      04-09-2019, 05:06 PM   #1211
ed116
Originally Posted by maDjzo View Post
I haven't had any issues with my BT, I have a 15' F15 running ID4 and I was able to code everything possible using BimmerCode. Never dropped or failed a coding session.
cool and bluetooth 4.0 would be better correct?
im curious as to why theres 2 different versions if they behave the same :P
      04-09-2019, 06:59 PM   #1212
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Originally Posted by ed116 View Post
hey guys what obd2 are you using `vgate pro ble or wifi? which one is better?
Do a little reading man. Both are fine.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      04-10-2019, 01:39 AM   #1213
alphaod
alphaod's Avatar
Without going through the whole thread: Just out of curiosity, how long does it take you guys to go through on typical coding session using the app? Like you wanted to do say a dozen different options after the dealer reprograms your car.
I use Esys right now takes me about 30-40 minutes to go through all the different modules (reading, editing—changing from not-active to active, etc.—, saving, writing to car, and many options require two-three different changes. The process is pretty time consuming overall. It doesn't help that I bought a $100 POS computer to do it on so the trackpad is hard to use. Is the app much faster to do a lot of this stuff that I can justify spending the money.
2015 BMW X5 xDrive50i
BMW CCA 509766
      04-10-2019, 06:12 AM   #1214
IndyJer
Drives: '17 F15 MSport
'16 F15 XLine  [0.00]
'17 F15 MSport  [0.00]
Benefit of the app is just quicker to navigate the different modules and most common coding is translated to English. If you’re comfortable with Esys, and it sounds like you are, I think you are perfectly fine to stick with that method. I don’t feel you’re missing out on anything major by not using the app.
      04-10-2019, 07:10 AM   #1215
maDjzo
maDjzo's Avatar
Poland
872
Drives: G30
2018 BMW M550i  [0.00]
+1
Also ESYS will allow you to code certain things App will not. Everything I needed/wanted to code, I was as able to use BimmerCode for easily. Total coding time was 15-25 min, most of which is waiting for it to read ECUs.
      04-10-2019, 08:12 AM   #1216
ed116
Originally Posted by MK2018 View Post
O yeah, lights are moving around like crazy now. It's pleasure to drive at night
question will this wear the headlights out faster? because theyre constantly moving more pressure/stress on the mechanisms?
      04-10-2019, 11:18 AM   #1217
MK2018
MK2018's Avatar
231
Drives: 2018 X5 xDrive35i
Probably will but they were designed to do this so you shouldn't be worry about them to brake to early in my opinion
Current
2018 F15 M sport x35i
Past
2017 GMC Sierra Denali
2017 GMC Yukon Denali
2016 GMC Yukon SLT
2015 GMC Sierra All Terrain
      04-10-2019, 04:16 PM   #1218
achnnal
Drives: BMW F85 X5M
Yes exactly, colors written in German.
Edit: I apologize but the BimmerPost did not upload them in the correct order.
Edit 2: I'm wondering if you manually adjust the value that's under each color, will that do anything.
Hi, maDjzo, I got different options than yours. Is this means it doesn't works with my car?
      04-10-2019, 04:30 PM   #1219
maDjzo
maDjzo's Avatar
Poland
872
Drives: G30
Hello, you might need to have your software updated. I would reference this thread most of the details are there, with other members experiencing the same issue.
DIY (How to) Interior - Ambient Light - Color change. https://f15.bimmerpost.com/forums/sh....php?t=1205119
      04-10-2019, 06:46 PM   #1220
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Looks like same issue I have.
Have changed the top led colour but not sure how I did it lol. One of these days when I'm not so impatient I'll actually go in and take a look at what I changed.
2016 BMW X4 xDrive 28i-Sold
2014 Lincoln MKX-Sold
      04-15-2019, 04:49 PM   #1221
maDjzo
maDjzo's Avatar
Poland
872
Drives: G30
Hey guys, so just to confirm. Anyone running the latest firmware from dealer; 003. ..., is no longer able to code blinker count from 3 running ID4 NBT? Haven't messed with profiles yet, perhaps deleting and starting new profile might work..
Just an update on my end: Had my firmware updated at the dealer, and Ambient lighting moved from 3070 with ensembles to 3076 RGB standard.
Update 2: Appears I lost the ability to adjust blinker count completely, however gained VLD with my HIDs, whereas on older software didn't appear to do anything after being coded.
      04-16-2019, 05:10 PM   #1222
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Cool
'06 C55 AMG (sold)
      04-16-2019, 06:29 PM   #1223
MK2018
MK2018's Avatar
231
Did you code some different colours?
Current
Past
2016 GMC Yukon SLT
      04-16-2019, 07:06 PM   #1224
maDjzo
maDjzo's Avatar
Poland
872
Drives: G30
Honestly no, I did a tri-color as my last ensemble, and added a golden/yellow which looks pretty cool. Did notice you can adjust hues based on RGB layout but the brightest combo on all layouts works best.
      04-17-2019, 01:17 AM   #1225
MK2018
MK2018's Avatar
231
Could you tell me what exactly needs to be changed in 3076, thanks
Current
Past
2016 GMC Yukon SLT
      04-17-2019, 08:25 AM   #1226
maDjzo
maDjzo's Avatar
Poland
872
Drives: G30
https://www.bimmerpost.com/forums/sh...php?p=24418293
      04-18-2019, 10:38 PM   #1227
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Just got back a few pages and do some reading
'06 C55 AMG (sold)
      04-18-2019, 11:32 PM   #1228
MK2018
MK2018's Avatar
231
I did but it's not very clear what and where needs to be changed
Current
Past
2016 GMC Yukon SLT
      04-19-2019, 02:05 PM   #1229
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
If his screen shots don't look like what you have then you can't do it. Your sw is old.
'06 C55 AMG (sold)
      05-05-2019, 07:59 PM   #1230
Cbozz
Cbozz's Avatar
Drives: M3
hey there, I'm trying to code out the amber lights on the welcome lights using bimmercode app
I successfully coded the high beams and low beams and DRL with amber delete but the welcome lights still have it, now I know there is codes for that for ESYS but how do we get this done on bimmercode app?
here is what I need to change with ESYS
and here are options in bimmercoding app
any ideas? I did check the lines that had '00' and are right under the ones with '64'
      05-06-2019, 08:45 AM   #1231
Cbozz
Cbozz's Avatar
Drives: M3
OK after all I tried this one in last picture - Welcome light and it worked!! so if anyone wants to get rid of amber in welcome lights code expert mode welcome light 1 and check whatever I checked in the pic! thanks
      05-06-2019, 07:14 PM   #1232
X3MBullet
X3MBullet's Avatar
Drives: 2022 X3M Competition
Originally Posted by lshiroda1 View Post
Ever able to code Blind spot triangle to HU>
Hey sorry I never got notified that you sent a message from my post. NO. I was not able to code the Blind Spot triangle on the HUD.
