10-28-2021, 05:33 PM | #1 |
Rep 10
Sport+ with BimmerCode
This is what I did to get Sport+ working on my F15 with BimmerCode. I hope this can help some of you out there.
(This programs Sports+ mode to active) Connect to BimmerCode Step 1- Select Integrated Chassis Management(ICMQL) Step 2- Select Expert Mode Step 3- Select 300A DSC_ICM_CODIERDATEN Step 4- Select FesHasMode5 and change to aktiv Step 5- Code (This programs the instrument cluster to show Sports+ mode) Step 1- Select Instrument Cluster(KOMBI L6 BO) Step 2- Select Expert Mode Step 3- Select 300C ECO_FDS Step 4- Select the following one by one and change all to menue_3 FDS_MENUE_TEXT_1 FDS_MENUE_SIGNAL_1 FDS_MENUE_TEXT_2 FDS_MENUE_SIGNAL_2 FDS_MENUE_TEXT_3 FDS_MENUE_SIGNAL_3 FDS_MENUE_TEXT_4 FDS_MENUE_SIGNAL_4 Step 5- Code I did get an error after coding the instrument cluster because the time needed to be set again. If this happens go to iDrive Main menu, then Settings, then Time/Date and uncheck then recheck Automatic time setting. This will change the time on the cluster to the current time and the error will go away. ***Check out this thread if you want to auto start in Sport mode and set Sport mode to "individualized". https://f15.bimmerpost.com/forums/sh....php?t=1386895 Last edited by StinglikeaBMW; 11-04-2021 at 10:09 PM.. Reason: Add information |
10-30-2021, 12:49 PM | #2 |
Rep 1,497
Appreciate the simple breakdown. I guess my question is, what does sport + mode give you over sport mode, other than traction control being turned off? For reference, I have an x-line without sport + mode nor paddle shifters.
StinglikeaBMW15.50 |
10-30-2021, 04:05 PM | #4 | |
Rep 7,548
Your initial thoughts are accurate…and CatalinP’s reply would verify your initial thinking. Sport+ basically adds a quick way to put the car into DTC (dynamic traction control) mode. DTC doesn’t totally disable DSC…it give the car a bit more leeway in regards to wheel slippage without ABS braking kicking in…as well as lowering/reducing the old/original ASC (automatic stability control) from kicking in. ASC is the technology that reduces engine throttle..this was the first iteration of traction control that BMW utilized back in the early 1990s before DSC was developed that added ABS braking to traction control. When wheel slippage is detected…ASC reduces engine throttle to help the driving wheels regain traction. Other things gained with the SPORT+ feature is LAUNCH CONTROL & accelerator pedal KICK DOWN is disabled. {LC is a feature that comes when you have the SAT & SPORT+} If your BMW did not come with the SPORT+ feature…even if you code it in…you can only get so much from coding it in. You can’t gain some of the things that BMWs that came with this feature from the factory due to not having the other options or equipment that those cars benefit from. Some of the chassis & suspension adaptations for SPORT+ come from adaptive suspensions and electronic steering options. If your BMW doesn’t have those additional options…coding SPORT+ will not give you the dynamic handling that the adaptive M handling package gives or the IAS (rear steering) adds. You can see/verify what the owners manual states about SPORT & SPORT+…and you can see a chart (below) that shows what occurs with the chassis & suspension in the various driving mode selections & gear shift lever placement.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 10-30-2021 at 04:22 PM.. |
5
10-30-2021, 06:08 PM | #5 | |
Rep 1,497
Hop7464.50 |
11-04-2021, 08:28 AM | #6 |
Rep 814
Drives: BMW X5 XDrive35i
FWIW, I tried to do this on my 17 and it didn't work nor did it change any menus.
AFAIK, only Esys can code in Sport+ because you need to add 2TB to the VO. So I'll likely be doing this at some point. Since I have an XHP tune which delineates the differences in shifting between Comfort and Sport modes more, I want DTC off when I'm in Sport+ so I get the faster shifts and less interference from the system when the roads are covered in salt later this season. Just my two cents.
11-04-2021, 10:22 AM | #7 | |
Rep 10
It would be great to get other peoples input to see if these steps worked or not, and if they have anything else to add. Last edited by StinglikeaBMW; 11-04-2021 at 10:41 AM.. |
sukhk5272192.00 |
11-04-2021, 02:41 PM | #8 |
Rep 162
Worked on my 2017 with no issues using Bimmercode
11-04-2021, 03:05 PM | #9 |
Rep 814
Interesting. I may have to try this again.
11-04-2021, 03:31 PM | #10 |
Rep 11
Worked on my 2014 with BimmerCode as well
11-04-2021, 08:50 PM | #11 |
Rep 814
Must be user error on my part then
11-05-2021, 01:43 PM | #12 |
Rep 814
Got it working, confirmed LC works too since I had SAT enabled already. Hell yea.
11-16-2021, 12:36 PM | #13 |
Rep 1,497
07-16-2022, 11:24 PM | #14 |
Rep 18
Thanks so much. Worked perfect for me. I have a 2015 Xdrive50i x-line. I activated SAT, drove it about 30 miles then coded this in. Drove another 5 miles and did my first launch control launch.
07-22-2022, 01:07 PM | #17 |
Rep 218
I think it was added when I had MPPK installed. Does just adding the coding for Sport+ do much without the MPPK software tune that increases horsepower and torque, optimizes shift points, and makes the exhaust note a little deeper? I do have the M Sport option and the Sport and Sport+ options may have been available anyway, just not the MPPK tune that adds the performance increases that changing the sport setting activates.
07-22-2022, 02:13 PM | #18 | |
Rep 5,066
07-24-2022, 05:31 PM | #19 |
Rep 25
Just added this feature and worked as said above, one question though. Does the sport+ option show up in the cluster option to pick as mine does not, still has eco, comfort and sport but sport+ does show up next to gear indicator.
07-25-2022, 06:29 PM | #20 |
Rep 7,548
If coded correctly…yes SPORT+ should appear in the display and it should turn DSC off…and turn DST on (TRACTION appears in the cluster).
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 07-25-2022 at 06:37 PM.. |
07-25-2022, 07:00 PM | #21 |
Rep 25
It does show up next to the gear indicator but is not listed in the list with eco, comfort and sport. Just making sure I coded correctly but followed the directions to a T. It does also turn on dsc and traction control off
07-26-2022, 05:08 AM | #22 |
Rep 7,548
See 3rd paragraph in first post.
