01-02-2019, 01:19 AM | #1 |
231
Rep 369
2018 F15 parked for a month
Hey guys, I couldn't find anything about that's why I'm going to ask here.
I will be away from home for about 4-5 weeks and I'm leaving my 2018 F15 parked in the garage for that time. Is there something I should do before I leave like plug it in to make sure it's going to start when I'm back?
Current
01-02-2019, 01:48 AM | #2 |
<3 Flat Four
217
Rep 754
nothing much to do other than get a branded trickle charger, and to fill up the gas tank. ive parked my f15 for months and it has always started. oh dont wash ur car before parking else the rotors will rust badly and seize ur pads to the rotor together.
2011 335is Le Mans Blue
01-02-2019, 01:57 AM | #3 |
1150
Rep 2,426
I parked in airport long term parking for two months, other than being expensive nothing was wrong. I did drive straight to a car wash before heading home.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
01-02-2019, 10:14 AM | #7 |
Rep 2,388
Yes. You should drain all fluids, take off wheels and put the car on support. Wax all exterior and interior. Take off injectors and keep them in linen cloth at 4 degrees Celsius in wine cooler. Upon return you should replace spark plugs and coils. Walnut blast intake, swap all rotors and buy new battery. Don't forget to swap transmission fluid and filter and lube turbines from inside (will require disassembly). This is the standard procedure for 2-3 weeks off. If you are going for a month - it's better to sell the car and buy new one upon return.
10
Violator4587.50 BimmerTy192.50 P111572.00 Kraftwerk AG460.00 Postie6e9.00 alphaod1149.50 Mr_Burt77.50 Flee61561.50 Markbebb38.00 The Libertine1235.50 |
01-02-2019, 11:17 AM | #9 |
Rep 1,066
Drives: 2015 X5 50i M Sport
Just fill the gas tank. Don't even bother adding fuel stabilizer.
2019 Cayenne Turbo
01-02-2019, 12:55 PM | #10 | |
231
Rep 369
I don't want my battery died and mess with settings or electronics, that happened to my Sierra Denali ones
Current
TOPEC216.50 |
01-02-2019, 12:56 PM | #11 |
231
Rep 369
I actually found it my car is equipped with battery charger, all I have to do is plug in to the outlet
Current
01-02-2019, 01:12 PM | #13 | |
231
Rep 369
Current
01-02-2019, 03:57 PM | #14 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
Just go and enjoy warm weather.
Freude am Fahren.
01-02-2019, 04:37 PM | #15 |
231
Rep 369
Thanks
Current
01-02-2019, 10:23 PM | #16 |
Rep 535
I left my 2014 parked for over 30 days straight in near freezing temperature last month. Started on the first attempt. No tickle charger.
I would just leave your 2018 just like that. If it doesnt start, you have to get it looked at.
Present: 2014 X5 50i
01-02-2019, 11:39 PM | #17 |
Rep 1,340
Wrong advice to not charge - will shorten life of the battery, even though it may start the car after a month of no usage.
https://www.batterystuff.com/blog/ag...practices.html |
01-03-2019, 08:24 AM | #18 | |
231
Rep 369
Current
01-03-2019, 09:22 PM | #20 | |
The General
55
Rep 124
01-03-2019, 10:56 PM | #21 | |
Rep 7,484
Granted, a new vehicle and battery parked for about a month will probably start upon return...but if you find yourself in this situation a lot...you may want to invest in a battery maintainer/tender that you can hook up quickly to the jump start locations in the engine bay. Read the material at the link above for the reason why (which is what some have already stated in regard to long-term health of your battery).
01-03-2019, 11:43 PM | #22 | ||
231
Rep 369
Looks like problem solved but thanks everyone who wants to help
Current
