01-18-2017, 06:31 PM | #1 |
Rep 620
xdrive3.5 staggered setup?
can you do a staggered setup on an xdrive3.5? Wheel size are 20x9 and 20x10.5.
Squattin on Megan Racing and Vertini Monaco |
01-18-2017, 07:35 PM | #2 | |
Rep 18,715
The M Sport comes staggered.
01-18-2017, 09:32 PM | #3 |
Rep 620
even on the xdrive? i know they do on the sdrive but havent seen them on a xdrive.
01-18-2017, 09:44 PM | #4 |
Rep 18,715
Yes. Even on the xDrive.
01-19-2017, 01:32 AM | #5 |
Rep 620
kool..thanks bro. which tire size would u recommend on a 20x9 and 20x10.5 wheels...275/40/20 and 315/35/20?
01-19-2017, 05:34 AM | #6 |
Rep 5,066
All Msport with 20" wheel option are staggered regardless of Xdrive or SDrive. Not 100% sure on the other lines if you get staggered or not with 20" wheel option. I think you do.
01-19-2017, 07:20 AM | #7 |
Rep 108
I believe they can all be shod with 275/40R20 315/35R20. My 2017 X5 xDrive40e non-Msport came from the factory with 20" staggered tires.
OEM wheels Front 20 x 10 offset 40mm Rear 20 x 11 offset 37mm |
01-19-2017, 07:49 AM | #8 |
Rep 1,363
Those tires should be fine.
Just a quick look at tire rack shows 275/40/20 tires require a minimum 9" rim And 315/35/20 tires require a minimum of 10.5 rim Since it's same size as oem, you should be good |
01-19-2017, 10:18 AM | #9 |
1150
Rep 2,426
The non-Msport versions also come staggers in 20" configuration.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
01-19-2017, 06:31 PM | #11 | |
Rep 11,891
01-19-2017, 08:12 PM | #12 | ||
Rep 2,353
