04-11-2019, 10:34 AM | #23 | |
1152
Rep 2,426
That looks pretty simple. I think I can do in that in driveway without making a mess!
2015 BMW X5 xDrive50i
BMW CCA 509766 |
05-16-2019, 04:26 PM | #24 |
Rep 234
Just an update. I did this job last weekend while changing out the engine oil. It was pretty straight forward. I didn't remove the steering gear cover for the front differential as I was able to reach the fill plug with just removing the reinforcement plate. I also bought a few of these transfer pumps at Harbor Freight (Coupon attached) for filling/draining the differentials (rear differential has no drain plug). Also don't forget to replace the drain and fill plugs this will require 3 (2 for front and 1 for rear) BMW Part #: 33117525064. Hope this helps.
Last edited by happydude; 05-16-2019 at 04:30 PM.. Reason: Details on Transfer Pump |
02-26-2020, 09:17 AM | #25 | |
Rep 27
I will change trans and x-case soon. |
02-26-2020, 10:30 AM | #26 |
1642
Rep 2,995
The diff fluids didn't look bad. Trans and transfer case did look dark though.
I'd at least check the fluid level in the diffs. |
Rightlanedriver6.50 |
02-26-2020, 01:45 PM | #27 | |
Rep 27
I'm thinking of buying this one and then maybe I'll find some indy shop that will do the change. 1. $284 - Transmission oil change kit: https://www.fcpeuro.com/products/bmw...-24118612901kt 2. I can't find yet a kit for transfer case |
02-26-2020, 02:19 PM | #28 |
Rep 912
I changed all fluids at 100,000km on my X6M....where I could I used Ravenol product but stayed with ZF 6 for the tranny....
Next time around, not bothering with ZF...the attached doc is a good read... https://www.audiworld.com/forums/a8-...truth-2882676/ |
02-26-2020, 04:29 PM | #29 | |
1642
Rep 2,995
02-26-2020, 05:26 PM | #30 | |
Rep 27
Is that the one? |
02-26-2020, 07:43 PM | #31 | |
1642
Rep 2,995
02-26-2020, 08:56 PM | #32 |
Rep 104
I need to do all my fluid service soon; was quoted $3k at dealer,$1600 at indy. shop; thinking of doing it myself, but dont have a lift. Are these easy enough to do with the vehicle 1.5ft off the ground on 3 ton jack stands? Enough room to work is what I'm wondering? Does the vehicle need to be flat/level, so wondering do I need 4 jack stands?
02-26-2020, 09:18 PM | #33 | |
1642
Rep 2,995
02-27-2020, 12:06 AM | #34 |
Rep 27
No adaptation or calibration is required for trans or xcase correct? Basically it's just matter of having good access to be able to work wrenches and to have some filling transfer pumps?
02-27-2020, 12:28 AM | #35 |
Rep 27
I found this video for E70 X5 xcase oil change: youtube.com/watch?v=-vCUNQSOI_M
Granted some mounting points and locations of covers might be different, but is this about right for xcase oil change procedure? I'm thinking to reuse drain plug and just buy 1L of oil for $50. Looks like it has 14mm hex if I'm not mistaken. I might try to do it myself when weather gets a bit warmer. I don't have stands, so I'm thinking to just move x5 on some amazon ramps - they are 8.5 inch height, so should be enough hopefully to work under the car. |
02-27-2020, 05:45 AM | #36 |
Rep 912
I reversed onto my “Rhino Ramps” which have a 16,000 lb capacity and a 7 inch lift.... I then raise the front via the lift point and place front on jack stands...
I lower the Jack but then raise so its snug under the same front lift point... I didn’t bother with rear jack stands but next time may jack the rear a bit more to place a 2x6 on-top of the ramp for a little extra clearance. I have two jacks... and safety is paramount. |
02-27-2020, 02:33 PM | #37 |
Rep 224
11 BMW E93 M3-- 06 BMW Z4M Roadster
99 BMW M Coupe -- 85 BMW M635CSI 97 M3 Coupe (Track)--95 BMW M3 Coupe 91 BMW 850i 6MT--20 Ram 1500 16 Chevy Tahoe 4WD |
02-27-2020, 09:42 PM | #38 | |
Rep 27
03-01-2020, 02:12 AM | #40 |
Rep 104
Tons of time in forum searches and still don't feel like I have a clear answer on my rear DHP diff. fluid needed. The PN's and description at suppliers(FCP, ECS...ect)don't seem to match what is shown in the service manual. Anybody with a DHP diff. have any clarity on this?
03-01-2020, 05:38 AM | #41 |
Rep 912
Nero x... take a look at spec chart.com...http://www.specchart.com/automotive/
Or pull up your vehicle on germanparts.ca As mentioned, I used appropriate Ravenol fluids on my X6m on my diffs and transfer case... Spent hours crosschecking part numbers and specifications also. Good luck... Last edited by Bilbofraggins; 03-01-2020 at 05:43 AM.. |
03-02-2020, 05:51 PM | #43 |
Rep 2
Hi all, new to the forum, new BMW owner. Love driving the X5 and am honestly looking forward to working on this beast. While we’re talking about the diff fluids I got a call from the wife and she sent me a picture of a reddish fluid where the left probably driver side door would be in the garage after I of course left for the airport. Just doing a little research I discovered that the tranny fluid in these is either blue or green correct? Would you all have any idea what this reddish fluid could be? She indicated that it was not oily in nature and didn’t have a smell and it’s winter and the AC hasn’t been on and the ground is dry currently where I live. Thank you.
03-02-2020, 06:28 PM | #44 | |
1642
Rep 2,995
