08-04-2022, 08:30 PM | #5611 | |
Rep 41,041
08-04-2022, 08:39 PM | #5612 | |
Rep 11
08-04-2022, 08:57 PM | #5613 |
Rep 41,041
A distinction without difference, I think. 0x63 is the Diagnostic Address for HU. HU still shows in RED, which is Not Responding.
08-05-2022, 07:29 PM | #5614 |
Rep 11
Just a thought - if the wrong istep shipment was chosen when we were getting the BDC_GW out of programming abort could that cause the connection issue now? If so should I re-flash BDC_GW ensuring the correct istep shipment is chosen? Are there any other modules that I should re-flash in the same fashion that could be affecting the communication issue?
08-05-2022, 07:39 PM | #5615 | |
Rep 41,041
08-07-2022, 10:06 PM | #5616 |
Rep 13
I am looking at purchasing the Mr12Volt carplay MMI box. It uses the MOST system for audio and requires the TV function to be coded. I am not finding any info on how to add the TV to the NBT multimedia options. Does anyone know what I need to do to add this option? I found 1 comment that said I need to add 601 to FA. If this is accurate which modules do I VO code this to? I have do some coding to my X5 following the guides here and just a beginner at coding these cars.
08-07-2022, 10:08 PM | #5617 |
Rep 19
Hi everyone, please help me with coding Msport steering
So I bought new steering with Heating, vibro and paddle shifters. My car (US) doesn't have driver assistance package. So I don't expect vibro to work. Same with paddles, haven't done wiring yet. But I want to code Heating. And LIM button to work. (I had SET on old steering) I did replace column control switch and after coding Heating button lights up. But no Heat to steering. I attached pics of old and new steering, coding done and Error below |
08-28-2022, 01:14 AM | #5620 | |
Rep 11
TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197] ExecutionID=2022/08/28-18:06:09.999 [] prepareTALExecution started [PROGRESS] [] prepareTALExecution finished [PROGRESS] [] prepareVehicleForFlash started [PROGRESS] [] prepareVehicleForFlash finished [PROGRESS] [] SVK-Ist does not match expected SGBMIDs for ecu ECUId:BDC_GW_0x10. Excpected (relevant process classes only): [hwel_000017b8-001_010_002, hwap_00000f3e-255_255_255, hwap_00006f29-255_255_255, hwap_00000f3a-255_255_255], Actual (relevant process classes only): [hwel_000017b8-001_007_009, hwap_00000f3a-255_255_255, hwap_00000f3b-255_255_255, hwap_00000f3e-255_255_255], Missing SGBMID(s): [hwel_000017b8-001_010_002, hwap_00006f29-255_255_255], Surplus SGBMID(s): [hwel_000017b8-001_007_009, hwap_00000f3b-255_255_255] [THROWABLE] [BDC_GW - 10] There was an error during TAL execution, please check the log files. [WARN] [BDC_GW - 10] - [Exception - BDC_GW - 10] SVK-Ist does not match expected SGBMIDs for ecu ECUId:BDC_GW_0x10. Excpected (relevant process classes only): [hwel_000017b8-001_010_002, hwap_00000f3e-255_255_255, hwap_00006f29-255_255_255, hwap_00000f3a-255_255_255], Actual (relevant process classes only): [hwel_000017b8-001_007_009, hwap_00000f3a-255_255_255, hwap_00000f3b-255_255_255, hwap_00000f3e-255_255_255], Missing SGBMID(s): [hwel_000017b8-001_010_002, hwap_00006f29-255_255_255], Surplus SGBMID(s): [hwel_000017b8-001_007_009, hwap_00000f3b-255_255_255] [BDC_GW - 10] installECUBL started [PROGRESS] [BDC_GW - 10] installECUBL finished [PROGRESS] [BDC_GW - 10] finalizeECUBLUpdate started [PROGRESS] [BDC_GW - 10] finalizeECUBLUpdate finished [PROGRESS] MCDDiagService<id=46900, job=com.bmw.psdz.jobs.uds.MCD3_GetSVKfromECU, service=RDBI_SVK - ReadDataByIdentifier SVK, description=error: timeout, link=BDC_BODY_40_ETHERNET> [DIAGSERVICE] MCDDiagService<id=46900, job=com.bmw.psdz.jobs.uds.MCD3_GetSVKfromECU, service=RDBI_SVK - ReadDataByIdentifier SVK, description=error: timeout, link=BDC_BODY_40_ETHERNET> [DIAGSERVICE] MCDDiagService<id=46900, job=com.bmw.psdz.jobs.uds.MCD3_GetSVKfromECU, service=RDBI_SVK - ReadDataByIdentifier SVK, description=error: timeout, link=BDC_BODY_40_ETHERNET> [DIAGSERVICE] [BDC_BODY - 40] There was an error during TAL