08-14-2018, 11:55 AM | #1 |
Rep 1,497
35i Approaching 60K Service
'15 purchased in May with 54K miles. Just performed an oil change as well as air filter replacement. I know that spark plugs are recommended at 60K but what else? Fluids (tranny, transfer case, diff, brake, etc.)? Trying to keep her in tip top shape
08-14-2018, 02:05 PM | #4 |
Rep 11,722
As a general rule of thrums for me, 60k service includes belts water pump and thermostat. With the exception of one car, never had to pull over for overheating. I would slap on some spark plugs as well.
08-14-2018, 03:42 PM | #5 |
480
Rep 317
Brakes: Any DOT 4 brake fluid should suffice however, Pentosin DOT 4 LV is what I personally use with no problems
Transmission: Use OEM Fluid ie Lifeguard 8, and OEM ZF PAN, you can get this from FCP Euro ZF 8HP TRANSMISSION SERVICE KIT Front & Rear Differential: 75w90 Liqui Moly you'll need 2 one for each axle also need to replace oil fill and drain nut's Transfer Case: Use BMW Transfer Case oil or ATC fluid by shell only! Waterpump: 60k miles is about when BMW electric water pump failures occurs replace it with thermostat. Brake pads: probally a good idea to inspect your brake pads and lube slide pins. |
4
08-14-2018, 04:16 PM | #6 |
Rep 83
Don't forget power steering fluid and brake fluid if they've not been done since purchase.
2021 X3 M40i, 2021 X5 xDrive 4.0i
------------------------------------------------------------- 2016 X5 3.5i, 2017 X4 M40i, 2006 330i E90, 2004 X5 3.0i, 2000 528i MT, 1986 535is MT , 1985 528e MT, 1985 325e MT |
08-14-2018, 04:24 PM | #7 |
480
Rep 317
08-15-2018, 11:55 AM | #8 | |
Rep 1,497
I had heard about the electronic water pump failure from a mechanic buddy of mine before the purchase. Are there any signs before failure? Also, I've been hearing a very faint whine at low speeds in my parking garage at work. Sounds like low power steering fluid. Since ours is electric would this be an indication it will fail soon. Haven't been on here long but power steering failure doesn't pop up much. |
05-03-2019, 10:32 AM | #9 | |
Rep 1,497
Chime in if you've had to replace yours and at what mileage guys. |
05-03-2019, 02:28 PM | #10 | |
Rep 14
Are you sure about what you are hearing? Could it be the turbos spooling up making that faint whine? |
05-03-2019, 05:55 PM | #11 |
Rep 474
My Indie guy told me 60k was cabin filters, brake fluid change, plugs and coils. Did cabin filters myself (one of the easiest cars I have ever done, someone at BMW screwed up). Dealer did plugs and coils under CPO for an issue I was having. Indie guy did brake fluid, rear brakes and rotors (brakes needed it).
05-04-2019, 04:21 AM | #12 |
Rep 147
Just had mine done at BMW. Oil, plugs, brake flush and cabin filter. I did cabin filter myself. Total cost in Columbia SC for the rest was around $600.
05-06-2019, 10:48 AM | #13 |
Rep 1,497
05-06-2019, 10:26 PM | #14 | |
Rep 449
'11 E92 M3 ZCP Mineral White - Fox Red Extended ‘15 F85 X5M Mineral White - Aragon Brown Full |
05-07-2019, 03:15 PM | #15 |
Rep 627
Drives: X5 F15 M package
Went to dealer today for same maintenance.
Will post the receipt |
M302_imola842.50 |
05-07-2019, 05:14 PM | #16 |
Rep 84
Don't want to be the one who points out the obvious, but my tires squeal in almost every garage. It gets more pronounced when turning. I hope, for your sake, that is all it is.
05-08-2019, 10:36 AM | #17 |
Rep 1,497
05-08-2019, 11:10 AM | #18 | |
Rep 570
https://www.amazon.com/Ravenol-J1C11...r=8-3-fkmrnull https://www.fcpeuro.com/products/75w...red-line-50104 Also why do you need to replace fill and drain nuts? Last edited by MrTookies; 05-08-2019 at 11:16 AM.. |
