      10-02-2015, 06:36 PM   #23
Alan l.
Alan l.'s Avatar
5450
Originally Posted by Cost a lot View Post
Hang on! Hang on, the photo above shows solid rotors, then the one below shows a drilled rotor! Please explain. Did you use original BMW pads? Give Carbotec pads a go, they are almost zero dust and slightly better braking over stock pads. Have been using them for 8 years. Have tried EBC, however Carbotec better. Can't stand the dust of the BMW pads.
Good photo, love to see rear and also on car with wheel.
Enjoy the new brakes. I also agree, Msport should come with these brakes as standard. In Aus. the MPBP is $6,3000 + fitting....
I am using the F85 X5M front rotors with my MPBK. Rotors are the same exact size except these are two piece and cross drilled. I got it for the looks honestly.
I will give carbotec a try if the stock mpbk pads ends up dusting too much.
      10-02-2015, 07:05 PM   #24
atomic80
Drives: 997TT
Do you have the parts numbers for carbotec and a source for them? The stock pads definitely do give off too must dust! I'm constantly cleaning mine.
      10-02-2015, 08:36 PM   #25
Alan l.
Alan l.'s Avatar
5450
I don't but I'm sure Ben could source them. I would guess it would be the same pads that fit the E70 X5M would be the ones we need since we have the same brakes.
Alan
      10-02-2015, 09:55 PM   #26
kskpsu
kskpsu's Avatar
Drives: 1M; E90 M3 ZCP; M4 GTS
'11 BMW 1M  [9.83]
My god... I think these M Performance brakes ranks right up there as my favorite mod. The coding last night made them feel amazing plus I spent the morning rebleeding the brakes one more time to make sure there is zero air left in the lines. The improvement over the stock 35i brakes is DRAMATIC. The feel is what I am use to in typical BMW fashion. The stock brakes were good but these gives me the feeling of confidence like I have plenty of brake left if needed.
All in all it's worth every penny.
Alan
I noticed an improvement over the stock 50i brakes, so beefing up the 35i setup is a no brainer (or get orphaned stock 50i brakes from others that have done the upgrade). The braking and bite also improved over time relative to the initial install...do a good bedding and let it all come together.
-kskpsu
      10-02-2015, 11:59 PM   #27
Alan, atomic80 , I'll check on Monday of the pads.
      10-03-2015, 12:53 AM   #28
atomic80
Drives: 997TT
I have those stock 50i brakes if anyone wants them.
      10-03-2015, 04:21 AM   #29
Cost a lot
Australia
11
Drives: 30d Msport 2015 F15
I will supply contact details and part numbers for Carbotec pads next week. At the holiday house for a long weekend. However they are a U.S.A product run by two brothers.
I can't rave about the Carbotec pads enough. I have had them on my last 3 BMWs, I put them on a delivery. If you hate brake dust get Carbotec pads, awesome.
      10-04-2015, 08:00 AM   #30
kskpsu
kskpsu's Avatar
'11 BMW 1M  [9.83]
In all seriousness, it would be an awesome pickup for anyone in a 35i that doesn't want the outlay of the M performance brakes. The difference is notable..for instance, the rear rotors are almost the size of the fronts on the 35i if I'm not mistaken, and they fit the E70 as well. Sold mine to my neighbor that has an E70 35i M-Sport, and he is pumped about them. Could powder coat the calipers too for an enhanced look.
-kskpsu
      10-05-2015, 03:17 AM   #31
schaeffs
Drives: X5
M50d brakes - 223M rims
Guys - apologies in hijacking this thread but do you know if the 223M wheels will fit over the M50d brakes? I ask this as I have a set from my old E70 with winters on them - does anyone have this combo? Thanks!!
      10-05-2015, 11:19 AM   #32
X5Jouster
X5Jouster's Avatar
110
Drives: X5 xDrive50I Msport
12k miles on my 50i. im completing the upgrade, i have the MPBK in my garage.
willing to get the complete 50i stock kit to anyone who can figure out what shipping will cost from 33433 florida
      10-05-2015, 11:20 AM   #33
X5Jouster
X5Jouster's Avatar
110
i feel the same way. i have the MPBK kit and have not decided on the drilled rotors quite yet....it will most definitely add that edge in looks
      10-06-2015, 08:07 AM   #34
Alan l.
Alan l.'s Avatar
5450
For those interested in coding your F15 for larger brakes...here is the instructions I followed. Huge thanks to Shawnsheridan for figuring out the code for the F15 being SBRE. For the F30 its SPBR.
This is how you code for Big brake kits for the car. This is REQUIRED or you will have mushy brakes after installing the brakes. Got this from another thread....
