      05-28-2014, 09:13 PM   #155
Originally Posted by stewy604 View Post
r33, I am going to do the phone cradle delete as well, it just takes up too much space in the already tiny center console. Anything I should be concerned with here?
Nothing you should be concerned but having the space that it was originally designed for.
      05-28-2014, 10:49 PM   #156
opasha
opasha's Avatar
1329
Drives: 2014 BMW X5 50i
Exactly .
@stewy604, just follow the instructions from the cradle thread: http://f15.bimmerpost.com/forums/sho...ghlight=cradle.
Page 1: r33 has excellent directions with pictures.
Page 3: I have just added further tips/pictures to aid in the wire disconnections at the end.
I used a Torx T-25 screw driver. That seems to be the main tool while some have commented using a T-30 - just double check to make sure how big your screws are. If you have any questions, just ask. It's pretty straightforward. The wire portion is a bit tricky, which is why I provided more information/pics. Good luck!
      06-16-2014, 11:22 PM   #157
Karthik
Drives: 2015 x35i M Sport
I wish I live near Socal.
You are genius r33.
      06-16-2014, 11:32 PM   #158
You are genius r33.
Thank you.
I am just helping in providing the solution.
      06-17-2014, 12:48 PM   #159
1230vani
1230vani's Avatar
653
Drives: G05 40i LCI
Just received a few more of the grill trim.
Attachment 1020394
Also the plastic rivet for the fender flare that need to be partially removed in installation process. I personally only able to take off 3 of them instead of the whole thing.
Attachment 1020399
Hi r33, grill trim inserts, if i want them mounted on the fully closed black plastic as is on the m package, which parts do i need? Thanks much!
      06-17-2014, 12:51 PM   #160
1230vani
1230vani's Avatar
653
Drives: G05 40i LCI
Just mounted titanium grills and those inserts are needed for proper look (i was not initially planning them but now i am hooked).
      06-17-2014, 01:04 PM   #161
@1230vani,
You will need these.
1 set of the grill trim
8 pcs of the locking ring
16 pcs of the plastic rivet (white plastic river for MW and AW, others uses Black)
PM me if you want it, I have a few set in stock.
      06-18-2014, 12:34 AM   #162
1230vani
1230vani's Avatar
653
Drives: G05 40i LCI
@1230vani,
Hi, will pm you soon (for other stuff such as coding and tpms), am quite impatient of having them put on the car and you are all the way in US so it would take quite some time. The car looks empty without the lower silver looking pieces. Thanks a lot for your input!
      06-18-2014, 12:55 AM   #163
@1230vani,
Where are you at anyway?
      06-18-2014, 03:19 AM   #164
1230vani
1230vani's Avatar
653
Drives: G05 40i LCI
Currently in Vienna, Austria.
      06-21-2014, 06:32 PM   #165
mattbar1
Drives: 2014 X5 M Sport 50i
Attachment 1020394
Attachment 1020399
Do you mind posting the part number and where to get the rivets? I think you or someone posted before, but I can not find them.
I need to replace my rear bumper and will need to replace the rivets on the rear fender flares.
MB
      06-22-2014, 11:40 AM   #166
MB
The black rivets is 07 14 7 293 278
The white rivets is 07 14 7 391 323
The qty needed is 12pcs per rear.
Good luck.
      06-23-2014, 10:04 AM   #167
Just installed my own painted reflector over the weekend.
      06-23-2014, 10:53 AM   #168
Socal2025
Drives: 2018 540i
The painted reflectors look even better in person. By the way, have you figured out if there is a coding that unlocks all doors when the engine is either (1) shut off or (2) the driver door is opened? Just wondering if it is even possible.
      06-23-2014, 10:56 AM   #169
@socal2025, I will look for it today and let you know.
      06-23-2014, 11:30 AM   #170
wdimagineer
wdimagineer's Avatar
Drives: 2015 X5 M
There is. Inside BDC CLM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK (or similar) will do this.
Set your idrive preferences to driver door or all doors.
      07-15-2014, 06:41 PM   #171
oshiri
Drives: F15 X5 30d
Coding help?
Simple basic coding,
- windows rollup via keyfob / comfort access
- side mirror fold via keyfob / comfort access
- trunk close via keyfob / driver side button
- DVD in motion
- Temperature on TPMS screen (default only shows pressure)
- M Performance splash screen
- Lane departure on HUD
- Signal on HUD
Still working on some more.
Hey mate just got my f15 last week, and just joined this forum in the last few days. lots of information around, particularly from you!
quick question, can you give me any more information, or perhaps point me in the right direction, about coding to reduce the time it takes to fold the side mirrors? is there also any way to code the one tap left/right signal to stay on for more than just 3 occurrences?
thanks! (and sweet looking ride!)
      07-15-2014, 09:38 PM   #172
@oshiri, welcome to the club.
I sent you a PM on the cheatsheet link. I hope you can start from there.
      08-14-2014, 06:22 PM   #173
Finally, got my wheels.
Not the greatest picture, but here they are.
      08-14-2014, 07:42 PM   #174
OuKEnFoLdMX
OuKEnFoLdMX's Avatar
Mexico
26
Drives: BMW F15
r33 are those 22? wheels, can you tell me were you buy them and the price, do you have runflat? thanks
      08-14-2014, 08:54 PM   #175
opasha
opasha's Avatar
1329
@r33, absolutely stunning wheels, my friend! . They really make your car look like a beast!
Yes, they are 22". They are HRE p104 I believe. He said they cost about $2k per wheel on page 6 of this thread. Also, no one makes a 22" runflat.
      08-14-2014, 09:04 PM   #176
Yes, they are 22" wrapped with Pirelli Scorpion non-RFT. It rides better than the 20" RFT IMO. Much smoother and forgiving than the RFT.
@opasha, thank you. I just wish that someone making a better wheel balance weight, that shiny thing are an eye sore.
I have another brand of wheel in mind, a friend's business. So, I may switch the wheels.
But still debating.
It is a carmod syndrome that I have.
