06-26-2023, 04:46 PM | #1 |
Rep 7
Dash wrinkles
So I’m looking to get this X5. It’s a 2014 with 122k with a nice service history. Only issues I see is the dash has some bubbles/wrinkles. I have a 2015 x5 and it doesn’t have this issue. Not sure if this leather is different if it has this as a known issue. Could I maybe glue it back down? Maybe use a syringe put some glue in through the stitches or around the speaker area? A dash from a junkyard is like $400 but I think it’s a lot of work. Any advice appreciated.
06-26-2023, 05:17 PM | #2 |
2018 F15 X5 X40d #BSM #IvoryWhite
39
Rep 334
That looks like it would've been the extended merino leather option which included a leather trimmed dash. I guess from the constant sun heat that it made the leather sag/lift. I've seen similar things happen to leather lined roofs within the previous generation Range Rover in hot countries.
Granted, it shouldn't happen especially on the dash where heat is expected to build up due to the sun's rays. I had a leather trimmed dash in my old 6 series Gran Coupe and never had any issues. Your best bet would be to speak to someone that does retrims/interiors for the best fix as these leathers tend to be very delicate. I remember checking how cushiony the leather dash was with my finger nail in my 6GC and it left a permanent nail mark |
06-26-2023, 05:36 PM | #3 | |
Rep 7
06-26-2023, 06:33 PM | #4 | |
39
Rep 334
Replacing the dash with the regular black plastic one shouldn't be an issue but if you look closely the top part of the door cards is trimmed in the same leather so you'll interupt the design. In my old 6GC it was champagne and dark blue leather split 2 tone with blue on the upper part of the doorcards and continuing to a fully blue leather dashboard so in that if I replaced the dashboard it wouldn't match with the door cards and interrupt the design also. |
06-29-2023, 04:04 PM | #5 | |
Rep 1,532
06-29-2023, 04:40 PM | #6 |
Rep 17
I have the same problem also need help
06-29-2023, 04:44 PM | #7 |
Rep 3,658
That looks awful, not sure how you'd fix that? It probably sat in the sun too long?
That's definitely the nappa leather dash not just based on pictures, but that mocha interior only came with the 'interior design package.' However, you could also opt for a leather dash as a standalone option w/o getting the 'interior design package' - that's what I have but my dash doesn't have any of those wrinkles (also has a 1/4 of the miles of this one mentioned). Either live with it, or find another X5 would be my suggestion. How many miles on yours? Does it sit out in the sun? You have a windshield cover/screen? |
Vivek.1367.50 |
06-29-2023, 09:18 PM | #8 |
Rep 22
Mine has this problem. 2016 X50i 50k miles. Bought used from my brother...he didn't even notice it lol. Wasn't garaged and in the south. Paint is in great shape but the dash is the thing that kills me. I'd like to put a new (used) dash in but I'm wary of some rattling after a new one is installed. Judging by the videos I've seen of dash removal it looks a little involved to say the least.
06-30-2023, 12:47 AM | #9 | |
Rep 1,532
06-30-2023, 10:02 AM | #10 | |
Rep 7,580
Nappa is a "full" grain leather and has a "light" protective coating. It is also soft to the touch and looks and feels good. Vernasca leather would fall into the same category as the Dakota/Nevada. It has an embossed grain pattern and has a synthetic polymer coating which makes it better for rougher usage (small kids/pets/etc).
Vivek.1367.50 |
06-30-2023, 10:46 AM | #11 | |
Rep 3,658
I just looked at the 2018 X5 non-M build guide and leather dash was available as a standalone option on every model from the sDrive35i to xDrive50i for $1200. Which is odd at least for the 50i, as for 2017 models like mine, leather dashboard was part of the Executive Package (per my window sticker, and I checked the 2017 X5 build guide). |
Vivek.1367.50 |
06-30-2023, 11:09 AM | #12 | |
Rep 1,532
Nappa as I understand is 'full-grain', meaning a natural pattern surface that isn't stamped like Dakota/NV/Vernasca but also isn't shaved or sanded to artificially create a fine-grain look. Merino does have a coating, just a natural rather than artificial one. Uncoated leather in a car would look awful within weeks no matter how careful you are, very porous material.
06-30-2023, 12:02 PM | #13 |
Rep 7,580
Ditto...my understanding of the difference between "fine" and "full grain" is the same. The "fine grain" leather has gone through a buffing/sanding process to remove any blemishes.
For example, if the cow hide has a barbed wire marking on it...the "fine grain" process would sand out the blemish. Where as if the hide was being processed just to be "full grained" the blemish could still be slightly visible.
Vivek.1367.50 |
