10-10-2017, 12:18 PM | #1 |
Rep 161
3.5i M sports front suspension - noise (Updated video.)
Hi guys,
My x5 develop this lite noise like small thumb from drive side front. Only when I drive very slow like 5miles to 10miles/h. When I accelerate and brake. But most of time when I very slowly accelerate from stop. I thought it must be a sway bar end link but when I check, all arms and busing and bolts are very tight and no movements. Do you have any idea?? By the way it has 70k miles on it. Last edited by mikeson; 10-18-2017 at 07:49 PM.. |
10-10-2017, 02:12 PM | #2 |
Rep 18,747
With 70k miles on it, I suggest you to re-torque or re-tighten the whole suspension components.
It could also be something with the brake.
10-10-2017, 07:22 PM | #3 |
Rep 161
Thank you.
Today when I drive like 15mile/h and then release gas pedal, very lite clunk squeaking noise. It is very lite and you can't even hear if I turn on the radio. But I can hear and it bugs me. And funny thing is when I pushed 'sports' mode, I can hear it less. I don't know because of engine noise or something, but somehow, I can't hear that noise. Hmmm |
10-17-2017, 10:19 AM | #5 |
Rep 11,722
Hmmm that is weird. Did you check the upper mounts nuts? See if they are within torquing specs?
To me it kinda sounds like the spring. I could be wrong. |
10-17-2017, 11:02 AM | #6 |
Rep 18,747
Could be a dead shock too.
10-17-2017, 12:33 PM | #8 |
Rep 256
I just took my car in for I think the exact same noise. I describe it as creaking when slowing or accelerating from a stop or very slow speed...is that the noise you are referring to? I can only hear it when driving very slowly with the radio off.
Dealer said it was the brake pads contacting the rotors after the brake is applied and that it is "normal". I was planning on taking it to another dealer to have it fixed because it is definitely not normal. It kind of makes sense to me that it is the brakes because road bumps and/or turning does not cause it only when I slow or speed up at slow speeds...but I still dont know if it is actually the brakes. I haven't had a chance to put the car up and look underneath and pry around to try to get it to replicate. My car has 34k miles.
2014 X5 50i
10-17-2017, 01:41 PM | #9 |
Rep 476
I took mine in twice to investigate a thump noise coming from the right front when going over a speed bump or on/off a driveway, WITH the steering wheel turned left. In both cases, the dealer did not find anything with the suspension, but made adjustments to the rear hatch. It did seem to help the last time.
If the sound comes when you apply gas, I would look over the engine/transmission mounts and generally the powerplant suspension. A cracked mount or loose bolt is the prime suspect. If the sound comes when you either apply breaks or go over bumps that cause suspension movements or compression, look over control arms, links, springs, etc. |
10-17-2017, 10:19 PM | #10 |
Rep 161
Update:
Thank you guys, I re-torque strut mount but it was tight. And I replaced a swayer end link. Noise is gone. It was the swayer end link. After I took out old one, it doesn't damaged at all and looks and move very good but after I put a new OEM one, noise is gone. Anyway, thank you guys. |
deutsch1004024.50 |
10-17-2017, 10:40 PM | #11 | |
Rep 11,722
10-18-2017, 07:56 AM | #12 |
Rep 161
BAD NEWS.
Last night was ok but this morning, noise is still there. sigh. So I am going to replace the strut(shock) and see how it goes. Hope I can replace that by this weekend. Of course, I will update for you. Last edited by mikeson; 10-18-2017 at 11:11 AM.. |
10-18-2017, 12:27 PM | #13 |
Rep 87
I had the same noise and after two visits at the dealer they replaced both front spidels (swivels) on guarantee. Now the noise disapeared and the direction seems too be more tight...also the tires were alligned as part of the process...I have 45k km...
10-18-2017, 01:20 PM | #14 |
Rep 161
Thank you for the info.
What is 'swivels'? Do you mean upper control arms? I bought 1 front struts with springs. - I don't need the springs but it comes. 1. upper control arms because of your post. I plan to replace them this weekends and will reports you guy. Last edited by mikeson; 10-18-2017 at 01:49 PM.. |
10-20-2017, 07:05 PM | #17 |
Rep 137
Had same exact noise and it can be heard also when going over small road bumps, you can also hear it if you roll down the windows.
Dealer replaced this Y part in front left suspension and its gone. Hope it helps
2018 G30 540i
2011 M3 E92 |
10-20-2017, 07:30 PM | #18 |
Rep 161
Thank you.
I just order the parts. I will replace it next Monday and will report you guys. So I was plaining to replace the front strut, but I will hold it for upper control arm. Because 2 people had same noise and I will get it next Tuesday. I can replace Tuesday night and will report on Wednesday. Thank you guys and have a great weekend. Last edited by mikeson; 10-21-2017 at 07:32 AM.. |
10-21-2017, 06:31 PM | #19 |
Rep 161
I tried to replace front strut but it wasn't easy and different 3 series BMW.
Bottom of spindle, bolts are too tight and I can't access with socket. Then I had to remove ball joint and then I can access but still it would be too much work for me. I bought to remove front strut was easy but I was wrong. I kind of give up and let see how it goes. If it goes worse, then I will drop it to shop. Anyway, thank you guys. |
08-07-2019, 12:56 PM | #20 | |
///M
194
Rep 272
Drives: 2015 F15 X5 50i M Sport
50i here. Didn't have this noise before and I just had both upper control arms (thrust arms) replaced because the thrust arm bearings were worn. After work was completed I've had the same creaking noise as your first video mikeson. BMW and my Indy shop have both taken a look and re-torqued everything.. said it all looks good. This is no bueno.. Any ideas??
2015 F15 X5 xDrive50i - M Sport - Space Grey Metallic - 21" 612M - Accelera Iota ST68's - Black Dakota - Leather Dash - Poplar Wood - Ceramic - Shawdowline - Anthracite - Adaptive M - Full LED - Executive - DA+ - Surround - HUD - Enhanced BT - Soft Close - B&O - ACC Stop & Go - Multi Contour - 4 Zone Climate - Comfort Seats - Cold Weather - Muffler Delete - Akrapovic Tips - F85 Grille - 35% Tint - BMW All Weather Mats -- Missing DHP, NV, Active Steering, Rear Entertainment, & Cooled Seats
08-07-2019, 12:59 PM | #21 |
///M
194
Rep 272
Ben, what part of the brake could be causing this? Caliper not re-installed properly?
08-07-2019, 01:53 PM | #22 | |
Rep 18,747
But, my guess would be the lower arm (#13) or the tension strut (#8)
