02-02-2024, 12:31 PM | #1 |
Rep 13
2018 Staggered Tires
Looking for some advice - please excuse the long narrative.
Now before anyone does a mental eye roll - I am a single female & am looking for tire advice as the dealership wants me to replace a tire (25% tread on the rear driver side tire) 🛞 and I don’t want to be taken to the cleaners. I currently have stock Continental ContiSportContact 5-SSR Front 275/40R20 Rear 315/35R20 Instead of replacing just the one tire, I want to switch them out to an all season Run Flats… yes it has to be a run flat, as being it’s a staggered set I can’t tote around two tires ‘just in case’ (mind u I got a nail 2 times in the span of 3 weeks) and sorry I don’t know how to change a tire. Why do I want all season / all weather (whatever they’re called) is because I’m peeling through tread with the cold weather & have the same scenario in the summer if I buy winter tires & no I do not have a place to store them so buying two sets is off the table. Plus it drives like 💩 in the snow with the current tires. I was told that no company makes AS RF’s in my size.. well after some digging I found a company that does but never heard of it - I "think" it would fit everything matches up the same (size obviously, tread depth 10/32, load range SL & index 106 front & 110 rear, speed ratio is W, diameter 28.7) which I THINK matches everything the Conti’s are. But I just don't know the brand - Lexani - a sub of Nexen… Does know anything about them or are they garbage? It’s the Lexani RFX Plus https://lexanitires.com/en/rfx-plus |
02-02-2024, 12:37 PM | #2 |
Rep 662
www.tirerack.com Problem solved.
02-02-2024, 12:38 PM | #3 | |
Rep 13
02-02-2024, 12:45 PM | #4 |
Rep 2,517
Lexani is sub brand of Nexen tires and these are sold through Walmart or other retailers and considered to be "budget" tires. I personally would not buy this brand, and this particular tire thread doesn't look too much of "all season to me",even it is being marketed as such. Many forum members including myself switched to the regular tires and pretty happy, run flats are expensive, loud and stiff. You don't need a second spare if you have staggered set up, regular one will work, you can just drive slow and for short distance (same as RFT), check your user manual. If you skip the run flats requirement you will have way more options for all season tires in this size.
02-02-2024, 12:48 PM | #5 | |
Rep 662
02-03-2024, 06:31 AM | #6 |
Rep 496
I’d recommend switching to non-run flats so you can get the tires you want. Then carry a mobile tire repair kit with you. You may not be able to plug the tire yourself, but at the very worst a tow truck driver would be able to. Unless you have a complete blowout from hitting something, which would likely also blowout a runflat.
02-03-2024, 07:11 AM | #7 |
Rep 549
I would just go ahead and switch to non-RFT. I just slapped on a full set of Bridgestone Alenza A/S Ultras and really like these tires compared to the Continental DWS06+’s. They are all season and I really like the performance of them.
Another reason why you may want to go with a Non-RFT is that if you look at your Auto Insurance policy, you most likely are paying for Roadside Assistance/Towing & Labor on your policy… use it 🤷🏽‍♂️ |
02-03-2024, 11:02 AM | #8 |
153
Rep 354
Same setup on my wife’s 2018.
We have the good looking 20” Pirelli P-zero RFT’s on during the warmer months. Then, I insist on putting the ugly 19” Michelin All-Seasons on during the wintry time. My wife raises the roof and whines all winter long until her good looking wheels go back on after three months. Life returns to normal when the winter wheels come off. My point is I go through all this grief because there is no terrific solution with winter & staggered performance wheels/tires. It is good advice to buy a set of namebrand AS non-RFT tires and use the roll on tow truck service if necessary. |
02-06-2024, 08:14 AM | #9 | |
Rep 13
lol she sounds like me! But alas I don’t have storage for an additional set of tires. What do you mean by roll on truck service? |
02-06-2024, 08:16 AM | #10 | |
Rep 13
02-06-2024, 08:23 AM | #11 |
Rep 13
I am seriously thinking of going with non run flats at this point. To drop a grand on tires that no one knows the name of, really makes me hesitate to pull the trigger. I also reviewed my policy & apparently am already paying for emergency roadside assistance. I know my insurance coverage is solid - million dollar plan - literally, yet I never thought to look at roadside assistance, I’ll attribute that to having a blonde moment.
Now off to check about glass coverage since I got my second lovely chip in my windshield. I’m assuming having a heads up display makes the glass more $ & I think after 3 chips it’s replacement time |
02-06-2024, 12:50 PM | #13 |
Rep 496
Roll on truck service is a flat bed tow truck. One that puts your car up on it to transport.
A mobile repair kit is a plug kit. Has pieces that kind of look like licorice and then a couple tools with handles. One you use to make any puncture more uniform, the other actually inserts the “licorice” to seal the hole. Then an air pump that runs off a 12v socket from your car. You may not be able to physically use the tools (but maybe you will…they do take some strength) but a tow truck driver or someone should be able to help out. |
02-06-2024, 12:52 PM | #14 |
Rep 496
02-06-2024, 04:29 PM | #15 |
Self Proclaimed Roundel Junkie
630
Rep 1,594
BMW makes what they call the Mobility kit... It is a lifesaver and worth every penny. Ditch the runflat tires (as many have told you) and get this. I have one in my X3 and also the X5. You can use it just to add air, or switch to repair and it will inject the included tire repair slime and THEN air up a tire. This is perfect if you don't have the means to plug a hole yourself. Very easy, comes in a nice case, and fits under the trunk floor.
https://www.fcpeuro.com/products/bmw...et-71100413439
2018 F15 X5d Carbon Black/Nutmeg Individual- Oil Burner Tow Rig
2013 E82 1M3 Carbon Black/Black- S65/DCT Track Toy 2013 F25 X3 35i Alpine White/Chestnut- German American Family Hauler Past: '11 E91 335is, '11 E90 M3, '10 X5M, '14 328d, '03 330i Dinan3 ZHP, '04 330i ZHP, '12 X3 35i |
03-14-2024, 09:58 AM | #16 |
Rep 13
03-14-2024, 10:00 AM | #17 | |
Rep 13
03-14-2024, 10:15 AM | #19 |
who is this noob
40
Rep 194
You don’t need storage. Your dealership or mechanic will store the wheels for you. Twice per year you stop by and they swap the wheels/tires. This is common in areas that get cold enough to need winter tires. Good opportunity to perform inspection, change cabin filter, etc.
Season-specific tires perform much better than all-seasons. |
03-14-2024, 01:03 PM | #20 | |
Rep 38
03-14-2024, 03:20 PM | #21 |
Rep 3,653
03-14-2024, 05:31 PM | #22 |
Rep 238
Drives: F16 X6 M50i
Pirelli Scorpion All Season SF2. Are those not available in your sizes?
