      01-13-2024, 01:40 PM   #1
kammy6000
Drives: bmw f11 530d bmw x5530d
Camshaft sensor no 12v
Hi, I am new to the forum, so please excuse any stupid questions. My bmw 5x 2014 f15 530d had does not have a 12 volt voltage at the camshaft sensor
Cranks but does not start code 273c00 on ista camshaft sensor no signal
I checked all the fuses. They are fine the battery I don't know how old it is. I just acquired the car, I have checked the 12v wire from the sensor all the way to where it goes into the car at hood
Only shows 3.4volts
1 pin is 5v
Middle pin is ground
3rd pin suppose to be 12v but i get 3.4
Tried new sensor still same
Any help much appreciated
Tried with jump leads and booster pack connected
At battery just cranks
      01-15-2024, 10:58 AM   #2
kammy6000
so it turns out fuel pump under rear seats is shorted .
positive and negative seem to shorted both are ground this will also throw this code possibly , tried removing relay short still present
where this will be shorting any ideas thanks
