10-22-2018, 03:40 PM | #1 |
Rep 2
Coding Errors
Looked through the forums and couldn't find the answer to this. I was coding my 2016 BMW X5 head unit with Bimmercode then the screen went black and now nothing displays. Is there a way to fix that or do I have to take it to the dealership to fix it?
edit: I was able to restore it to the original setting. Last edited by jim233823; 10-22-2018 at 04:05 PM.. Reason: Solved |
10-22-2018, 04:08 PM | #2 |
Rep 627
Drives: X5 F15 M package
Can you explain what did you do to restore ?
10-22-2018, 09:12 PM | #4 |
N00B
94
Rep 210
It's in sleep mode most likely, I had the same issue a couple months ago and thought I bricked it. It cleared itself up like 3 hours later (I looked it and didn't go near it), confirm once it's back up that all modules are green and avoid advanced coding if possible, that's what killed mine. I restored to a good/known backup and everything has been great since then.
The owls are not what they seem!
