01-04-2024, 07:32 PM | #1 |
Rep 20
Error: 801C76 ambiguous routing
hello all
Anyone know what the following error code means? Google seems no help ? comes up with bimmerlink and won’t clear. Only error I have so is bugging me. 2018 f15 n55 x35i Central Gateway Error: 801C76 ambiguous routing Thanks |
01-05-2024, 11:30 AM | #3 |
Rep 7,488
The BMW Fault Code website {https://bmwfault.codes/} lists TWO selections for this code: 801C76
01-05-2024, 04:39 PM | #4 | ||
Rep 20
but there are 2 permanent error Dynamic stability controller 2 errors D34420: FLEXRAY Controller Error Bus 1 D34422: FLEXRAY Controller Error Bus 2 |
01-05-2024, 04:41 PM | #5 | |
Rep 20
any idea, how to reprogram? thank you |
01-05-2024, 06:23 PM | #6 |
Rep 7,488
Reprogramming and/or coding modules usually requires the “heavy-duty” software like ISTA+
01-05-2024, 06:40 PM | #7 |
Rep 20
01-06-2024, 06:41 PM | #8 |
Rep 628
Unless you also have a 125A power supply (and maybe ICOM, though ENET might make that unnecessary). Avoid messing with something that isn't causing any symptoms. Or, take it into the dealer and ask them to program it. Will probably charge 2+ hours to do it.
Edit: Just noticed you're in Baghdad. I have no idea what the dealership situation is there so my advice might be less than applicable. |
01-06-2024, 10:57 PM | #9 |
Rep 2,511
Connect your car to external charger and try to get istep update for all modules. It is relatively dangerous procedure and can potentially brick your car/modules, proceed at your own risk and do some research first.
This video is a good start for beginners: |