=> Connect
=> Expert Mode
=> Coding
=> Read FA
=> Save FA
=> Editors and viewers
=> FA-editor
=> Go to HO-Wort and right click on "Edit," then type SBRE under the HO-Wort file
=> Select the FA, "Calculate FA" to verify that no errors are found after adding the SBRE.
=> Write (write) FA to your car. No confirmation window will appear after saving the FA to the car
=> Expert Mode
=> Coding
=> Read (read) the FA. You are able to see SBRE be added to the HO-Wort folder on your car.
=> Read SVT, and locate the "DSC" (File Folder SVT / ECU / DSC), then right-click the "DSC" folder and select "Code". Consolidation should start immediately.
=> Allow the coding is over, and repeat step 1 to save a copy of the new FA.
=> Disconnect the car's computer.
The M-Performance brake is now activated and enjoy the authentic experience of M Performance brake.
      10-06-2015, 05:33 PM   #35
Cost a lot
Australia
11
All, contact details for the Carbotec brake pads.
'Concord NC 28027.
4031 Dearborn Place Nw, Concord, NC 28027.
PH- 877 899 5024 or local 704 481 8500.
I only have the part numbers for M50d brakes (F15,2014-2015), as follows.
(F-CT1443-1521, R-CT919-1521). Note the '1521' refers to the pad performance level, being their 'high performance street compound, low dust'. You can select between a few compounds.
These guys are excellent in that if they don't have a set available for a particular brake set up/car, all you have to do is send them a set of original pads and they will remove the 'BMW' pad compound and install their pad compound to the original backing plate. Check out their web site, you can search you vehicle, however you may have to contact them for details on the BMW MPBP and supply you vin #.
Trust me if you hate brake dust, get a set of these and you will never look back.
Enjoy.
      10-08-2015, 12:30 PM   #36
stewy604
stewy604's Avatar
290
^^ Thanks for the tip on those. I've been running Akebono Euros on the rear of my A4, front is Pagid - OEM Porsche with Cayenne S 6-pots. The Akebonos have been great, VERY low dust. I got tired of having to wash my wheels every few days.
2007 Suzuki GSX-R 750
      10-11-2015, 10:14 PM   #37
Alan l.
Alan l.'s Avatar
5450
My god you are right. The MPBK gives off sooooo much more brake dust. After one drive and my wheels are dark grey/black! The amount of dust I get in one day now is what i use to get in a week worth of driving with the stock pads.
Alan
      10-12-2015, 01:16 AM   #38
Cost a lot
Australia
11
Yep, get the carbo Tec pads. Almost no more dust and no performance loss at all. Even more important as you have beautful wheels. As I said, I have not run original BMW pads for over 10 years now.
      10-12-2015, 08:58 AM   #39
X5Jouster
X5Jouster's Avatar
110
the front rotors are monsters!
i definitely underestimated the sheer mass and weight of the rotors judging by the pictures
      10-13-2015, 06:24 AM   #40
atomic80
Drives: 997TT
Where can I get those carbo Tec pads and are they available for the MPBK? All that brake dust is driving me nuts!!! I have the new rotors but I think I'll wait to get them installed until I get those pads.
      10-13-2015, 07:38 PM   #41
bjcarls
Drives: 22 Tahoe, 22 R1S, 23 Z07
I can't find a single aftermarket pad for an x5 50i. I sent an email to carbotec.
The only thing worse than BMW pads are my wife's audi pads...
      10-13-2015, 07:47 PM   #42
Alan l.
Alan l.'s Avatar
5450
Carbotech should have it for your car with the MPB since they have a kit for the E70 X5M which is the same brakes as ours. You'll want the 1521 pads from carbotech
      10-14-2015, 05:22 PM   #43
ozx5
Drives: bmw
Alan I
Such a great writeup - and to all of you, giving real non bs recommendations/experience you all should give yourself a pat on the back for sharing it with us
I just want to know one thing - if the MPBK for say a 50i is a Non-cross drilled (and now naturally you have this) did you have to do a swap of somesort ?? Or you have a choice to go cross drilled ??.... Was it a cost difference ??
Just want to know what was involved in the jump of getting MPBK with "cross drilled rotors"?
Thanks again mate
      10-14-2015, 07:32 PM   #44
Alan l.
Alan l.'s Avatar
5450
In order for you to have cross drilled rotors with the MPBK you would need to buy F85 X5M rotors which goes for about $315 per rotor.
I ended up selling the rotors that came with the MPBK for $400 so at the end it really only costed me $230 to upgrade to the two piece X5M cross drilled rotors. Realistically I could have sold the MPBK rotors for even more than $400 to the E70X5M guys because they sell for about $600 online too.
Alan
