      10-08-2021, 03:22 AM   #1
///M_Martin
///M_Martin's Avatar
74
Drives: F85 X5M Edition Black Fire
Custom exhaust tips on OEM exhaust F85 X5M
Hi there,
Someone was made this mod to exchange the original chrome exhaust tips with some custom options like carbon,power coated black etc. tips with bigger size too?
For this moment i want to keep my OEM exhaust BUT want to put some more bigger and looks better like OEM tips.
Any advise or suggestions
Thank you!
      10-08-2021, 07:45 AM   #2
MBoss_F86
MBoss_F86's Avatar
Drives: 2016 BMW X6M
Not bigger but definitely better looking tips on my F86 stock exhaust. Previous owner did it but it should a simple install. You can get M carbon fiber tips 3" inlet.
      10-08-2021, 09:35 AM   #3
Blue By You
Blue By You's Avatar
631
Drives: 2017 LBB X5M F85
MODE ceramic coated slip-on exhaust tips
Originally Posted by ///M_Martin View Post
Hi there,
Thank you!
I did some research before I bought these black tips from MODE in Australia. Some people had trouble with the regular MODE tips deteriorating from the acids etc in the exhaust. (or something like that) And I saw a message from MODE to one of those owners where they recommended their ceramic coated tips for better longevity.
So anyway, here are the ceramic coated black tips from MODE that I had installed. If you're going for the black theme, they're great because they're a matte finish and any discoloration from the exhaust blends in. They fit great, look great, and seem to be holding up well thus far.
https://modeautoconcepts.com/product...ed-matte-black
      10-08-2021, 10:51 AM   #4
LOW4LYF
LOW4LYF's Avatar
2163
Drives: E92 M3 & F85 X5M
Looks great! Do you have a link?
      10-08-2021, 11:19 AM   #5
Blue By You
631
Ahhh...
Pardon me, I was rushing...
You will see where it says "with slight modification" for the F85 X5M and F86 X6M.
      10-08-2021, 01:34 PM   #6
LOW4LYF
LOW4LYF's Avatar
2163
Thank you
      10-08-2021, 03:00 PM   #7
jab23
224
Drives: 2017 X5M
Here is my origianl post on this...
https://f15.bimmerpost.com/forums/sh....php?t=1770912
If you scroll through, some people found them cheaper at other places other than MODE.
Just FYI, the mouths of mine discolored fairly quickly despite ceramic coating, but overall they still look decent after a year.
      10-08-2021, 03:44 PM   #8
Blue By You
631
Ceramic?
Mine are different than what people were circulating on that post. The ceramic ones are matte and that's what I have. They are supposed to be more durable than the shiny ones, per MODE.
Are yours the ceramic matte ones or the regular shiny ones?
      10-08-2021, 04:51 PM   #9
jab23
224
Drives: 2017 X5M
I bought the gloss ones and ceramic coated them myself. You may only be able to get the matte ones from MODE.
      10-09-2021, 07:14 AM   #10
Klienfeld303
Klienfeld303's Avatar
Drives: 2018 x5 M
CF m power tips. 90mm
ACID.
      10-11-2021, 10:12 AM   #11
///M_Martin
74
Thanks guys for help
I thing all options is very good and need time to decide.
The car is Edition Black Fire and the exhaust tips will be black or carbon
      10-11-2021, 11:20 AM   #12
SLOWER
SLOWER's Avatar
Drives: 2003 M3
What is needed as far as "modification"?
      10-12-2021, 03:58 AM   #13
///M_Martin
74
I thing need to cut the OEM ones and welded or fix with brackets new ones
      10-12-2021, 05:40 AM   #14
Blue By You
631
Minor Modification
The tabs on the new tips just need to be cut and/or bent a certain way then they slip right on with a rubber mallet. No welding. No alteration to stock tips, although they probably get ruined in this process. MODE can send you instructions.
      07-11-2022, 11:15 AM   #15
Da_Meister_22
Da_Meister_22's Avatar
208
Drives: F10 M5 & F85 X5M
How big does the "inlet" need to be to fit the stock muffler of a 2016 F85 X5M?
Would these fit?
https://www.ebay.com/itm/19440584901...3ABFBM9pT2zrxg
AW F10 ///M5
AW F85 X5///M
BootMode3 STG 2///Project-Gamma Intakes///ActiveAutowerke DPs///Maxton-Design Body Kit
@MeisterAutosport @RatedMClub @RatedMRally
      07-13-2022, 08:14 PM   #16
88bimmer
88bimmer's Avatar
Drives: E70 50i f85 x5m
Would these fit?
I think m5 f90 3" inlet will fit check ebay, I want to install carbon fiber m tips so bad, but not 100% sure the size, and I don't want the slip on 3.75" black , prefer cut the stock and replace with CF m tips
