04-12-2016, 05:05 PM | #1 |
Rep 234
Drives: 2022 M5C /// 2023 XDrive40i
Dimensions and Weight of Staggered Wheels & Tires
Would anyone know - through prior experience, maybe - of the dimensions and weight of a 20 inch wheel and tire (mounted), for both the front and rear on an OEM staggered setup for the F15?
I'm trying to determine shipping, but really need this info. Much appreciated. |
04-12-2016, 08:45 PM | #2 |
Self-Deprecating Narcissist
7266
Rep 6,561
469M wheels without tires weigh 35.25 front each, 37.50 rear each. 30lbs for front tire and 35lbs rear. I would overestimate a shipping weight of 85lbs per corner for packing material, wheels, tires and inflation.
04-12-2016, 11:37 PM | #3 |
Rep 234
04-13-2016, 07:56 AM | #4 |
7266
Rep 6,561
no problem. good luck with the shipping let me know how much it comes out to after everything is said and done. (if you can ship freight on a pallet it is the cheapest and safest but it must go to a commercial address otherwise UPS will be your best option for the lowest price. USPS have a 70lb limit per item shipped so it is not an option at this point.)
04-13-2016, 03:20 PM | #5 |
Rep 234
I found that busfreighter.com (Greyhound), is coming out to $200, based on your info above, and assuming total diameter (length / width) is 28-30 inches. So not bad, unless UPS is cheaper, but I doubt it at this point.
04-13-2016, 05:08 PM | #6 |
7266
Rep 6,561
i would wager ups being somewhere in the $350 area before insurance and taxes in your area.
