10-26-2023, 11:53 AM | #1 |
Rep 106
wheel lug lock
Searched the forum could find my question.,
My wheel lock is missing so I need anew one. I cant order from Amazon can I? dont you need the VIN to make sure you get the right one? HELP!!! trying to get my winters on |
10-26-2023, 12:00 PM | #2 |
Rep 7,488
Do you have BMW or aftermarket locking bolts?
If they are BMW bolts...look for the code number on one of the locking bolts. You can order a new adapter/key from your local BMW dealership's parts department.
50iXman34.00 |
10-26-2023, 12:47 PM | #3 | |
Rep 106
They are the orignals. Can I see the code with the wheels on the X5? |
10-26-2023, 01:55 PM | #4 |
Rep 7,488
It depends on what type you have. Sometimes you can see the code down at the bottom of the lug bolt. If not, you may be able to get someone at the dealership to go out to your car with the set and do a "Cinderella slipper" to find out which adapter fits your locking lug bolts.
If you're going to be ordering a new key...it gives them "insentive" to find the right one. Do you have this type? This type will sometimes have the key code down inside the locking lug bolt. Or do you have this type"
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 10-26-2023 at 02:07 PM.. |
10-26-2023, 03:30 PM | #5 |
Rep 192
I just had this issue. Basically I took a picture of the bolt, then flipped it horizontal (mirrored). Then I compared the pattern to a diagram to find the correct code. Once I was confident that I had the correct pattern, I ordered a key on Amazon.
Diagram: View post on imgur.com Just be very careful when applying torque to the socket, as they are a little bit fragile. Turn slowly with a breaker bar and it should work. I was able to get all 4 lugs out with the key. At that point I threw away the useless locking lug bolts and replaced them with normal ones. Additionally, your local BMW dealer should have a master set. In my case, the one I needed was missing from the set Good luck! |
10-26-2023, 03:38 PM | #6 | |
Rep 106
10-26-2023, 06:24 PM | #7 |
Rep 7,488
You have the type like my first pic above…you need D.
And yes, your local BMW dealership should have a master set to figure out which replacement adapter you would need. Again, I recommend going to the PARTS department (not the service dept)…and hopefully get a parts person that has been there a while or ask for the manager/supervisor of the Parts department. Because they probably have been there long enough to either have seen this situation and/or know where the master set is located or which tech has the set…and would be more amenable to walking out to your vehicle to find the correct adapter that fits your lug bolts.
50iXman34.00 |
10-27-2023, 09:52 AM | #8 | |
Rep 106
To confirm, BMW was able to give me the code I need and will have one waiting for me tmr. Qsilver7 THANKS so much for the help you are an asset here! |
10-29-2023, 06:24 PM | #10 |
Rep 7,488
Good to hear they were able to hook you up.
There is a location below the cargo floor where the tow hook and screwdriver are stored…but sometimes the smaller adapter (like what you use) doesn’t fit securely in that location. The other type of adapter that was pictured above with the various shapes is a bit larger and usually fits securely in that location. If your adapter won’t fit snuggly by turning it like in the pics below…I’d recommend another location where it won’t get lost.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 10-29-2023 at 06:36 PM.. |
10-29-2023, 06:27 PM | #11 | |
Rep 106
Umm is the x5 supposed to come with a nutdriver for the bolts to show acces to the battery? |
10-29-2023, 07:30 PM | #12 |
Rep 7,488
No…BMW has minimalized the tools down to the tow hook and screwdriver.
