10-01-2016, 01:03 PM | #1 |
Rep 5,724
Drives: '24 iX50; '23 i4 M50
Factory Alignment 20"
Hi Guys,
Just noticed a nail (in the shoulder cannot be repaired) in my LR tire (20" DWS)--bad luck as I replaced this tire about a year ago due to another nail! Anyway, when I was measuring the tire depths on the remaining 3 tires, in order to determine if I could get a way with replacing just the one tire (so long as there isn't more than 4/32nds from the other tire tread depths), I noticed crazy uneven wear on each tire. We all know BMW is notorious for negative camber and the insides wear faster, but readings from the same tire could range from as low as 5/32 to 9/32! I measured each tire at four different places. My question is have folks with 20" tires experienced out of spec alignments from the factory like those of us familiar with the E70 experienced? I searched and found many skeptics about out of spec alignments coming from the factory, but this was unfortunately the case for many of us with our E70s and the 20" tires. Back to the tire, I guess I'll be overly cautious and replace all 4 tires if I were to go with the lowest depth reading 5/32 as that would be too great a difference with a new 10/32 Conti DWS. Plus, Tire Rack is covering the one tire replacement thanks to their n/c road hazard insurance and they no longer carry the DWS in our 315 size. Not sure mixing the DWS with their latest DWS06 would be wise depending on how much different the tread pattern is between the tires.
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
11-01-2016, 10:57 AM | #2 |
Rep 22
Keif, we've experienced the exact opposite in our 'll X5d with 20" The fronts wore extraordinarily evenly, the rears nearly so (center of the tire wore slightly faster, but it's what you'd expect with a tire that wide with centrifugal force and all). Note that we are running non-runflats (Michelin Sport Pilots), in a pretty even mix of freeway & city. I think we got nearly 30~35k on the first set, and we're over that for the second set and don't yet need to replace.
11-01-2016, 04:07 PM | #4 |
Rep 11,135
Just measured my P Zeros, both front and back. They are wearing pretty evenly so far. I'm switching to Michelin Super Sports soon, so we'll see how they do.
11-01-2016, 05:27 PM | #5 |
Rep 251
Had the same issue, see my post here: http://f15.bimmerpost.com/forums/sho....php?t=1303263
As part of my ordeal I was informed that the car can tolerate more wear difference front to back than side to side, which makes sense. |
11-01-2016, 07:50 PM | #6 |
1148
Rep 2,426
Recently replaced two tires on a Cayenne Turbo that now has mixed DWS/DWS06 tires, and does not seem have affected the driving dynamics of the car.
