PM | #3 | |
Rep 178
I've seen some posts about checking the accelerometer sensor on other model forums. Are these the same sensors your are referring to? Thanks, Joe. |
r33_RGSport12971.00 |
11-01-2018, 02:18 PM | #4 | |
Rep 18,717
Check on those connectors. Those connectors connected to the accelerometer. 1 sensor per strut.
11-02-2018, 11:27 AM | #5 | |
Rep 178
I am going to pull the tires this weekend and check the sensors to make sure everything is plugged in and tight and nothing had been cut. Should I disconnect the batter before unplugging any of them? Here is an image of some of the errors I pulled on BimmerLink that appears to deal with the driving dynamics. Is there any way to pinpoint with sensor or at least wheel location that is causing the error. Does anything stand out to you based upon these codes? |
11-02-2018, 11:33 AM | #6 | |
Rep 18,717
Also, your picture not showing up. Why don't you email me, bchen@rgsport.com
11-04-2018, 02:15 PM | #7 | |
Rep 178
Thanks for your responses on this Ben. I took off all the wheel today and found the culprit. Lesson learned. Not a good idea to drive without the exhaust tips on. Have them out being re powder coated now as the first time they were coated, they didn’t sandblast them enough and they peeled in a small section. Anyways since they were off, all the heat coming straight out of the muffler melted one of the rear wires that controls the ECD. Patched the wires up and as good as new. |
11-04-2018, 02:19 PM | #8 | ||
Rep 18,717
Lucky you didn't melt the whole car.
JWK170200.00 |
11-05-2018, 07:28 AM | #9 |
Rep 178
Damn lucky. The heat also got to my painted rear reflectors I bought from you. Tabs warped and cracked so they were ready to fall out. I did a lil JB Weld work on the tabs to see if I could get them back into place last night. See if it works. If not I will be in the market for some new ones from you.
Luckily the wires weren't too bad that they just needed separated and reinsulated. A lil tape and good as new. |
04-13-2020, 07:10 PM | #10 | |
Rep 10
Question, where are these sensors located? One on each side behind air strut? |
04-14-2020, 03:18 PM | #11 |
Rep 2,511
04-22-2020, 06:41 AM | #12 |
Rep 157
Just an FYI to anyone finding this thread in the future; I got this same warning after my recent wheel/tire changeover from winter to summers, and it went away after a few drive cycles. Probably had something to do with the way they jacked the vehicle up. No cause for alarm I think.
04-26-2020, 12:03 AM | #13 | |
Rep 5
Scared the crap out of me as when I bought my x5 (used) I had the same problem, although that time it was actually due to the speed sensor wire being broken. |
11-23-2022, 10:33 PM | #14 |
Rep 15
seeking help
have a new to me 2017 xdrive 35i F15 (with 100k kms mileage)and have been getting this fault intermittently, rear shocks were leaking so got them replaced ($3k!) - since then i have had a new issue - traction control coming on aggressively at moderate speeds and loads but only when turning to the left and when the side of the car loads up under cornering. the traction control intervention is very abrupt and applies the brakes very aggressively.
SO... advice from the tech was to change the front struts too (another $2k!) - but the car displays the same issues and there are no other codes according to the tech. after forum research i found a post suggesting to update the software and reflash the vertical accelerometers - so we did that - and no change. The tech is now sayin i need to replace all 4 accelerometers at a cost of aanother $3k - i am hesitant to say the least - can any of you smart and experienced folks help give me any clues as to any other fault finding i can do rather than just keep firing the parts cannon st this car? thanks |
