      05-01-2020, 07:08 PM   #1
Queenzlegend
Queenzlegend's Avatar
Drives: 2015 BMW X5
2015 Bmw  [0.00]
Rear Suspension air keeping dropping
My rear suspension keeps dropping randomly sometimes it would stay up for 3 weeks. Some days it drops. Early in the morning it rises back up.
      05-01-2020, 07:51 PM   #2
ponytuning
122
Drives: '16 F16 50i, 15' F15 50i
See this https://f15.bimmerpost.com/forums/sh....php?t=1699210
      05-01-2020, 07:52 PM   #3
SPSE93
SPSE93's Avatar
113
Drives: 335i
Comman problem, the rear air bags need to be replaced. Dont drive the car like that, otherwise you can damage the rear shocks.
      05-02-2020, 11:50 AM   #4
chumbedi
Drives: BMW X5e40 (F15)
Check fuse (maybe loose connection) / check airbags, valves and air lines for leakage (spray soap water)/ since problems are random check air dryer at compressor, incase desiccant silica beads are moist could be faulty rubber seal at solenoid valve which controls venting.
But don't drive too long with that problem, you can damage the air compressor and that will be costly
      05-04-2020, 09:33 AM   #5
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Order the bags from FCP Euro 350 for the set.
Get halfway up on ramps.
Remove the pump fuse
Take the paneling off the bottom of the truck, under the passengers side.
loosen the valves at the block bleed the bags, you'll see a blue and red tube connected to the block with gold fittings.
Get your jack on the diff pumpkin (i use a piece of wide flat wood to stop metal on metal damage) and lift the truck off the ramps, then install your stands on the jack point in front of the rear wheels.
Drop the car onto the stands. I usually rest the jack under the diff just in case.
Once bled, spin the bags out and remove the air supply tube 10mm wrench.
You can transfer the dust cap over from the old bags at this point.
Insert the air lines into the new fittings, no need to use the old fittings and reinstall the bags on the top side by spinning them into place.
Pull the bag down as far as you can and then lift the hub to meet the underside of the air shock to the suspension arm, you can use a spare jack or just life by hand.
once clipped in, bolt everything up, jack the car up, install the wheel and lower the truck onto the ramps. Tighten the fittings on the block, install the fuse, turn on the car and check for leaks on the valve block. Once confirmed good, button up the under paneling and then drive off the ramps.
You're done.
      05-04-2020, 10:30 AM   #6
feven1026
feven1026's Avatar
Drives: 2014 BMW X5 50i
mine died around 120K. get both air bags changed.
VERY common on F15, i personally consider air bag is wear and tear parts.
      05-04-2020, 11:22 AM   #7
Alex Morgan
Drives: BMW X5 F15 (2014)
Hello,
I've had the same problem
I found this clip on You Tube
I've not got round to investigating it further - but it might help
      05-19-2020, 09:19 PM   #8
Queenzlegend
Drives: 2015 BMW X5
2015 Bmw  [0.00]
I contacted bmw North America they may fix my airbag issues. I have to get new diagnostic done and then submit all documents.
      04-29-2022, 12:26 PM   #9
amw111
Drives: BMW x5 2016, edrive40
Question Did it end up working?
Did the new air bags work out?
I think I have a similar issue - fuses are all good (also no warning in the dashboard / boardcomputer). Very rarely the rear sags down and when I drive the car gets bouncy in the back (without driving over any bumps).
Usually, when I just turn off the car, lock it, and then turn it back on it adjusts itself.
Does that sound like the air bags need to be replaced?
Hitting 60k miles soon
      05-01-2022, 02:44 AM   #10
acmurda
Drives: 08 e92 m3
Just change the bags and be done with it. 99% of the time is cracked/Leaky airbags and to the ones that say "no I don't see any crack in mine".... trust me take em out and you'll see. Replace with the Arnott bags and you're done. Takes $350 and less than an hour to diy rather than trying to diagnose other things that may be the other 1%
      05-01-2022, 02:45 AM   #11
acmurda
Drives: 08 e92 m3
Yes 💯 its the bags. The system should not deflate on its own in any condition.
      05-03-2022, 10:46 PM   #12
Linux200
Linux200's Avatar
Algeria
Drives: f15 sdrive
2015 2015  [0.00]
I think I have a similar probleme cry
      05-03-2022, 11:39 PM   #13
Linux200
Linux200's Avatar
Algeria
Drives: f15 sdrive
2015 2015  [0.00]
Lightbulb
Originally Posted by Alex Morgan View Post
Hello,
great video thanks
