02-27-2015, 01:52 PM | #1 |
Rep 10
Valet Question...
Folks has anybody figured out a simple solution to the problem of Valet Parking. I have Comfort Access and Valet Park quite frequently.
The problem is that when I collect the vehicle the seat and steering wheel are often moved. I don't have a problem with the driver adjusting to drive safely etc but the car remembers the position from the valet driver, not from my preference... Yes I can press "1" on the seat and get my seating position back but the steering wheel needs to be moved manually. I could use the second key fob which would fix that problem, but having the second fob everywhere I go is a problem. I don't want to carry both and can't leave the second one in the car because with comfort access if anybody touches the doors they will open. Is there a step by step process here to get my seat and steering wheel positions sorted then fixed so they return to the same place even if the last driver moved the seat?? Hope that makes sense! |
02-27-2015, 01:57 PM | #2 |
Rep 35
This is weird, did you try holding the "1" button? I valet everyday and once the car is on i need to keep holding the memory button, not just press it once. Hope thats it...
02-27-2015, 02:39 PM | #3 |
Rep 18,713
Hmm, you may want to re-set the memory with the steering wheel positioned. I tried mine and it work with just one press of the memory button.
02-27-2015, 02:51 PM | #4 | |
Rep 10
I'm kind of hoping there is a better answer than me having to recall my seat position after every valet. But I will try that for now. Thanks |
02-27-2015, 03:02 PM | #5 |
Rep 18,713
NZPolarBear , I tried that I-Drive setting, and that didn't work with a keyfob press. Not sure if it does it with the newer firmware, since mine still on the first batch of F15 firmware.
AFAIK, it only do that when you use different set of keyfob. Maybe other members with 2 drivers can chime in, as I don't let my wife drive my X5. But I know that it does that with my F10 where my wife drives it daily.
02-27-2015, 03:02 PM | #6 | |
Rep 781
02-27-2015, 05:07 PM | #7 |
117
Rep 324
I also do the valet parking often.
I did use the Guest Profile. But, sometimes, when switching back from Guest to my profile, everything is put back except the seat position. Anyway I haven't spent time to figure it out. So, what I'm doing now is - Before surrendering the car to the valet, I - * switch to Guest profile. * exist the setting in iDrive. * put on the plastic cover. * tip. When getting the car back - * remove the cover. * put back my profile. * press the memory button to get my seat position back if the seat isn't moved after my profile is restored. * tip. Note: I have the Ivory White seat, so my dealer gave me some plastic covers for the chairs to "protect" my seats... |
02-27-2015, 05:15 PM | #8 |
117
Rep 324
Valet parking is always the problem.
Tesla forum has talked about this for years, but even Tesla couldn't do too much control to it yet. They now only can reduce the power when you do the valet parking. It can also be monitored by the smart phone. Luckily, in SoCal, most of valet guys know how to take care of Tesla. I haven't seen the best one for the valet mode yet, but this one below has the unique feature which is helpful. http://www.autoblog.com/2014/12/18/v...-red-corvette/ |
02-27-2015, 08:34 PM | #9 | |
Rep 781
02-28-2015, 04:11 AM | #10 | |
Rep 70
Idrive
I believe there is a setting deep in Idrive that allows you to change the setting to remember the key vs last seat position. I can't be certain but will look for it when I get my car back next week. |
02-28-2015, 10:49 AM | #11 |
Rep 1,886
Our two keys behave as they are supposed to, unless both keys walk in the car at about the same time, and then you never knows whose seat/steering/mirror settings you get. The iDrive settings are identical for us as the big boss does not bother with iDrive much.
Also, you can save a named profile in one of the eight keys, and that way, even with the other key you can press the selected 1-8 button and it goes to your settings. The car needs a "valet mode", which some cars have. Such modes also drastically reduce power. |
03-02-2015, 02:14 PM | #12 |
Rep 10
retx I'm going to do as you have suggested. I have now re-saved my seat position and it does now also move the steering wheel which is great.
I will now put the car into the Guest profile when i drop off the car. I have now saved a button to select my standard profile so when picking back up again all I need to do is press a single button to hopefully select all my settings again... Thanks for the help. |
03-02-2015, 02:56 PM | #13 |
Rep 1,762
Drives: Porsche Panamera
Memory button remembers steering/seat/lumbar/side bolster/headrest/side mirror positions.
