01-22-2019, 01:07 PM | #1 |
Rep 30
Remote battery needs replacement
Received a system alert on the gauge cluster that read "remote battery needs replacement", so I replaced the battery in the key fob. However, seems that the system doesn't automatically detect that the battery has been replaced?
Is there anyway to get rid the alert message without a decoder gadget? I won't be going to my Indy shop until the spring. Any help on this would be great appreciated! |
01-22-2019, 01:14 PM | #2 | |
Rep 1,343
That would be my best guess
01-22-2019, 02:10 PM | #3 |
Rep 7,489
Are you sure the replacement battery was fresh and has at least 2.8-3.s volts?
Do you have a 2nd remote that may also need a battery replaced?
01-22-2019, 02:31 PM | #4 |
Rep 100
and not overlook a protective removable piece of tape on the battery before inserting , not as if that happened this weekend
Russmov1328.00 CanadianLurker41.00 |
01-25-2019, 09:57 AM | #5 |
1st year CCA Member
25
Rep 30
This actually happened to me about a month after I bought my x5. Replacing the battery is actually kind of easy.
1. Remove the key from the remote 2. Carefully pry the back of the remote outwards. 3. Place it all back together and you should be all set! |
01-25-2019, 07:29 PM | #6 |
88
Rep 366
Replacing the battery in the fob requires nothing but what he said above. you replace the battery, and the vehicle recognizes that the battery isn't low anymore.
If you replaced the battery, and got the same message, the battery isn't full.
2014 X5 35d X-drive. Space Gray Metallic. Mocha Dakota Leather.
01-25-2019, 09:06 PM | #7 |
241
Rep 307
FYI the key actually fits into a small piece on the lid to help you pry it up.
01-25-2019, 09:08 PM | #8 | ||
241
Rep 307
covertstyle20.00 |
01-26-2019, 11:10 AM | #9 |
Rep 192
I had the same alert message come on last week, replaced the battery and got back in the car and it went away.
covertstyle20.00 |
01-26-2019, 07:00 PM | #10 | |
Schumacher
786
Rep 2,278
Drives: E30 325is,E93 M3,X7M50,F06 M6
I decided to replace both remotes since I had the batteries for something else anyway. Took total of 5 minutes to replace both.
