12-27-2016, 02:46 AM | #3015 | |
Rep 30
I'll check the codes mentioned in the post to see whether I can find a hint. |
12-27-2016, 02:24 PM | #3016 |
Rep 8,364
Maybe I misunderstood for what you are looking. LIM function is set by user. The same codes will also allow user to disable distance component of ACC+ for recular DCC.
12-27-2016, 04:35 PM | #3017 |
Rep 592
@karoshi
from the X1 thread you posted, is this what you are trying to achieve for your Euro Spec F15? .... " You have to have the limiter activated. Say, you're doing 30mph with the limiter. Camera detects that you are approaching a 50mph zone. Once you're passed the traffic sign, you should see the new sign readout on HUD with an arrow pointing upwards right next to it. The arrow stays there for a few seconds. Press and scroll up while the arrow is shows and limiter jumps to 50mph from 30. You won't have to hold the rocker to reach 50mph manually....." |
12-27-2016, 05:23 PM | #3018 |
Rep 8,364
I re-read thread. It sounds like speeds adjustments are only suggestions and appear briefly; driver must decide to toggle change with rocker switch. I never use the limiter function so I have not tested if additional coding is required to enable function.
12-28-2016, 02:42 AM | #3019 | |
Rep 30
12-31-2016, 01:17 AM | #3020 |
Rep 8,364
I went ahead and tested my system today and it never suggested adjustments. There must be additional FDL's required. I always thought LIM function was rather limited in functionality (pun intended). I still do not really think I would use feature, but this would make system more useful.
01-01-2017, 06:10 AM | #3021 | |
Rep 458
I bought and installed huf tire sensors sensors for winter and have the vdo for summers. |
01-03-2017, 02:30 PM | #3023 |
Rep 40,774
01-03-2017, 09:38 PM | #3024 |
Rep 4
Thanks.
I was successfully able to code most of options in cheat sheets 6 months back. Dealer updated firmware in my car(X5 F15) last week when I went for first service, for installing MPPK. Now am not able to see options listed under BDC_BODY. I selected the correct series, still BDC_BODY module is getting loaded with only ..... Can someone please update me on how to resolve this issue. Please find the screen shots attached |
01-03-2017, 09:41 PM | #3025 | |
Rep 40,774
Also, "Read Parameters from VCM" should not be checked, and "Series, I-Step Shipment" should be blank.
01-04-2017, 02:03 PM | #3028 | |
Rep 592
01-04-2017, 08:00 PM | #3031 | ||
Rep 8,364
PM Sent |
01-04-2017, 08:59 PM | #3032 |
Rep 591
Quick question, my headlights (not DRL) seem to be always on even when the sun is out. I don't believe it's always been that way but I just noticed it today. I've done some coding but I remember it working correctly after coding the halos to be 100% all the time. Any ideas?
01-04-2017, 09:31 PM | #3033 | |
Rep 592
01-04-2017, 09:33 PM | #3034 | ||
Rep 591
01-05-2017, 12:07 AM | #3036 | |
Rep 8,364
Neuera09278.50 |
