      03-13-2018, 06:26 PM   #639
Florida-X3
Drives: '23 X3 x30i / '12 Infiniti M37
I just got set-up with Bimmercode and while my first attempt at changing things resulted in a big fat nothing. Do you have to make one change at a time between pushing the "Code" button? Also, is there some sort of guide (not the quick start) that provides more detailed explanations of each option? Some are obvious and others are not.
      03-13-2018, 06:47 PM   #640
Polskidebesciak
Drives: Audi Q7 TDI
I would like to start coding, is this the device to buy?
https://www.amazon.com/Vgate-Scanner...ar+vgate&psc=1
      03-13-2018, 06:51 PM   #641
scooby007
Drives: 2015 BmW X5 M-Sport 35i
Polskidebesciak - If you go to Bimmercode website, it will give you a list of OBD II adapter that will work with the app. I purchased the wifi model and been using it with my android tablet and phone.
https://www.amazon.com/Vgate-iCar-di...9693e50e56c6bb
      03-13-2018, 07:36 PM   #642
Florida-X3
I just bought this one.
https://www.amazon.com/Vgate-Elm327-...rds=vgate+wifi
      03-14-2018, 10:16 AM   #643
Mgm 05
Drives: ‘15 X5 35d; '24 i4 M50
The other major coding thread has a link to a cheat sheet that can help with some stuff otherwise your best “guide” to BimmerCode is to read through this thread.
When you say you got nothing did the code not take or not complete? You should be able to do multiple things within a given module at once but I started with something simple and easy to make sure it worked (like LEDs on reverse or open/close trunk from footwell button) then kept adding.
      03-14-2018, 10:57 AM   #644
CeeTeeX5
This might be a silly question but did you check to be sure you aren’t in demo mode?
2018 X5 35i M-Sport
Dinan Stage 1 Tuner
M-Perf Exhaust and lip
2018 X1 28i M-Sport
      03-18-2018, 10:21 AM   #645
possib1edoc
Drives: BMW X7
Have two questions:
1. Any way to use back up camera on at any speed?
2. Are we able to change ambient colors using this app?
Thank you, appreciate help!
      03-18-2018, 10:28 AM   #646
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
Originally Posted by possib1edoc View Post
Have two questions:
1. Yes, for a short period of time.
2.Yes, you would have to go into expert mode.
Follow this thread to know what needs to be changed:
https://f15.bimmerpost.com/forums/sh....php?t=1205119
This is what am running now, looks awesome!
      03-18-2018, 10:36 AM   #647
possib1edoc
Drives: BMW X7
That looks amazing!
I wasn't able to code the back up camera while already in motion. I was just able to change the setting where it stays on longer after going reverse and driving forward.
      03-18-2018, 12:40 PM   #648
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
That looks amazing!
Thank you!
I think I did the backup camera with Esys before, not sure if it works with bummercode.
      03-18-2018, 06:11 PM   #649
Polskidebesciak
Drives: Audi Q7 TDI
Just received the device today. I will play with the coding tomorrow after work. Do you guys perform it with the engine on or off, and just the ignition?
      03-18-2018, 07:34 PM   #650
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
523
Drives: 2020 Mineral White 30d MSport
Always ON
      04-04-2018, 05:46 AM   #651
Johnd3
Drives: 2017 BMW X5
Hi, how did you code the added turn signals to HUD? i have 2017 x5 with m package.
      04-04-2018, 06:34 AM   #652
CatalinP
Drives: BMW X5 F15 2014 3.0xd
Using Bimmercode, but bear in mind that it does not work if you have full digital dash (6WB).
      04-04-2018, 12:37 PM   #653
anon1000
Drives: bmw
With the new firmware you can no longer change these colors, you are stuck with the standard ugly blue, uglier orange and white.
      04-04-2018, 01:34 PM   #654
perry8912
Drives: bmw x5
What’s the brightness of the ambient light setting?
      04-04-2018, 09:15 PM   #655
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
I think you can, you just have to enter the value manually.. here are the values!
      04-04-2018, 09:18 PM   #656
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
What's the brightness of the ambient light setting?
I always have it at max... even that is little dim IMHO.
      04-05-2018, 02:10 PM   #657
candm
candm's Avatar
Drives: 2016 BMW X5 xDrive40e
Even without 6WB turn signals can become unavailable as well.
I have a 2016 40e and went in for service and has a update from the dealer to fix a pre-ignition problem. That update removed the option for me. Everything else appears to work though.
2016 F15 X5 xDrive40e Alpine/Terra
2013 E84 X1 xDrive28 Apline/Terra
      04-08-2018, 05:38 AM   #658
eric_s
Drives: X5
Hi Newbie here.. wonderful and informative thread. I have a general question that I don't see here (or maybe I might have missed it). I am driving the Xdrive 40e and would like to find out if coding would affect sensitive electronics of the car. Would seek fellow 40e owners affirmation. Many thanks to all.
      04-09-2018, 03:25 PM   #659
SCA
SCA's Avatar
Drives: Multiple BMWs
App updated 04.08.18
      04-12-2018, 09:37 AM   #660
Rhinowso
Rhinowso's Avatar
Drives: 2014 X5 35i
Just did some coding last night with the new update and noticed the ability to code in the sport auto transmission. Is this the same as clicking the shifter left to go into S/M mode?
