      04-09-2017, 05:06 PM   #1
eggyacid
eggyacid's Avatar
Drives: BMW X5 F15
Turn off the car, hit the button TWICE?
good afternoon...
once again, first BMW coming from Audio and MB world.
my 2014 X4 push button works great however a bit confused on shutting down the car. Do I always have to push the button twice?
Hitting it the first time will turn off the engine but radio/nav still on
hitting it again second time will off the radio
is this normal? I googled and few people told me to hold the button down for 2 seconds (didn't work, makes no difference). Or just walk out, close the door and lock it. Once it locks, it will turn everything off.
confused
Jeff
Current Ride
- 2016 Toyota RAV4 Hybrid
- 2014 X5 xDrive35 M
- 2013 ML-350 (Gone)
- 2012 Audi Q7 TDI (Gone)
13Ghost40.50
      04-09-2017, 05:37 PM   #2
McWCgW
Drives: 2015 x35d
Yep, hit it twice to turn everything off.
      04-09-2017, 05:46 PM   #3
XXX5
Drives: 2014 X5 F15 50i M Sport
Or if you lock the car no need for second push, it will shut down radio etc
      04-09-2017, 05:47 PM   #4
turboawd
1636
Drives: 2015 X5 35i
Press once, the radio will time out after a few minutes
Press once and lock the door, radio goes off right away
      04-09-2017, 07:20 PM   #5
Doanster
Doanster's Avatar
627
You could also code the car to turn the iDrive off after you open the driver's door to exit the vehicle.
      04-09-2017, 07:28 PM   #6
IvanLZ
IvanLZ's Avatar
Drives: 2015 X5 35i
U can hit it once and then lock it and it will turn the radio off and lights
      04-09-2017, 09:35 PM   #7
MysticBlue
I didn't like it at first. I was used to all of my previous BMW's that you could just hit once and hold for a second or two and everything would shut off. (This is why your google search came up with that.... that's how it used to be). But, like most change, I've gotten used to it. If I'm anywhere but home, I don't worry about it 'cause I'm going to lock it anyway, which shuts everything down. In my garage however, I don't lock it so it was kind of irritating at first, but I usually remember to hit it twice now. But even if I don't, I know it's going to time out and shut down on it's own in a few minutes. I still don't like it, but not a big deal.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra.
      04-10-2017, 07:57 AM   #8
rog832
Drives: X6
I recently switched to BMW from MB and this is one thing i just don't understand. I also noticed if don't press the button twice or lock the door my phone stays connected to the car till the iDrive shuts down. I guess i have to looking into coding the car to turn the iDrive off after you open the driver's door to exit the vehicle.
      04-10-2017, 08:02 AM   #9
double_j
86
Drives: 2008 JB/B E90 M3
You'll get used to it eventually. It's not that big a deal to push the button twice.
The harder part is figuring out what to do when you pull up to a drive in ATM or something and the auto stop turns off the engine. I never remember how many times I need to press the button.
      04-10-2017, 08:38 AM   #10
Kzang
Kzang's Avatar
3240
Drives: 2015 X5 35i Msport SG
Step 1. Push the button once which shuts off the engine..
Step 2. Get out of the vehicle.
Step 3. Press lock button on keyfob or if you have comfort access press the ridges on the door handle to lock the car. Everything shuts down.
PS: you do NOT have to press the button twice.
      04-10-2017, 08:59 AM   #11
Doanster
Doanster's Avatar
627
Not sure what you mean here. Are you saying you use the button to restart the motor? You should never need to touch the button during normal driving if you have this feature enabled because iDrive stays on and the motor should wake up with the release of the brake pedal or you jerking/turning the steering wheel a bit.
      04-10-2017, 09:03 AM   #12
Doanster
Doanster's Avatar
627
Coding it just makes it convenient, but as Kzang stated, just lock up the car normally via any means and rest assured iDrive will shutdown and never drain your battery. Remember, even if you sit in the car and listen to music with the motor off, you'll eventually get the warning that iDrive will shutdown unless you hit the button again. There are fail-safes all over this car...
      04-10-2017, 09:18 AM   #13
IvanLZ
IvanLZ's Avatar
Drives: 2015 X5 35i
When auto stop start is enabled and the car is on a stop, it will turn off the engine temporarily but if you open the door while its stopped then the engine will shut off completely and you will need to press the start engine again.
      04-10-2017, 10:08 AM   #14
double_j
86
Also, I tend to be very inconsistent between just keeping my foot on the brake while using the ATM or putting the transmission park. One doesn't require a button push, the other does.
      04-10-2017, 10:34 AM   #15
stewy604
stewy604's Avatar
290
As said above, you'll get used to the "two press".
2007 Suzuki GSX-R 750
      04-10-2017, 11:11 AM   #16
McWCgW
Drives: 2015 x35d
Yep, it's quite easy. "boom-boom", it's as fast and easy as only pressing it once.
      04-10-2017, 12:00 PM   #17
Flying Ace
Flying Ace's Avatar
4985
Drives: G05 45e, 997.1 & 991.1 GT3s
is it really that difficult to understand how to shut down the car?
Push 1 turns off motor. At this point, you can turn off electricals be either locking the car or pushing the button again.
      04-10-2017, 12:07 PM   #18
xdriverx
Drives: 2017 BMW X5 35i Xdrive
Who opens their door while in traffic? Or at the ATM for that matter? LOL
unluky7528.00
      04-10-2017, 12:15 PM   #19
double_j
86
I've seen some drive up ATM users act like it's a walk up machine. Totally out of their car. These are the same people who have to open their doors to pay a toll.
      04-10-2017, 12:57 PM   #20
xdriverx
These are the same people who drive the speed limit in the passing lane.
      04-10-2017, 02:32 PM   #21
Kzang
Kzang's Avatar
3240
I HATE these people... I just feel like people in this area ( NY/NJ ) just don't understand what the left lane is for because they drive so freakin slow in the left lane and either don't seem to look back behind them to see if they are holding up traffic or are just asses.
      04-10-2017, 02:40 PM   #22
Chadmatic
Registered Member
Chadmatic's Avatar
Drives: F15 35i M-Sport
I have seen plenty of drive-up ATM machines and parking pay station gates with island curbs that stick out so far you are forced to open your door if you don't want to curb your rims.
