05-10-2018, 10:29 AM | #1 |
Rep 21
Hitch - Factory versus Stealth
I have been reading threads in here for a while on hitch options for my 2015 X5 with M sport package. I have narrowed it down to the factory or Execuhitch or Stealth Hitch options. I like the factory option as I can get the hitch first and install the wiring and controller later (as I plan to use it for a bicycle carrier initially). This appears to be the full list I'd need for the factory option:
82 71 2 349 499 - Retrofit kit tow hitch cross tube 82 71 2 349 501 - Retrofit kit tow hitch module Class 3 82 71 2 349 500 - Retrofit kit tow hitch wiring harness 71 60 6 889 589 - Control unit for trailer hitch I can do the first two parts initially and add the last two once I plan to tow. If I did the Execuhitch or Stealth Hitch, I'd get the 2" receiver and the Active wiring harness. Execuhitch offers the OEM harness (harness and control unit I believe), but is Stealth Hitch's active harness actually the factory harness? I can't tell if the Execuhitch option for this model is the automated or the manual version. I like that the Execuhitch and Stealth are pretty invisible, the factory option also appears to be pretty out of the way as well. Pricing is pretty similar overall so that isn't really a factor. Any additional thoughts? Last edited by RDA1; 05-10-2018 at 10:43 AM.. |
05-10-2018, 08:56 PM | #2 | |
Rep 222
When you don't have the receiver connected no one would ever know your SAV can tow ... Which is a good thing. |
05-12-2018, 06:32 AM | #3 |
Rep 102
Drives: 2014 X5 50i M Sport/2016 340XI
I’m extremely happy with the stealth hitch I put on my x5. I have the m sport package and I was concerned I would have to cut the bumper but it fit without issue. It’s also stealth and when the ball is removed completely invisible. The owner Steve was very helpful when I had 20 questions about the install and fitment of the kit and even honored a several months expired $100 off coupon when I asked him for it. Couldn’t be happier. The hitch also fits much tighter than an American style receiver hitch that has a lot of play. It is much quieter than the hitch setup on my prior tow vehicle which was a Jeep Grand Cherokee.
05-15-2018, 01:07 PM | #5 |
Rep 36
RDA1, I have had both hitches the execuhitch on my 2015 X5 Diesel and now a Stealth Hitch on my 2017. I opted for the Stealth Hitch because the receiver is made from stainless steel and should not rust. I had left the drop on the Execuhitch last camping season, at the end of the season it was rusted in and I had to hit it with a hammer to break the surface rust loose.
So I opted for the Stealth Hitch and hopefully will not have the same issue take place. Also when I purchased the 2017, it had a factory hitch on it. I took that off because the locking mechanism looked like it was made of cheap pot metal and I didn't want to lose the trailer if it broke. |
Sedoy680.00 |
05-15-2018, 03:24 PM | #6 | |
Rep 997
What's the towing capacity of Stealth Hitch? I know that Execuhitch can do 7700 lbs.
05-15-2018, 06:43 PM | #7 |
Rep 36
The Stealth Hitch is rated at 7,000 lbs. But personally I would not want to tow over 75% of factory rating due to extra wear and tear on the drive train. Our trailer is about 3,600 lbs loaded. With the new vehicle and the Stealth Hitch it is much more stable. Probably 90% suspension and 10% hitch. I always felt like the Execuhitch drop had some play when under a load.
05-15-2018, 06:48 PM | #8 | |
Rep 36
Sedoy680.00 |
05-16-2018, 09:18 AM | #9 |
Rep 21
05-16-2018, 06:16 PM | #11 | |
Rep 36
Here are the pics of the Stealth Hitch. As you can see the block is stainless steel. I think a good thing that cuts down on rust is the water intrusion protection. The Stealth Hitch uses a molded rubber plug to completely seal the block device and the Invisihitch/Execuhitch used a plastic door that is spring loaded and does not seal the block device allowing water to intrude when driving when drop is not installed. Sorry the pictures are upside down of the block device. Stupid IPhone! |
05-17-2018, 08:31 AM | #13 | |
Rep 21
05-21-2018, 03:41 PM | #14 |
Rep 21
I ended up buying the Stealth Hitch today, thanks for the help all, I'll add more input in this thread if I believe it will help a future buyer choose between the three options.
09-21-2020, 02:00 PM | #15 |
Rep 14
Not trying to bring up an old thread but you both have had the Stealth Hitch for about two years. How have they held up? Any additional comments/recommendations? Looking to add one to by ‘14 X5 for mostly light duty utility trailer for runs to the dump with yard waste and possibly in the future a 12 to 16’ Boat.
TIA! |
09-21-2020, 04:03 PM | #16 | |
Rep 648
My only issue is car washes in the winter, spraying off the underbody, seems to eat the rubber plug. I have lost 2 of them already. The black painted parts have started to show some rust, especially the loops you hooks up the safety chains to. Would be nice if those two loops were made with stainless also... |
