09-29-2016, 04:12 PM | #1 |
Self-Deprecating Narcissist
7258
Rep 6,561
FS: OEM X5 50i M-Sport Brakes Complete Set F15 F16 E70 E71...
Up for sale is a complete set of OEM BMW X5 50i M-Sport Brakes. I recently installed OEM X5M BBK and have these sitting in my garage waiting for the next owner to take advantage of the savings. Approximately 4000 Miles. This is an excellent and affordable way to upgrade stock brakes on 35i or diesel models and a must have if you have a modified X5 which may go faster than the stock brakes are rated for. Other X5/X6 models have 13.7 inch front brakes and 12.6 inch rears, while these brakes are 15.2 and 13.6 respectively. I am told these would work on E70/E71 X5/X6 but verify before purchasing. -front calipers -front caliper brackets -front pads -front sensor -front backing plates -front spring clips -all hardware -rear calipers -rear caliper brackets -rear pads -rear sensor -rear backing plates -rear spring clips -all hardware I prefer not to ship since this will be quite costly however I will ship if the buyer pays all PayPal and shipping fees. Local pick-up preferred and I would work out a discount for a local buyer to save us both time and energy. Thank you for your consideration and please do not hesitate to contact me with any questions or for photos.
10-26-2016, 07:58 AM | #4 | |
7258
Rep 6,561
i do not have photos off-hand since this is very comprehensive, extensive and complete set of parts. similar to photo below however far more hardware included. ever possible part needed to complete a proper retro-fit: going back to the e70 there were small, medium and large. 35i, 50i, x5m. if i recall correctly front rotors on 35i are 332mm, the 50i get 365mm and the x5m (the kit i installed) get a drilled floating rotor of 385mm. the x5m50d had a completely different caliper: the same type of S/M/L sizing is found on f30/f31/f32 depending on engine size and options:
P111541.50 |
01-16-2017, 05:39 PM | #6 |
7258
Rep 6,561
Sold to the gentleman above. Thank you.
