04-27-2021, 03:51 PM | #1 |
Rep 272
All fluids for F85/ F86
Hello,
I want to change all fluids in my new to me 2016 X6M. I am making a list of all the fluids that needs to changed in a F85/ F86. I have this list. Please let me know if I am missing any. Also if anyone know the intervals that would be great. UPDATED LIST Engine Oil Transmission Oil Front & Rear Differential Fluid Transfer Case Brake Fluid Power Steering Fluid Coolant Intercooler Ty Last edited by MBoss_F86; 09-09-2021 at 07:50 AM.. |
04-27-2021, 06:55 PM | #2 |
Rep 1,035
Don’t forget the transfer case, front differential and intercooler fluid.
08-18-2021, 02:09 PM | #4 |
184
Rep 364
Drives: M2C X5M M4
They have only got 1 litre of auto box fluid it will be approx 6 and it needs a filter, I would only use ZF lifeguard 8 no after market.
The transfer case is dtf1 oil not dual clutch transmission oil and the labour time is very high on the transfer case. Also you are not supposed to change the centre diff (it's hard to get the correct level) oil only the 2 outer chambers. As an aside I have posted about this previously on this sub forum that the plug isn't a traditional level plug it needs to be measured in or it will mix with the middle chamber. I did upload BMW's instructions somewhere on the f85/86 forum. The rear diff is hugely expensive and a bad service can be as damaging as no service The coolant circuits are supposed to be vacuum filled not conventionally filled and bled also, I have a bmw k1300 bike and it's the same, something to do with an air trap in the hose. |
08-18-2021, 05:06 PM | #5 |
Rep 272
///MCollection I did notice the issues you mentioned in the quote. I will talk to them.
Transmission Fluid - needs 7 litres oil and filter kit (24-00-7-855-263) Transfer Case - DTF1 (83-22-2-409-710) - do you know how much fluid I need? They did quote me 4 hours of labor for Transfer case which sounds about correct The shop I got the quote are M car experts. I wonder if they gave got my quote mixed up with something. I will talk to them. Thanks a lot for the comments. |
08-18-2021, 05:56 PM | #7 | |
223
Rep 304
MBoss_F86139.00 |
08-19-2021, 12:29 AM | #8 |
184
Rep 364
Drives: M2C X5M M4
KLR X5M is correct as above, reset transfer case adaptions
If there M experts you should be fine, maybe just a typo. The ZF service kits come with 7 litres as above but I've not used the 7th bottle yet. And the amount for transfer case I believe is closer to 500ml than a litre but maybe slightly above. The DFT is in litre bottles so strong chance you will be buying a litre which is neither here nor there on the cost. |
08-19-2021, 08:19 AM | #9 |
Rep 30
As a *rough* comparison, my local dealer quoted me about 650 to do the transfer case and transmission services. The labor costs on some of this looks a bit extreme in my opinion.
08-19-2021, 10:13 AM | #10 |
Rep 1,035
I had all of these services performed on my X5M earlier this year, although I bought my own fluids and parts, I lessened the impact to my wallet. And paid for labor only
09-04-2021, 02:08 AM | #11 |
Rep 188
Just got quoted $473 (labor only) for Transfer Case service at Funfzehn.
Does anyone know of a trusted shop in So Cal that'll do it for less?
2016 X5M F85 Mineral White
2011 Mercedes G55 AMG (sold) 2005 C6 Corvette (sold) |
09-05-2021, 06:57 AM | #12 | |
Rep 1,891
09-06-2021, 02:58 AM | #14 | |
Rep 188
Maybe the book states 4-5 hours?
09-06-2021, 02:59 AM | #15 |
Rep 188
What were you quoted?
09-06-2021, 03:01 AM | #16 |
Rep 1,891
$725. Oil change, intercooler/coolant, power steering, all 4 brake pads and sensor, front and rear diff, transfer case. I supply all parts.
09-06-2021, 07:41 AM | #17 |
Rep 95
im not sure why you would need to change intercooler fluid unless perhaps way over 100k.
I get gearbox and center diff fluids as well... but again, 80k miles or more. Having had a couple of these X5s and an X3. The only issue I had was a first gen X3 center diff wearing out the plastic gear.
2014 M6 Coupe (SG/Silverstone)
2017 X5M (LBBlue/Aragon) 2000 Z3M Roadster (EstB/Black) |
09-06-2021, 01:24 PM | #18 | |
Rep 1,035
As yourself this, why would you change your engine coolant and not your charge air fluids. I know the the charge air is a closed loop system, but no fluid last forever.
09-06-2021, 02:58 PM | #19 | |
Rep 188
Is it a reputable shop? Curious to know what their labor is for just the transfer case change.
09-06-2021, 04:45 PM | #20 | ||
Rep 1,891
09-08-2021, 10:12 AM | #21 |
Rep 1,035
The quote for the transfer case is way too high in my opinion, anything between $150-200 is reasonable, as the cross brace has to be remove to gain access to the fill/drain plugs.
09-08-2021, 02:50 PM | #22 |
Rep 188
Yeah, I called a few more shops and you're right, average quote is $130, and should take only 1 hour of labor.
