      05-21-2015, 08:12 PM   #1
templarklimek
templarklimek
Drives: 15' X6M, 12' R8 V10,
Exhaust system MOD
Gents,
I've had good luck with a local shop modding my exhaust systems rather than spending 3-5K from other companies. This time is no different. The factory system has respectable 3 inch pipng but then it goes into IMHO a heavy complicated muffler setup. I had them cut out the factory muffler setup and replaced with 3 inch straight pipe. It sounds a little deeper but with an awesome growl. Not so load as to disturb a neighbor or the PD. Plus u lose about 55 pounds form factory system. No engine lights from removing the electronically controlled flaps either.
This is old exhaust but NOT the piping.
Crap,how do I reuce the size/memory of these pics. grrr.
      05-21-2015, 10:37 PM   #2
templarklimek , any sound clips or videos to give other forum members idea?
I bet it would sound great.
      05-22-2015, 02:17 AM   #3
templarklimek
templarklimek
I'm on it, it gives an AWESOME gurgle sound that has a hint of deepness to it without being obnoxious
I'll post some sound clips
      05-22-2015, 06:55 AM   #4
RajG
Drives: '14 M5 CP
Does it drone around 1.5-2k RPM? I did something similar on my old F10 550 and it droned in that range which made me go back to the factory muffler setup.
Current Stable
?19 M5 CP
?19 X6M
      05-22-2015, 09:44 AM   #5
templarklimek
templarklimek
I'm not getting any drone, the factory resonators were left on and it sounds deeper with a satisfying burble.
      05-22-2015, 09:51 AM   #6
Poleposition
Poleposition's Avatar
Drives: very well
Confused but very interested. Downpipes/cats to two seperate resonators to what? Straight pipes right out the back? Must sound great. Pls post pics from underneath if you can.
2022 Individual M5 Comp
Venetian Violet
2021 X6M Comp
2024 i4 M50 on order
IG @purpleM5Comp_NY
      05-25-2015, 01:58 AM   #7
ChrisM6GC
Drives: M6 GC
Are there any flaps on the x5m exhaust? Any easy mods that can be done to keep the flap open like in the m6 and m5?
      05-25-2015, 06:42 AM   #8
Roundown
Drives: BMW
Anyone remove those secondary (post sensor) cats? Popular mod on the N54- was typically good for 3-5% increase in power.
      05-25-2015, 08:15 AM   #9
fyim
fyim's Avatar
83
Drives: E92
http://ind-distribution.com/ind/bran...control-module
      09-05-2018, 03:55 PM   #10
Bobby_Drake
Bobby_Drake's Avatar
390
Drives: '16 X5M
Resurrecting an old thread. Interested in your set up. Can you post pics of the system installed in your car? Any sound clips?
      09-06-2018, 07:52 PM   #11
yewlock
yewlock's Avatar
Drives: X5
His Last Activity: 08-04-2017 06:55 PM
      09-11-2018, 09:41 PM   #12
Bobby_Drake
390
Drives: '16 X5M
I figured I'd try. Looking at a straight pipe set up as well...
