      01-23-2019, 02:00 PM   #23
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
Originally Posted by Silververtu View Post
$1k coilover isn't out of ordinary. Lots of well known Japanese brands coilovers, made in Japan, are less than $1k. Of course those are most likely for Japanese cars. JRZ makes custom track-ready/autocross suspension starting at around $1.5k. KW1 is around $1.3-1.5k for 3 series/Audi A4 application. The only issue is the size of aftermarket X5 suspension is too small, so each set of suspension carries a higher R&D cost for X5 application, which in terms driving the price up. Also lack of competition in the marketplace.
If KW would just make a V1 for the X5, that would solve all of my problems!
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      01-23-2019, 03:32 PM   #24
Silververtu
Silververtu's Avatar
231
Drives: 2015 X5 50i M Sport
It would have been installed on mine too!
2019 Cayenne Turbo
Gone but not forgotten:
2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport
      01-23-2019, 04:20 PM   #25
Road Carnage
Road Carnage's Avatar
Drives: 96 328is, 15 X5 50i
I want to say BC are made in Taiwan. To compare, H&R springs are about $300, a set of Bilstein B6 shocks are about $1k, so a set of quality coilovers in the $1k range isn't too far out of the question.
But yea comparing $1k to $2500 for KW makes you scratch your head doesn't it? It seems like a lot of folks have had a positive experience with them so who knows.
Looks like the difference is adjustability. The KW’s only come in V3 with full compression and rebound damping adjustability, along with ride height adjustability. Looks like the BC are not adjustable, more equivalent to the KW V1 set up which is much less expensive (but not available for the f15).
That’ll buff out
      01-23-2019, 06:14 PM   #26
mikew2069
mikew2069's Avatar
413
The BC are actually adjustable. "BC Racing offers one of the widest ranges of damping adjustment with 30-clicks of compression/rebound adjusted simultaneously on the BR Series"
BM3/H&R/Borla
      01-24-2019, 11:32 AM   #27
Road Carnage
Oops, my bad, I was looking at a set for my E36 when I wrote that. You are correct that the BC’s are adjustable. Looks like a good optio, go for it and report back! Too bad you are to closer to Philly, we could compare rides.
That’ll buff out
      01-24-2019, 03:44 PM   #28
CommoN81
Drives: 2016 X5 35i
I had BC on my Subaru. Great option for the money. Quality product and great adjustment options.
      01-24-2019, 05:03 PM   #29
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
KWs are also resistant to corrosion and use a bit more expensive steel for that. Folks in 3 series forum opt for ST coilovers - that are owned by KW and are exactly same coilovers, but made from less expensive steel for those who don't have snow and salt to worry about. The problem is that there is no KW3 option in ST lineup (only KW1 and possibly KW2)
      01-24-2019, 06:42 PM   #30
mikew2069
mikew2069's Avatar
413
I'd happily take a KW1 option. Too bad ST doesn't make an X5 kit.
BM3/H&R/Borla
      01-25-2019, 09:57 PM   #31
M302_imola
M302_imola's Avatar
843
Drives: '15 X5 35i Xdrive Mineral Whit
Passed an F85 X5M on the interstate today and really liked the stance. Has me wondering if the F85 X5M suspension can be used on the F15 X5? I have an xline with standard suspension...would the X5M suspension lower the car significantly?
      01-25-2019, 10:23 PM   #32
If I remember correctly, F85/F86 X5M/X6M uses the same major suspension components and geometry.
Slightly different front spring than 50i.
PM for Everyday DEALS!!
      01-25-2019, 10:27 PM   #33
Modedx5
Drives: 2012 X5 35i
Side note-you guys think the dinan supplement ride quality and handling kit would fit the 50i msport? I have HR springs currently on it and wanted to add the kit to help with bottoming out.
      01-25-2019, 10:30 PM   #34
M302_imola
M302_imola's Avatar
843
Interesting! I swear it looked lower. Of course it was on OEM 21" wheels and I'm on 22" reps. If the F85 was lower I'm sure we'd see way more F15's on that suspension.
      01-25-2019, 10:32 PM   #35
It is lower because of the spring rate.
Shocks also different compression amd rebound.
But the geometry and main components are the same.
      01-25-2019, 10:35 PM   #36
If you want to avoid bottoming out, kept the stock bump stop.
But if you want to avoid riding on a bump stop, then you change to Dinan bump stop.
      01-26-2019, 07:22 AM   #37
mikew2069
mikew2069's Avatar
413
I've looked at that and thought about it but it really comes back to the soft stock shocks. We need something tighter that will help with both rebound and compression.
BM3/H&R/Borla
      01-26-2019, 10:23 PM   #38
Bilstein B6 is the answer if you are running H&R or Eibach Spring.
Otherwise, KW V3 is your best option.
I would not even look into cheaper brands.
You get what you pay for.
      01-26-2019, 10:33 PM   #39
daytonaviolet
OEM CSL Whore
daytonaviolet's Avatar
Philippines
1253
Drives: 2017 F85 X5M
To be clear .. kw v3 does not have rear springs ?
      01-26-2019, 10:41 PM   #40
daytonaviolet
OEM CSL Whore
Philippines
1253
My point is .. if you don't have DHP, KW V3 will not work as it does not have rear springs 😜
      01-26-2019, 10:49 PM   #41
mikew2069
mikew2069's Avatar
413
Well I’ve been waiting for my B6 for two months now and I’m over it. Sure you get what you pay for but you don’t have to buy the most expensive thing out there to get something good quality. From what I can tell, most people have been happy with BC.
They do make a Kw V3 version with rear springs.
BM3/H&R/Borla
      01-26-2019, 11:02 PM   #42
They do. Sold a bunch of them.
      01-26-2019, 11:19 PM   #43
daytonaviolet
OEM CSL Whore
Philippines
1253
I just realize that there are 3 kinds of kw v3 for our cars and one of them does support 4 springs 😜
r33_RGSport12996.00
      01-28-2019, 10:26 AM   #44
mikew2069
mikew2069's Avatar
413
I tried searching around but couldn't find spring rates. Does anyone know the standard suspension factory spring rates for front a rear? I would also like to know H&R and KW spring rates.
BM3/H&R/Borla