execution, please check the log files. [WARN] [BDC_BODY - 40] - [Exception - BDC_BODY - 40] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_SVK has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; LinkName: BDC_BODY_40_ETHERNET severity: ERROR [] null [THROWABLE] [] finalizeVehicleFlash started [PROGRESS] MCDDiagService<id=230600, job=com.bmw.psdz.jobs.common.MCD3_FinalizeVehicleF lash, service=DSC, description=error: negative response : conditionsNotCorrect, link=#RtGen_MultipleEcuJob_LogicalLink> [DIAGSERVICE] [] finalizeVehicleFlash finished [PROGRESS] [] prepareVehicleForCoding started [PROGRESS] [] prepareVehicleForCoding finished [PROGRESS] [] finalizeVehicleCoding started [PROGRESS] [] finalizeVehicleCoding finished [PROGRESS] [] finalizeTALExecution started [PROGRESS] [] finalizeTALExecution finished [PROGRESS] TAL execution finished [TAL_EXECUTION_FINISHED] TAL-Execution finished with status: "FinishedWithError". [C207] TAL execution finished. Duration: "1min 7s". [C206] Read SVT after TAL execution started. Read SVT after TAL execution finished. |
08-28-2022, 10:53 AM | #5621 | |
Rep 41,041
Is BDC HWEL in svt_soll Black or Red / Blue?
08-29-2022, 02:47 AM | #5622 | |
Rep 11
See attached for BDC GW after I changed the versions back to 000. |
08-29-2022, 10:58 AM | #5623 | |
Rep 41,041
So after you calculate SVT Target (SVT_soll), check the box that says "HW-IDs from SVTactual" and then Save it. If HWEL is Black only, no Red / Blue HWEL, then you can proceed to flash it. If HWEL is not Black only, the only thing you can do is try different I-Step Shipment dates until hopefully one works. This is simply Trial and Error.
08-30-2022, 11:05 AM | #5624 | |
Rep 247
08-30-2022, 06:07 PM | #5625 | |
Rep 13
09-05-2022, 08:01 PM | #5626 | |
Rep 247
09-10-2022, 10:17 PM | #5627 |
Rep 5
Question: I want to make all VO code changes at once and reprogram the all car (or close to it). It is a 2015 X5 F15 x3.5.
I-Step F025–14–07-505 (same i-step for shipment, last and current). I am using 2.8.1 launcher and e-sys 3.30. That’s the combination that seems to work the best. I coded a bunch of stuff already with no problems (seat belt warning off, remember AC, DVD in motion, radio off and open doors when engine off, etc…). I have never done any VO code, so to make sure I am doing it right, wanted to ask if my plan is "sensible" and I have been doing a lot of research past few weeks to try to figure it out. This is my current Salapa folder looks like this and I have never changed it so that’s the original: 1CA,212,245,248,255,258,2H7,2VB,302,319,322,346,3A G,3AT,3E1,402,420,423,430,441,459,488,493,494,496, 4AC,4NB,4NE,502,508,522,524,563,575,5A1,609,610,64 5,655,676,697,6AC,6AE,6AK,6AM,6AP,823,845,853,8KL, 8S4,8SL,8SM,8TN,992,9AA My VO coding plan: 1) VLD: add VLD, so remove 8S4. 2) Enhanced bluetooth: Add 6NS. Some guides talk about removing a code some don’t. I might already have enhanced bluetooth because I can listen to my iphone music collection with USC (and bluetooth), if that's the case why that code is not there already and should I still code it? 3) Sport mod: add 2TB and clear error code with appropriate steps 4) hitch install: I am installing a Draw-Tite 75600 hitch and following this thread about programming it: https://f15.bimmerpost.com/forums/sh....php?t=1732198 it calls for adding K235 to the HO-WORT folder and then VO code (confirmed from official BMW retrofit instructions). Are there other VO coding option worth the trouble? I am planning on VO code once and take care of details with FDL coding. Is it ok to make all changes at once and then VO code the all car or all ECU one at the time? Starting hitch and OEM wiring harness and module tomorrow. Is the plan ok? should I VO code something else while I am doing the rest? Thanks a lot. |
09-14-2022, 11:06 PM | #5628 |
Rep 5
hitch installed and plugged in. Of course I am getting the trailer error on the dash. I'll wait to code the car, want to first confirm my thoughts in previous post.
09-28-2022, 12:03 PM | #5631 | |
Rep 141
