09-01-2015, 08:54 PM | #23 |
Rep 18,682
22's and it rides better than stock 20".
If you want to upgrade, I suggest to skip the 21", the tire prices are ridiculous. If you need help with OEM replicas, let me know.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com SPRING Sale!! 04/01 - 04/15 - Code: "SPRING2024" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
OFFWHITEX5325.50 |
09-02-2015, 11:40 AM | #25 |
Rep 1,547
21's or 22's...just my .02. I'm looking to swap my 20" 469M's next spring...leaning towards 22's.
09-02-2015, 04:33 PM | #26 |
782
Rep 311
Drives: 22 Mint Green G80 M3
09-02-2015, 06:54 PM | #27 |
Rep 18,682
Here is the post in my mods thread.
http://f15.bimmerpost.com/forums/sho...&postcount=173 I have yet to update that thread with nicer pictures.
09-03-2015, 12:08 PM | #29 |
Rep 1,547
^^^ Lovin' that 1st set on the blue F15 Albert...
09-08-2015, 11:40 PM | #32 |
Herr Oberst
244
Rep 531
In answer to the OEM vs. Aftermarket question, it's not a matter of who made the wheels so much as a matter of how they were made. Many aftermarket makers use the same low-pressure casting process as OEM spec. The ones to watch out for *tend* to be the replica wheels, especially ones that seem too good to be true on price. These are typically made with gravity casting instead of LP casting or roll-forging (sometimes called roll-forming for a similar process). Gravity cast wheels tend to fail at much higher rate, because the process is cheaper but produces a lower quality wheel.
Long story short, know what you're buying. When in doubt, OEM is a safe bet. |
09-09-2015, 01:13 PM | #33 |
Rep 106
What are the factory tire sizes for the X5, I see some pictures where the tire look really wide, are these factory or aftermarket non run flats?
Are the bigger non run flats give a more comfortable ride. For e.g. - will a 20 inch non flat be more comfortable vs a 20 inch run flat? |
09-09-2015, 01:40 PM | #34 | |
Herr Oberst
244
Rep 531
Comparing different sizes can yield different results. For example, a run flat on a 19" wheel can be more comfortable than a tradition tire on a 21" wheel (given equal circumferences). YMMV. |
02-13-2018, 12:06 PM | #35 |
Long Time Bimmer Fan
215
Rep 156
I'm looking at some new wheels for mine too and would consider 22" but the only problem I have with going 22" is that you can't go super wide (325) in the back and can't have a staggered setup. Speaking to some tire shops, they all say you can't go bigger than 285 on 22". Since I want wide and staggered, I'm forced to go 21 or 20.
02-13-2018, 12:08 PM | #36 | |
Rep 2,388
295/30-22 front and 335/25-22 rear Last edited by DuSh; 02-13-2018 at 12:18 PM.. |
02-13-2018, 12:16 PM | #37 |
215
Rep 156
Maybe I was being told that in order to maintain the same wheel height as the stock setup and not throw off the speedometer. That's probably the caveat I missed. Does that make sense?
02-13-2018, 12:19 PM | #38 |
Rep 2,388
295/30-22 front and 335/25-22 rear - that's the setup many are running - it's exactly same height and diameter as oem stock. People are running these for 3 years now since x5 f15 came out
02-13-2018, 12:41 PM | #39 |
215
Rep 156
Interesting, thanks for that, appreciate it! 25 is super low profile...it's all rim but I'm sure looks awesome.
02-13-2018, 03:26 PM | #40 | |
Rep 842
In reality, a 25 aspect ratio on a 335 tire is not as thin as it sounds.
'23 B8, '84 Monte Carlo SS, '23 Escalade, '21 S 580, '20 AMG GT 53 , '18 LS 500, '18 X6, '16 Corvette, '12 750Li, '14 GS 350, '13 ES 350, '10 Maxima, '09 Challenger |
02-13-2018, 03:54 PM | #42 |
Rep 1,180
22's. No one says "I wish I got smaller wheels" but plenty say "I wish I got bigger wheels".
2018 X5 35i M-Sport
02-13-2018, 04:00 PM | #43 |
Rep 842
I wish I got 26s
02-13-2018, 04:35 PM | #44 |
215
Rep 156
Wow, that looks sick! I love how the rims fill the wheel well and that's the look I want. Is that X5M stock height or has it been lowered? Does the F85 sit the same height as the F15 or is it lower out of the factory?
