01-20-2017, 05:51 PM | #3081 | |
Rep 8,364
01-21-2017, 07:55 AM | #3082 | |
Rep 938
re: versions: media: mn-003.009.004 phone: tn-003.009.004 cant tell but assume these could be newer than update 5074? |
01-21-2017, 02:26 PM | #3083 |
Rep 8,364
01-21-2017, 05:28 PM | #3084 |
Rep 592
01-21-2017, 06:04 PM | #3085 |
Rep 8,364
01-21-2017, 06:36 PM | #3086 | |
Rep 96
Drives: 2010 335d, 2018 540d
01-21-2017, 07:30 PM | #3087 | |
Rep 8,364
01-21-2017, 08:19 PM | #3088 | |
Rep 96
I SO appreciate your help! Last edited by bms5; 01-21-2017 at 10:49 PM.. |
01-21-2017, 09:01 PM | #3089 |
Rep 938
I had two things on there. Bluetooth update and map update. Neither will load. I may go buy a new flash card tmw and see if that works. There aren't any hidden files either. Argh.
01-21-2017, 10:42 PM | #3090 | |
Rep 8,364
PM'd additional instructions. |
01-22-2017, 09:33 AM | #3091 | |
Rep 938
thanks a ton for the help! |
01-22-2017, 12:52 PM | #3092 |
Rep 8,364
01-22-2017, 04:17 PM | #3093 |
Rep 102
Surround view in reverse
Thanks to all the very knowledgeable and helpful people on this forum. Given your instruction, I was able to code my X5 for the first time without incident this afternoon!!!
Is there a code to make a 2017 X5 go into surround camera mode when reversing instead of the reverse camera? My 2012 X3 did this by default; so did my M4 now that I think about it. I know there is a button you can push to get it to go to surround, but I want surround view to be default when reversing. Thanks in advance for any help. |
01-22-2017, 04:56 PM | #3094 | |
Rep 2,353
01-22-2017, 06:25 PM | #3095 |
Rep 159
I downloaded the E-Sys 3.28.1 exe and the TokenMaster Premium ESysLauncherPremiumSetup_2.6.2_Build_124.msi file.
Installed both. Generated a PIN on initial launch of TokenMaster. Saved EST file to data folder as per instructions. Went to FDL Editor in E-SYS just to test entering the Softoken PIN that I created and it says please enter correct PIN in red. I keep entering the one I created and it does not work. Any suggestions on what I am doing wrong would be much appreciated. Thank you |
01-22-2017, 06:29 PM | #3096 | |
Rep 40,650
01-22-2017, 07:12 PM | #3097 | |
Rep 159
The only thing I am concerned about is that on some information it states that the app should only run on a memory setting of 1024 RAM nothing greater. The E-Sys launcher will not save me changing the value from 2048 to 1024 RAM but the E-Sys regular app will save the change, so that is why I tried to run the E-Sys Launcher, close it, then open the E-Sys app and use that. |
01-22-2017, 07:28 PM | #3098 | |
Rep 40,650
01-23-2017, 04:24 PM | #3099 | ||
Rep 8,364
01-23-2017, 06:38 PM | #3100 | |
Rep 159
Thanks |
Stinkyxy152.00 |
01-23-2017, 06:55 PM | #3101 |
Rep 159
OK, now I have E-Sys launcher running.
I have a brand new 2017 F15 50i. The code spreadsheet does not reflect the code categories I am seeing. For example I wanted to stop the legal disclaimers in the IDrive and the rear view camera. According to the sheet I should be looking at the HU_NBT module. The only module I can see is HU_NBT2. IHave I done something wrong or are all the module names and values changed for the 2017 model? [IMG][/IMG] |
01-23-2017, 07:07 PM | #3102 | |
Rep 8,364
HU_NBT2 is ID5 on '17 Models. Most of the funktions and codes are the same. |
