      01-24-2024, 08:33 AM   #1
ernicito
Drives: BMW X5 (F15)
FZD, E-SYS questions
Hello im newbie in this, watched some videos, but can't find explanation for my questions.
I have BMW F15 X5 2017 RHD, from TargetProject I have 4 opinions for F025
One is : F025-22-11-510 and another is I think F025-22-07-540 (about this one not fully sure didin't make screenshot.) But when I connect using F025-22-11-510 above on the KIS/SVT Target it shows "I-Step (shipm.): F025-16-11-503"
1. So first question would be what means those F025-xx-xx-xx, is it newer version is it production date? If I select then 22-11-510 is it wrong selection?
2. What means where TargetProject= at the end with same versions theres _DIRECT?
3. Into my FZD water came from sunroof and damaged connection with passenger airbag, I swaped to used one and now sunroof can't be programed by holding button and theres a faults that the FZD: No current coding data stored, FZD: Control unit is not encoded for the vehicle, and plenty of other related with sunroof. So what procedure should I use to code it? I have the old one should I connect that scan save CAFD file or something? Because when I connect via ESYS and go to the FZD, I don't see the CAFD file in that used one which is now connected.
I will be very thankful for the answers.
      01-24-2024, 11:37 AM   #2
RED_Y_
Drives: 2014 X5 3.5d
Please check this thread out, first post even got the video about basic coding:
https://f15.bimmerpost.com/forums/sh....php?t=1033991
1.Just difference between the FW version of your car and firmware released.
2. Do no use direct connection.
3. Should be along the line of Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE. But I am not 100% sure if FZD is codable, you should ask in the coding thread.
      01-24-2024, 12:26 PM   #3
ernicito
Thanks for your reply.
I did check that thread, sadly only one video is available.
Really appreciate for writing procedure.
      01-24-2024, 02:48 PM   #4
ernicito
Tried doing as you said got error :
job failed with negative response error:
code : coding signature not correct
description: no detailed description available; LinkName: FZD_56_ETHERNET
severity: ERROR
is it because the used FZD not flashed?
      01-24-2024, 06:53 PM   #5
RED_Y_
I am not that much of an expert, may be shawnsheridan can help here.
